Author Topic: [GB] 1976 - Flashback to the Colors of the 70's (SA Row 3) --- Shipped  (Read 280949 times)
Offline tjweir
Re: [IC] 1976 - Flashback to the Colors of the 70's (SA Row 3)
« Reply #200 on: Sat, 20 December 2014, 07:18:35 »
I have no SA sets yet, but I'm a big fan of this colourway, interested.
Offline swill
  • builder & enabler
    • swillkb.com
« Reply #201 on: Sat, 20 December 2014, 11:09:26 »
Is there interest in having symbolic arrow keys for the navigation cluster?
i.e.
If so, would you prefer:
  • to replace the text navigation cluster (i.e. "UP,DOWN,RIGHT, LEFT")
  • included in addition to the text direction keys as part the base kit
  • as an optional add-on kit
Other colors?
My opinion:
- I don't think symbolic arrow keys should be the default because we are not using symbols on any of the other keys.
- I like the idea of having the option of getting symbolic arrow keys though.
- I think they should be an additional optional kit as not everyone will want them. (This may risk them not reaching moq).
My two cents anyway.
« Reply #202 on: Sat, 20 December 2014, 15:02:49 »
i.e.
Other colors?
My opinion:
Agreed.  In general, I prefer symbolic arrows, but when a set is designed with all-text mods I prefer to keep that theme going. So I echo swill's thoughts on this one.
Offline IvanIvanovich
  • Mr. Silk Underwear
« Reply #203 on: Sat, 20 December 2014, 15:04:50 »
I would definitely prefer arrows over up down left right. I would put them both in the base kit. It's not really causing much additional bloat. I don't really get the point of having the extra Z Y keys either if you aren't going to have all the rest of keys needed for any of correct German, Swiss, Hungarian, Slovak, Czech, Serbian... it really serves no purpose.
Offline engicoder
« Reply #204 on: Sat, 20 December 2014, 22:55:38 »
I was trying to cover the differences that touched the gradient portion. The majority of the differences fall in the brown zone and includes keys not covered by any group buy. In most group buys the Y and Z can be swapped without consequence. but that is not the case with the gradient.
Maybe these should be part of the ISO kit...and possible add blue 1u <> key as well.
« Reply #205 on: Sun, 21 December 2014, 09:16:41 »
Actually a 30 or so key German/Serbian kit would be kind of sweet. Those 2 layout are most similar and have almost the same numrow if leave off the Alt Gr legends... then just the additional accented letters. I would buy that just to have something different that is usually not available in buys.
Otherwise, yeah putting them in the ISO kit makes more sense.
Offline engicoder
« Reply #206 on: Sun, 21 December 2014, 11:08:38 »
Interesting. I looked at the Wikipedia images of the layouts and did some searching and the German layout seems standardized, but I found a lot of variations for Serbian...some Latin, some Cyrillic. Some ISO, some ANSI. Assuming the ISO as shown in Wikipedia, I made up this sample...
84577-0
I know its not correct yet, so tell me what needs fixing. Thanks
« Last Edit: Sun, 21 December 2014, 11:10:30 by engicoder »
Offline swill
  • builder & enabler
    • swillkb.com
« Reply #207 on: Sun, 21 December 2014, 12:16:26 »
Just want to say that I love how open you are to ideas. You are also super fast to show mockups and hash through ideas which is making this set $%#&@!% awesome.
I am guessing you will need to start a pmk vote soon to get this started as a GB?  Not sure how long that will take, but u suspect we can get through the vote stage pretty quickly with this epicness.
Offline engicoder
« Reply #208 on: Sun, 21 December 2014, 12:37:28 »
Thanks. I see this as a community effort, I'm just acting as coordinator.  Cheesy analogy follows: FingerPunch had the seed, Oobly and I planted it, and the GeekHack community helps nurture it as it grows. Hopefully soon we can all partake of its bounty.
Yes...very soon. I just wanted a few days for everyone to check my work. Also trying to time it so that if it goes to group buy quickly, there will be enough time for people to emerge from their holiday poverty and buy.
« Reply #209 on: Sun, 21 December 2014, 15:29:02 »
Yeah that looks cool. I think safe to go with the current ISO Latin based standard. If it's all uniform profile there is no need for 2  + *  keys.
If other people are even interested in German/Serbian, perhaps roll the GB ISO set in and have a trilingual ISO kit since they would need the ISO return and shift anyway.
« Last Edit: Sun, 21 December 2014, 15:33:12 by IvanIvanovich »
Offline engicoder
« Reply #210 on: Sun, 21 December 2014, 15:48:39 »
I'll remove the extra + * key, thanks.
When you say roll the GB ISO in, do you mean have two ISO options: 1) GB ISO and 2) Trilingaul or just the Trilingual?
« Reply #211 on: Mon, 22 December 2014, 07:58:48 »
Yeah I mean just have one ISO kit with the ISO enter, shift, and the Britain, German and Serbian key all together. If people want the German/Serbian they would have to buy the ISO British set you already had anyway so...
Offline engicoder
« Reply #212 on: Mon, 22 December 2014, 08:57:50 »
That would make the relative small UK set much larger for what is probably a minority. Maybe it makes more sense to have two sets and duplicate those keys in each. That way the UK set would remain as it is, and the German/Serbian kit would have to stand on its own, demand wise.
BTW, I am toying with using a outline/ghost image in these partial sets to show what caps are offered. See the example below, is this a plus, or is it too much clutter? If its a plus, which one...with or without color?
84661-0
« Last Edit: Mon, 22 December 2014, 09:04:03 by engicoder »
« Reply #213 on: Mon, 22 December 2014, 10:41:03 »
Sure that works too. I like the 2nd one style give a reminder of why key is that colors. Looks clear to me what it is.
Offline engicoder
« Reply #214 on: Mon, 22 December 2014, 16:12:36 »
Updated the OP once again with latest images. I'm creating the IC on PMK now. Should be up in the next few days....depending on when SP goes away for the holidays.
Offline goflo
« Reply #215 on: Mon, 22 December 2014, 16:16:31 »
I reeaaaaally would love the german set. That, ergodox and the absolutely gorgeous color scheme would make it a must-buy for my ergodox  :thumb:
- Ergodox Classic/Browns/Grifiti Rests  | - IBM Model M Blue Label |  - Poker II MX Blue | - Ergodox Classic/Blues/Grifiti Rests
Offline Geroximo
« Reply #216 on: Mon, 29 December 2014, 19:18:21 »
Hopefully the teal/yellow/orange/red won't turn out too bright ... a bit of a darker tone would benefit the vintage style.
I'm probably in for at least a Base, Primary Gradient and a German ISO Kit.
Make it happen pls  :thumb:
« Last Edit: Mon, 29 December 2014, 19:25:35 by Geroximo »
Offline engicoder
« Reply #217 on: Mon, 29 December 2014, 21:19:56 »
Here are the colors as they stand as rendered from scans done by Dianoda in this post.
85767-0
Offline engicoder
Re: [IC] 1976 - Flashback to the Colors of the 70's (SA Row 3) (Live on PMK)
« Reply #218 on: Tue, 30 December 2014, 12:37:09 »
The interest check is live on PMK!
Please vote! http://www.pimpmykeyboard.com/deals/1976/
Offline 00zeRO
  • mechanicalkeyboards.com
  • * Commercial Vendor
  • The 00verseer of Vault 77
    • Mechanical Keyboards
« Reply #219 on: Tue, 30 December 2014, 13:28:01 »
Even though the interest check is on PMK, will you be doing the actual GB on there as well, or will you be organizing it on your own like the Rad Hard set? Just curious. I am definitely down for the Base Kit and Alternate Gradient. Right on!  :thumb:
Daily Driver: Typist A w/Midnight Dawn | Kailh BOX Clicks
Junktown 2: Now on eBay!
Offline engicoder
« Reply #220 on: Tue, 30 December 2014, 13:36:35 »
The GB will be run through PMK as well, unless there is a need to do it another way.
Offline 00zeRO
« Reply #221 on: Tue, 30 December 2014, 13:46:19 »
Very cool, SP needs all the support they can get these days. I look forward to certain key personnel returning to their post there so that productivity smooths out...know what I mean?
Offline dimmu
« Reply #222 on: Tue, 30 December 2014, 14:15:55 »
please tell me this comes with a 7x spacebar.
Offline Data
« Reply #223 on: Tue, 30 December 2014, 14:38:53 »
Voted.  I have a feeling this one will be a huge success.
Offline 00zeRO
« Reply #224 on: Tue, 30 December 2014, 14:46:46 »
I am already dreaming of novelties to accommodate this one...SA Row 3 is 'Outta Sight' right now.
« Reply #225 on: Tue, 30 December 2014, 16:04:36 »
I voted. I don't know if I'll have the dollars to afford it, but I'll definitely try my best.
Offline engicoder
« Reply #226 on: Tue, 30 December 2014, 16:21:57 »
The Winkeyless kit includes a 7x spacebar. There will probably be a child deal for extra space bars as singles as well.
Offline dimmu
« Reply #227 on: Tue, 30 December 2014, 16:25:19 »
awesome. im drooling right now.
Offline engicoder
« Reply #228 on: Tue, 30 December 2014, 16:29:49 »
Yes, it will be nice to have Melissa back, but Bob has done well. He always has been prompt in replying to my inquiries. Considering that he is probably covering Melissa's interface work has been in addition to his regular job,  I think Bob has done a great job covering.
Offline meow a cat
  • Resistance is futile.
« Reply #229 on: Tue, 30 December 2014, 17:04:21 »
Voted, this set looks great. I hope it does well!  :thumb:
Definitely in for a TKL and colour kit, and possibly blanks for a JD40.
Boards:
Offline 00zeRO
« Reply #230 on: Tue, 30 December 2014, 17:13:13 »
Actually, Melissa is working from home...
Offline engicoder
« Reply #231 on: Tue, 30 December 2014, 17:59:22 »
Ah..didn't realize that. She really goes the extra mile for everyone.
Offline Moralless
« Reply #232 on: Tue, 30 December 2014, 17:59:39 »
Congrats on all the votes your IC has already accumulated in the short time it has been up on PMK, I'm sure this keyset will be a great success. :thumb:
Just wondering what sized blanks are you planning to offer when the GB goes live?
« Last Edit: Tue, 30 December 2014, 18:02:25 by moralles »
Offline engicoder
« Reply #233 on: Tue, 30 December 2014, 18:10:52 »
1u, 1.5u, and 2u in blue and brown
1u in red, orange and yellow
I'm open to other suggestions.
Offline 00zeRO
« Reply #234 on: Tue, 30 December 2014, 20:27:11 »
JD40 needs 1.25's and 1.75's
Offline engicoder
« Reply #235 on: Tue, 30 December 2014, 20:33:06 »
No problem. I assume these are mods so blue and brown for colors?
Offline engicoder
« Reply #236 on: Tue, 30 December 2014, 20:34:04 »
IC on PMK already hit 100 votes!! That was faster than I expected.
Offline swill
  • builder & enabler
    • swillkb.com
« Reply #237 on: Tue, 30 December 2014, 20:43:30 »
I didn't even realize it was up already. I will vote once I get to a putter. I expect this will be quick to get to mass.
Sorry R5, another little buy is coming to bump you again. :)
Guess I will have to wait longer for my 3 R5 sets. Haha...  I don't mind.
Offline 00zeRO
« Reply #238 on: Tue, 30 December 2014, 21:23:58 »
Most def
Offline 00zeRO
« Reply #239 on: Tue, 30 December 2014, 21:26:04 »
FYI my SA Row 3 relegendables will be coming up right after the current Fallout set.
Offline Streiw
« Reply #240 on: Wed, 31 December 2014, 23:54:17 »
Bob is still doing some of her workload, else I wouldn't have responses indicating such.
Offline goflo
« Reply #241 on: Thu, 01 January 2015, 09:04:13 »
I got an idea for a small change.
I want to use the ergodox kit with the german kit together.
Could you add a yellow "Z" 1U, the german umlauts in the cyan like color ("ö" in 1U, "ü" and "ä" in 1.5U), the "?ß" and "^" in 1,5U to the german set?
Else the colors wouldn't match for the german ergodox users. I know that "we" may be only a small amount of buyers, but it would be nice to have that beautiful set in it's full beauty and not with wrong spots ;)
« Last Edit: Thu, 01 January 2015, 09:45:56 by goflo »
Offline engicoder
« Reply #242 on: Thu, 01 January 2015, 11:44:41 »
There was a comment on PMK asking about JD40 and if it would work....
86029-0
Oh yeah!!
If I add a few caps to the Specialty set, the JD-40 can be populated using the base, gradient and specialty. Not sure about a 40% specific kit.
Offline engicoder
« Reply #243 on: Thu, 01 January 2015, 12:02:12 »
Is this what you mean?
As you said...the number of people looking for this is relatively small, so I'm not sure I want to add it to the German kit. Could possibly add it as its own kit, but I'm not sure it would tip. Feel free to change my mind  :D
« Last Edit: Thu, 01 January 2015, 12:08:11 by engicoder »
Offline goflo
« Reply #244 on: Thu, 01 January 2015, 12:06:56 »
Almost.... The "ö" is right, the "ä" and "ü" need to be 1,5U.
The rest is right.
Hmm, could you set the MOQ for that particular kit rather low? I know the price would get higher, but I'd rather like a higher price than a not tipping part and a uncomplete keyset  :'(
*edit*
You corrected it while I was typing ;)
Offline HendyZone
  • HHKB Elite
    • MechanicalKeyboards.co.id
« Reply #245 on: Thu, 01 January 2015, 12:16:43 »
I like your design sir
Nice touch on the gradient
Hoping for the GB live ;)
Offline engicoder
« Reply #246 on: Thu, 01 January 2015, 12:28:40 »
The rest is right.
*edit*
I guess another option would be to add the to the German kit and bump the Serb/Slav keys to their own kit.
« Reply #247 on: Thu, 01 January 2015, 13:37:00 »
If going to add DOX specific stuff... wouldn't it just make more sense to stick it in there? No one else would have any use for those.
Offline goflo
« Reply #248 on: Thu, 01 January 2015, 13:42:40 »
The problem is....the US or UK Ergodoxer has no use for it either  ;D
I think internationalization is always a problem with those kits, but since engicoder made a special german/slavic kit (which I'm really happy about) I thought it might fit in there.
« Reply #249 on: Thu, 01 January 2015, 13:52:31 »
Maybe add Å Æ Ø +? and § also so can catch the Nordic guys on the EDOX add on too?
