Author Topic: i think i like the FC660C more than the 87UW 55g - am i crazy?  (Read 1889 times)
Offline skuko
« on: Mon, 24 November 2014, 23:02:31 »
seems that the leopold has more "thock" than the realforce, which i honestly find very weird :X am i crazy or something?
i think it's due to the fact, that the leo has a smaller plate, so the sound is a bit mure muffled. also, i think i like the 45g better. they're a bit less snappier than the realforce, but they're also a little lighter, which i like (previously used MX reds almost exclusively).
i think i will keep the leo for home and use the 55g RF at work for some time and let it sink in a bit. if i don't really like it, there may be a RF available int he EU for less than what keyboardco charges :D
Re: i think i like the FC660C more than the 87UW 55g - am i crazy?
« Reply #1 on: Mon, 24 November 2014, 23:14:56 »
yes. you are crazy.
55g is best topre switch. 55g RF is best ever.
Offline slickmamba
« Reply #2 on: Tue, 25 November 2014, 00:02:36 »
If you like snappy, the novatouch has the snappiest topre I've used (hhkb, 87ub, 660c)
Hi :)
Offline exitfire401
  • The Force is Re/\l
« Reply #3 on: Tue, 25 November 2014, 00:04:02 »
This. It's almost snappier than 55g.
Offline skuko
« Reply #4 on: Tue, 25 November 2014, 02:29:30 »
it's not like a i need more snappy than the leopold already is, the keys on the leo just feel a bit softer and "thockier" to me than the RF.
i think it might just be a case of me preferring the 45g topre to 55g. :O
Offline Matt3o
  • -[°_°]-
  • ** Robot Emeritus
« Reply #5 on: Tue, 25 November 2014, 02:54:26 »
no, you are not crazy. The leo 660C it's in incredibly fine keyboard, and my daily driver, but I put 55g domes on it.
Offline Peinful
« Reply #6 on: Tue, 25 November 2014, 03:20:38 »
Yes, yes you are crazy
Offline byker
  • Literally Canada
« Reply #7 on: Tue, 25 November 2014, 03:22:38 »
Now you folks have me wanting to try a novatouch...  >:D
