Author Topic: Model AT F Problem  (Read 1250 times)
Offline terrpn
  • Alpha Geezer
  • - Buy Vintage -
Model AT F Problem
« on: Mon, 24 November 2014, 11:01:52 »
When I received my AT F I took it mostly apart, cleaned, reassembled and everything worked fine
Now the o/O key is not registering? I can see the spring keeps popping off the hammer, however when I replace the spring back on the nipple and just press the spring without the cap on it just starts registering oooooooooooooooooooooooo............
If I put the cap back on even with the spring seated back properly on the hammer I get nothing.
Do I just need to swap out the hammer maybe or do I do something else?
Luga G80-1865/MX Reds + Dolch G80-1813/MX Blues + G80-3700HQAUS + DK9008G2 Pro/MX Browns Thick PBT + DK9008G2 Pro/MX Clears Thick PBT +  QFR TKL/Ghetto Greens + Cherry G80-1800/MX Blues + IBM Model M SSK Bolt Modded + IBM Model M + IBM Model F + IBM AT F + Cherry G80-1000 (HAD)/MX Vintage Blacks + Razer BWU/MX Blues + Leading Edge DC2214/Blue Alps + Compaq MX11800/Browns + Chicony 5181/Monterey Blues + Chicony 5161/MX Black Cherry Clone + Focus 2001/White Alps + Chicony 5191/White Futabas + Olivetti ANK27-101 + Dell (Old Logo) AT101/Black Alps + NMB RT8255C+/Black Space Invaders + Unitek K260/Green Alps + Apple M0116/Orange Alps + AEK II M3501/Cream Alps + AEK M0115/Orange Alps + NEC  APC412/Blue Sliders + NEC APC410/Blue Sliders + Omnikey /White Alps + Wang/Yellow Alps (Omrons) + Laser/White SMK + Fame/Blue Aruz + AEK II M3501/Salmon Alps + Zenith ZKB-2R/Green Alps + Wang 724/Orange Alps + DK1087/Green Alps + Zenith ZKB-2/Yellow Alps + Dell Old Logo AT101/Salmon-Pink Alps + Leading Edge AK1012/White SMK's + Magitronic SK-1030/White (Linear) Futaba's + Packard Bell/White (Clicky) Futaba's + Datacomp DFK101/White  Alps + SGI AT101/Dampened White Alps + NMB AQ6RT-72511/Grey Space Invaders (Hi-Tek) + Datacomp/Blue Alps + Phillips 2812/White Space Invaders (Linear) + Dah Yang K251/Vintage MX Blues + Chicony 5161/DS Caps/Vintage MX Blue + Archie-NMB AQ659ZRT-725/Black Space Invader (Tactile) + IBM Model M 71G4644 (RD) Bolt Modded with Soarers Converter + IBM Model M Silver Label 1390131 + Cherry G80-1501/Vintage MX Clears + Focus FK8000/Linear Futabas + Gateway 2000 Anykey Programmable/Maxi-Switch + Dell GY13PVAT101/Dye Sub Caps/Salmon Alps + Chicony 5161/White Alps + AST K0B101/Slider over RD + Qtronix QX-32H + Everex/NMB RT8255CW+ Black Space Invaders-Split Erase + Tandon/NMB AQ659ZRT-101A/Beige Space Invaders + Cherry G80-11903 MNRUS/MX Blacks + Apple IIGS A9M0330/SMK Whites + WYSE PCE/MX Blacks + Chicony 5160AXT/Clicky Futaba + Cherry G80-0528/Vintage MX Blacks + Dell AT101/Linear (Modded) Black Alps+Topre 55g
Offline Parak
Re: Model AT F Problem
« Reply #1 on: Mon, 24 November 2014, 11:33:23 »
Make sure that the flippy moves freely when inside the barrel and is not jammed against the barrel somehow. In addition, the spring must be firmly seated on the flippy all the way to the base - if it keeps popping off, then it's not on there firmly enough. The tension of the keycap compressing the spring causes the flippy to rise off of the pcb and break the capacitive sense, so if that's not happening you'll keep seeing the key being pressed.
