Author Topic: [IC] Slightly pushy Boob or nipple keycap  (Read 16263 times)
Offline Mandolin
  • Crystal Connoisseur
« on: Sun, 23 November 2014, 16:50:17 »
Rigid keycaps are tactile enough?
Materialwise I found out there are some semi rigid polyurethane foams that are actually dense enough to support some wear (I haven't looked coloring). As polyurethanes got a "green stage" where it hasn't polymerized fully, they could chemically bond to a different density version, such as a totally rigid resin, a flexible one or a combination of both. Inlays or macro retentions based on friction are always a alternative too, but this is the real deal of adhesions, no tricks necessary.
One could do the stem in a rigid poly, and a slightly foamy upper part, that gives a little push. I wondered, if there is actual interest to experiment creatively in those regards and offer a foamy keycap on top with a rigid stem.
A high shore hardness silicone could be used also, but I don't know if it's rigid enough to fit the stem and be usable.
Creatively: A boob or nipple on a keycap is what I believe the best subject for the job, but maybe there are another, better ideas that use this capacity fully.
If there is enough interest, I'll test something and post in in the future.
UPDATE
Wanna try? boobiecaps.com
Dedicated thread:https://geekhack.org/index.php?topic=66214.0
« Last Edit: Wed, 17 December 2014, 02:29:01 by Mandolin »
Artisan keycap Maker
Working on
- Custom keycaps
- Artkeycaps V2 sale
- Due chihuahua and demoncat orders
- Boobiecaps
- Optic fiber embedded keycaps
- Others
Offline HPE1000
  • Keycap Paparazzo
Re: [IC] Slightly pushy Boob or nipple keycap
« Reply #1 on: Sun, 23 November 2014, 17:22:15 »
Offline exitfire401
  • The Force is Re/\l
« Reply #2 on: Sun, 23 November 2014, 17:23:40 »
This is without a doubt the weirdest IC I've ever seen
Offline anne
« Reply #3 on: Sun, 23 November 2014, 17:24:07 »
Offline Mandolin
« Reply #4 on: Sun, 23 November 2014, 17:33:22 »
Another example could be a jelly plate or a protruding belly with it's belly button, a tongue clear coated to look slimy, a snail with a rigid shell but a soft body. Anything wobbly.
I'm dead serious about it and I'm gonna do it anyway. I was curious about the public interest in something like it and still need some feedback. Maybe when I have a prototype and some testers if everything goes according to plan. It means a whole lot of different possibilities for keycaps.
I don't want to vary only the colors of the caps, that's boring, there are a bunch of materials to experiment with, (nitinol wires for some heat activated thing, maybe a folded origami inside the body of a keycap made in acrylic, that deploys with heat changes: if the metal is thin enough, the heat of the fingertips is enough to make changes, etc...)
I'm discussing it strictly using descriptive terms, personal appreciations aside, but feel free to express yourselves.
Why not do it now? there isn't a single reason not to. The medium is mature enough.
« Last Edit: Sun, 23 November 2014, 18:08:56 by Mandolin »
Working on
- Custom keycaps
- Boobiecaps
- Others
Offline geogga
  • gosh dang GH and their GBs
« Reply #5 on: Sun, 23 November 2014, 17:44:56 »
Offline Parak
Offline Mandolin
« Reply #7 on: Sun, 23 November 2014, 17:56:02 »
Ding ding ding  ;D
Working on
- Custom keycaps
- Boobiecaps
- Others
Offline Techpriest
« Reply #8 on: Sun, 23 November 2014, 19:05:31 »
I'll be the odd man out here, I think this sounds cool.  Any chance of multiple colors?  Would be cool to do a rainbow set on the function keys.  Would also be interested in the belly with belly button, eyeball, brain, perhaps a nose.  It would make sort of a hilarious keyset.  Even if you only do the run of the boob and nipple, I'll buy a set of each.
Another idea, any thoughts on making an additional jelly ball keycap set?  I've kind of wanted something like it ever since seeing the keyboards in Prometheus.
Thanks,
Techpriest
Offline Mandolin
« Reply #9 on: Sun, 23 November 2014, 19:18:14 »
Thanks,
Techpriest
Yes, yes, yes: brain with real veins and arteries locations! nose cap with embedded or individually punched real hairs, eyeballs with variable pupil dilatation made from old lenses diaphragms, belly cap with skin folds and stretch marks, maybe a cushing syndrome belly...
It's about what can you do with it what's most exciting. No transparent version. The foam should be tinted or painted over. The flex won't allow clear coating the foam ibecause it'll crack, but with solid colors you'd have many options, combining it with flexible or rigid polyurethane resins that could be treated differently. It's those three elements that'll be theoretically mixable, foams, flexible and rigid PU resins.
I could also make a skull or face with a jaw hanging from the lowest border of the superior surface (so it won't interfere as much with typing), and use a foam or flexible PU on the jaw articulation, and it should wobble when pressed. If you got different flexure speeds, there is the possibility to coordinate them to achieve effects as muscles contracting for instance. One could do a keycap with hidden hands that stretch out when pressed! It's so cool.
I'm not familiar with prometheus keyboard :(
« Last Edit: Sun, 23 November 2014, 19:39:03 by Mandolin »
Working on
- Custom keycaps
- Boobiecaps
- Others
Offline Techpriest
« Reply #10 on: Sun, 23 November 2014, 21:11:17 »
Have you thought of using silicone resin?
Offline Mandolin
« Reply #11 on: Sun, 23 November 2014, 21:20:18 »
I'm not familiar with all of its presentations, manipulation and availability. I only know the emulsion used as a lubrication agent, silly putty and two part adhesive agent like sugru.
Do you have streamlined info? or could you make a brief list of what is good for? It's mixable with another resins as a filler? reactivity? toxicity? It's safe to work with with non sofisticated lab equipment?
Working on
- Custom keycaps
- Boobiecaps
- Others
Offline Evo_Spec
  • (╯°ヮ°)╯︵⌨
« Reply #12 on: Sun, 23 November 2014, 22:38:54 »
Mark me as interested! i'd love a boobiecap!
GON NerD TKL DTA Edition
Offline Coreda
« Reply #13 on: Sun, 23 November 2014, 22:52:02 »
Sooner or later this was going to happen.
Offline ConscienceDrop
  • a-are these pbt?
« Reply #14 on: Sun, 23 November 2014, 23:13:02 »
god speed sir.
it was a long dark night, but i see the sun starting to rise for keyboard lovers.
i dream of a day when all my fingers can type on boobs
Offline tribade
« Reply #15 on: Sun, 23 November 2014, 23:14:56 »
I...actually really like this idea. Count me interested.  :))
KMAC mini w/ blacks | Realforce 87uw 55g w/ Digil0g case | KMAC w/ blacks | Duck Viper w/ clears
"Te occidere possunt sed te edere non possunt nefas est."
Offline Mandolin
« Reply #16 on: Sun, 23 November 2014, 23:33:23 »
 :D. There are a lot of options to explore, one could include little soft clip on (or attached via magnet) bras between keys, one boob, two boobs, tri boobs per key, different anatomic characteristics, historical/famous figure profile, etc, etc.
That was the kind of glorious response I was looking for.
I'll send a PM to the ones that manifested their interest when the time comes. I'll need some testers once they are ready. I prefer people that could speak freely publicly, but I'm open to communicate privately (and for the future sales too).
« Last Edit: Mon, 24 November 2014, 05:05:13 by Mandolin »
Working on
- Custom keycaps
- Boobiecaps
- Others
Offline Evo_Spec
  • (╯°ヮ°)╯︵⌨
« Reply #17 on: Sun, 23 November 2014, 23:56:33 »
:D. There are a lot of options to explore, one could include little soft clip on (or attached via magnet) bras between keys, one boob, two boobs, tri boobs per key, different anatomic characteristics, etc, etc.
Count me in! Although i'm in Japan so that might change things but if you're still willing to count me in i'll buy a boob mousepad to match.
  • a-are these pbt?
« Reply #18 on: Mon, 24 November 2014, 00:40:09 »
These probably exist there already. . .
Offline Heliosphere
« Reply #19 on: Mon, 24 November 2014, 01:29:09 »
Isn't this basically an idea for (literal) rubber dome keycaps? I'm intrigued.
Offline Mandolin
« Reply #20 on: Mon, 24 November 2014, 04:48:14 »
Not really. The rubber dome keycaps are rigid PBT, ABS or POM plastic caps, not PU or epoxy resin, nor foam. The plastic dome is flexible, but acts as a switch itself with two positions. There's not enough "push" with cheap plastic used in the rubber membrane.
I'm talking about varying the degree of flexibility inside each cap. A rigid base for the stem and lowest cross section in the body of the keycap and a foamy cushion and/or a flexible PU resin on the rest of the body, all chemically bonded, no gaps in between: just one solid piece cap
Furthermore keycaps made of hard silicone can be made using the same method, with a rigid silicone for the stem/base of the body and a more elastic mix in the upper part. Chemically bonds are supposedly covalent.
« Last Edit: Tue, 25 November 2014, 10:09:12 by Mandolin »
Working on
- Custom keycaps
- Boobiecaps
- Others
Offline Evo_Spec
  • (╯°ヮ°)╯︵⌨
« Reply #21 on: Mon, 24 November 2014, 04:55:51 »
I'm not in Tokyo so i can't go to "weird central" Akihabara to check =/
Offline Razor Lotus
« Reply #22 on: Tue, 25 November 2014, 14:48:40 »
Would love to see a full boob setup
Offline Evo_Spec
  • (╯°ヮ°)╯︵⌨
« Reply #23 on: Tue, 25 November 2014, 15:12:11 »
I could definately try, i'm not too sure how far i could bring this, i could get my GF to crochet some boob plushies and maybe make some kind a wrist rest thing and if it's not too expensive i think i saw some place with boob cups too lol
Offline GL1TCH3D
« Reply #24 on: Tue, 25 November 2014, 15:15:18 »
Going to read up more on these! Sounds unique and would make great gag gifts for those keyboarders!
Offline HydraDyne
« Reply #25 on: Wed, 26 November 2014, 03:18:17 »
Could we have a full DVORAK key set? I think that would be fantastic.......
Offline Evo_Spec
  • (╯°ヮ°)╯︵⌨
« Reply #26 on: Wed, 26 November 2014, 03:21:15 »
It'll be a full BoobOrRack key set  :))
Offline PunksDead
  • hspernks
  • keyboard poser
« Reply #27 on: Wed, 26 November 2014, 04:14:09 »
Can i get a set of hairy boys to hang off my keyboard?
Offline Evo_Spec
  • (╯°ヮ°)╯︵⌨
« Reply #28 on: Wed, 26 November 2014, 05:09:28 »
Close enough?
Offline Mandolin
« Reply #29 on: Sun, 30 November 2014, 19:57:55 »
Preorders open: http://boobiecaps.com
« Last Edit: Wed, 17 December 2014, 02:28:30 by Mandolin »
Working on
- Custom keycaps
- Boobiecaps
- Others
Offline Evo_Spec
  • (╯°ヮ°)╯︵⌨
« Reply #30 on: Sun, 30 November 2014, 20:20:59 »
Boobiecap preorders, it ends on december 7th http://goo.gl/forms/llTBIx7PTm
Great idea on doing it in pairs! i have to apologize cause it caught me at a bad time since i just blew all my money on hot keys....
Offline Mandolin
« Reply #31 on: Sun, 30 November 2014, 20:28:45 »
One for you and another to gift!.
Don't worry, I'll make them anyway, only this preorder would allow me to do it faster. If there isn't public interest, I'll have them ready in mid 2015.
There's much to do and it'll be a process of improvements. You could hop in at any time.
Interest has been cleared as positive, so I created a dedicated thread to discuss it further.
[#Boobiecap project]: https://geekhack.org/index.php?topic=66214.0
« Last Edit: Sun, 30 November 2014, 20:49:11 by Mandolin »
Working on
- Custom keycaps
- Boobiecaps
- Others
