Author Topic: Happy Hacking manual?  (Read 6159 times)
Offline scott62185
« on: Mon, 24 November 2014, 20:10:36 »
Hello, I just got a new HHKB(!) and being somewhat of a keyboard newb, I don't know how to change the DIP switches (or anything else) on this bad boy. Can one of you keyboard aficionados help me out by pointing me in the direction of some information for the HHKB 2? Thanks!
Offline jwaz
  • * based mod
  • #geekhack on freenode
Re: Happy Hacking manual?
« Reply #1 on: Mon, 24 November 2014, 20:15:22 »
https://elitekeyboards.com/products.php?sub=pfu_keyboards,hhkbpro2&pid=pdkb400b
It's on the product page, just scroll down.
If you want to customize your layout more than the dip switches allow check out Hasu's alternative controller:
https://geekhack.org/index.php?topic=56494.0
Offline scott62185
« Reply #2 on: Mon, 24 November 2014, 20:22:18 »
Great! Thanks a lot!
Offline scott62185
« Reply #3 on: Mon, 24 November 2014, 20:26:33 »
Another thing, what is "lite mode?"
« Reply #4 on: Mon, 24 November 2014, 20:38:51 »
A conventional membrane keyboard.  Similar lay to the HHKB 2 Pro, but with arrow keys.  NOT a Topre keyboard.
« Reply #5 on: Mon, 24 November 2014, 20:51:07 »
TIL turning a dip switch completely changes your keyboard's switches.
SW1   SW2   Keyboard Mode
OFF   OFF   HHKB Mode
ON   OFF   Lite Mode
OFF   ON   Macintosh Mode
ON   ON   N/A
Offline Sturmfrau
« Reply #6 on: Mon, 24 November 2014, 21:03:42 »
Hmmm that controller looks nice but I don't see the usb ports on it or it really doesn't have it?
HHKB Pro 2 Black (Blank) | HHKB Pro 2 White (Blank)
Offline scott62185
« Reply #7 on: Mon, 24 November 2014, 21:21:20 »
No, I mean, if you put switch 1 on and 2 off it puts the HHKB into "lite mode." I'm not sure what that is...
« Reply #8 on: Mon, 24 November 2014, 21:29:19 »
Ah that, sorry, not really concentrating while I'm working.
http://www.linuxjournal.com/article/8361
"The SW1 and SW2 DIP switches select among three modes: default or HHK mode, HHK Lite mode and Macintosh mode. The only difference between the default mode and HHK Lite mode is some additional key combinations become available in HHK Lite mode. For example, you cannot use the Fn-Tab combination for Caps Lock in default mode; HHK Lite mode enables it. I can see no reason why anyone would prefer the default mode to the HHK Lite mode, and I recommend you use HHK Lite mode if you use an HHKB Pro keyboard."
