Author Topic: Tex aluminum 60% cases  (Read 17199 times)
Offline Barracuda
« on: Tue, 25 November 2014, 19:07:52 »
I just saw thst you guys have restocked on the tex aluminum 60% cases, but I have some questions.
1. Are these the old version (with front lip)  or the new version (like those from massdrop, without a front lip)?
2. Do they come with aluminum feet, or with pre-installed screwholes for aluminum feet (so you could add them yourself) ?
Thx,
Barracuda
Looking for a matte Blackout V2!
Offline SavvyBird
  • Savvy Caps
Re: Tex aluminum 60% cases
« Reply #1 on: Tue, 25 November 2014, 19:23:50 »
OMG they're in stock :D
purple or orange  :-X
my money why ...
hi
Offline rpeterclark
  • RPTR ❌
« Reply #2 on: Tue, 25 November 2014, 21:01:29 »
I emailed them and customer service guy Justin Sweet responded " Yes, it does feature the thick front design." He didn't respond about the feet though.
Offline JoshMK
  • * Commercial Vendor
  • MechanicalKeyboards.com
« Reply #3 on: Wed, 26 November 2014, 09:34:00 »
Rubber feet. Pictures on website are accurate.
Josh McConnell
Josh@mechanicalkeyboards.com
615.266.1420 ext303
Offline 00zeRO
  • mechanicalkeyboards.com
  • * Moderator
  • The 00verseer of Vault 77
    • Mechanical Keyboards
« Reply #4 on: Wed, 26 November 2014, 10:32:02 »
Swing and a miss on my part...sorry I missed that question. I'm burned...
Daily Driver: Typist A w/Midnight Dawn | Kailh BOX Clicks
Junktown 2: Now on eBay!
Offline darkiedark
« Reply #5 on: Sat, 06 December 2014, 14:15:39 »
Any way we can get the aluminum feet?
Offline heedpantsnow
  • Old enough to know better
« Reply #6 on: Sat, 06 December 2014, 14:35:39 »
I tried a while back. In the end I had to order them from Korea and decided to go a different route: plastic ball that separates into hemispheres and velcros onto the bottom of my case.
I'm back.
Offline darkiedark
« Reply #7 on: Tue, 09 December 2014, 17:04:33 »
Well that's slightly annoying considering the Massdrop cases came with the feet. Where did you find them from Korea? Was it from GON?
http://www.gonskeyboardworks.com/housings-and-related-parts/19-aluminium-legs.html#/color_of_al_legs-other_colorsextra_lead_time_and_charge
« Reply #8 on: Tue, 09 December 2014, 19:08:07 »
Yep I think it was. If you went that route you will have to drill and tap your case yourself if it doesn't already have holes. I have an m4 tap but no m2 which is probably the screws they use. :-/
I'm back.
Offline Rodgaroon
  • Size matters, just ask my wife.
« Reply #9 on: Tue, 16 December 2014, 14:55:38 »
If you can find a case with feet i highly recommend it. I have them and it is perfectly balanced. love the TEX i got off massdrop.
G6v2 (MX Black) | Poker II (MX Brown) | Compact SQ (MX Clears 62g)
« Reply #10 on: Tue, 16 December 2014, 22:27:20 »
Barracuda what did you decide to do?  If you order some of GON's feet, let's go in together and maybe save on shipping.
I'm back.
Offline darkiedark
« Reply #11 on: Wed, 17 December 2014, 17:02:13 »
I got my case from mechanicalkeyboards and you were right. The new revision doesn't have the holes tapped out :c.
Offline Barracuda
« Reply #12 on: Wed, 17 December 2014, 17:33:25 »
I decided to get them without the aluminum feet. I'm not planning on buying the feet,  since that  would mean that I have to drill the holes for the feet myself, and I'm not that confident in my ability to drill on a 100usd piece of aluminum ;)
