Author Topic: Cherry thick PBT dye-subed worth? vs ABS DS  (Read 4355 times)
Offline Geroximo
« on: Sun, 23 November 2014, 04:25:01 »
Hi guys,
how much are original Cherry thick PBT dye-subed keycaps worth, and how do they compare to original Cherry ABS Double-Shots?
I'm assuming the price-difference is huge, but are the thick PBT dye-subed keycaps worth the extra money?
Best regards
Geroximo
Offline Oobly
Re: Cherry thick PBT dye-subed worth? vs ABS DS
« Reply #1 on: Sun, 23 November 2014, 04:52:13 »
Depends how much you care about how quickly ABS wears smooth. In terms of typing feel and quality I'd say they're similar.
Buying more keycaps,
it really hacks my wallet,
but I must have them.
Offline epzy
  • HHKB Fiend
  • ded
« Reply #2 on: Sun, 23 November 2014, 05:27:56 »
Y e s.
Cherry's PBT is a bit smoother than their ABS, but not by a lot. Between NIB dyesubs and NIB doubleshots there's not a big difference, but obviously the PBT set will hold up much better in the long run because of the material is way more durable.
From my experience, the going rate for ANSI Cherry dyesubs seems to be $300 for mint and $400 for NIB. For ISO  around $60-100 for mint, not sure about NIB.
« Last Edit: Sun, 23 November 2014, 05:29:41 by epzy »
Offline IvanIvanovich
  • Mr. Silk Underwear
« Reply #3 on: Sun, 23 November 2014, 11:41:14 »
Being in Germany, you have a good advantage as finding old Cherry G80/G81-30**SAD boards is often not a problem on German ebay. For example... starting at 1EUR!
« Last Edit: Sun, 23 November 2014, 11:43:11 by IvanIvanovich »
Offline Hypersphere
« Reply #4 on: Sun, 23 November 2014, 11:49:09 »
My overwhelming preference is PBT because of the dry and slightly textured feel. I also like the crispness and longevity of the legends on good-quality dye-sublimated PBT keycaps, such as those on vintage IBM keyboards and current HHKB Pro 2 and Topre Realforce keyboards. Depending on the manufacturer, some of the dye-sub PBT keycap sets can be excellent as well.
Double-shot ABS keycaps also can have beautiful long-lasting legends, but ABS plastic tends to have a clammy feel that I do not like.
Offline Geroximo
« Reply #5 on: Sun, 23 November 2014, 12:22:05 »
Yes that's right, I'm just wondering if I should look for a G80/81 SAD (PBT dye-sub) or a G80/81 HAD (DS ABS)
« Reply #6 on: Sun, 23 November 2014, 12:27:34 »
It's likey you can find either of them for quite cheap. Get both and decide what you like on your own. If it was me, I would try to get at least one of G80 model, so you have a decent board with MX to use with the preferred keycap set.
« Reply #7 on: Sun, 23 November 2014, 12:27:56 »
I prefer DS ABS massively. It's just so much better...
this too
you're allowed to have your own opinion
Offline epzy
  • HHKB Fiend
  • ded
« Reply #8 on: Sun, 23 November 2014, 19:36:25 »
Cherry thick PBT is nothing like IBM, RF or HHKB in terms of feel, btw. Sandpaper vs Smoothness.
Offline Flyersfan1
  • Hi!
« Reply #9 on: Sun, 23 November 2014, 19:45:56 »
How different is BSP and OG Cherry in terms of feel?
Quote from: Photekq
« Reply #10 on: Sun, 23 November 2014, 19:47:53 »
BSP is buttery and Cherry is velvety
Those are the adjectives I use for them, anyway. I usually don't like PBT, but I do like BSP and Cherry.
Offline epzy
  • HHKB Fiend
  • ded
« Reply #11 on: Sun, 23 November 2014, 19:48:30 »
I will make a comparison when I receive my BSP set from imsto. :)
Offline Flyersfan1
  • Hi!
« Reply #12 on: Sun, 23 November 2014, 19:50:13 »
Nice!!! I look forward to it!  :)
Quote from: Photekq
Offline 3Love
  • Bumpino Supremo
  • I want to become a great collector. Greedy!!!
    • https://geekhack.org/index.php?topic=63161.0
« Reply #13 on: Tue, 25 November 2014, 17:17:55 »
Really good touch feeling. I perfect the best touch feeling when I choose keyset.
I♥Keyboard  I♥Clack  I♥Brobot  I♥Hammer
                          I♥♥♥friends
【WTB/WTTF】https://geekhack.org/index.php?topic=63161.0
KBD Collection: 356CL, 356.2, 356DGE, Koala, 356MINI, 356N, 356N-MK2, 356PAD, 360C, 456GT, FMJ, LZ-MXSE, LZ-RE, KMAC 1.0, KPAD, Duck Orion, Duck Pad, Exo, TEX and etc.
