Author Topic: Help me find 1.75u and 7u Spacebar for BSP Classic Beige  (Read 4757 times)
Offline Sygaldry
  • Edema Ruh
« on: Tue, 25 November 2014, 20:45:20 »
I'm looking for something in Classic Beige to match the BSP Classic Beige set. Anyone have an ideas for where I should be looking?
(It seems the only choice I have for spacebar would be to find a Cherry Profile GMK 7u spacebar) but I'm stumped as to where to find a 1.75u Right Shift.
null
Re: Help me find 1.75u and 7u Spacebar for BSP Classic Beige
« Reply #1 on: Tue, 25 November 2014, 20:46:39 »
BSP is only 7u spacebars IIRC
Offline Sygaldry
  • Edema Ruh
« Reply #2 on: Tue, 25 November 2014, 21:05:25 »
I just ordered from Originative (fingers crossed) and the set doesn't include the spacebar  :confused:
null
« Reply #3 on: Tue, 25 November 2014, 22:58:34 »
RIP
PM IMSTO
he'll have what you need
Offline intelli78
« Reply #4 on: Tue, 25 November 2014, 23:29:29 »
RIP
PM IMSTO
That for 7x ABS, or, get 7x PBT from Compaq MX11800.
As far as I know there is no 1.75x PBT right shift. You'll need a DS ABS one from a G8*-1800. Alternatively, get ahold of an RGB pack.
Offline blighty
« Reply #5 on: Wed, 26 November 2014, 01:29:02 »
You can find 1.75 PBT shift keys on G81-1800 boards.  They are lasered, but it's better than nothing.  They were easy to find on ebay at one point (I currently use one on my sprit MX-mini with a g80 pbt set with an ABS 7u space from a beige set since the 7u space that came with my pbt set had melted stems somehow).  You could get lucky on taobao.com (http://item.taobao.com/item.htm?spm=a230r.1.14.15.YulkqR&id=16620743597&ns=1&abbucket=11#detail  notice the 1.75 shift on the left instead of the right side, and it's an ABS set), but that's a crap shoot.
edit: found pic i posted in another thread of shift key
82703-0
« Last Edit: Wed, 26 November 2014, 01:42:50 by blighty »
LZ ergo (MX silent red) | JER - A06 (MX silent black-red springs) | Duck Lightsaver V2 (MX red) | Duck Octagon V2 (gateron clear) (lifted pads) | Duck Orion V2 (gateron red) | TKC 1800 (gateron silent reds) | Mistel MD770 (MX red with GMK silencing clips) | Realforce R2TSLA-US4-IV | Realforce R2TLSA-US4-BK | TX 75 (gateron clear) | KBDFANS 75 ("vintage" MX blues) | Kinesis Freestyle Pro (MX red) | MS Surface Ergonomic | MS Natural Ergonomic Keyboard 4000 | Filco Majestouch 2 TKL (MX black) | Phantom (Filco case) ("vintage" MX blacks | Spr1t 75% PCB x 2 (MX black and gateron clear) | Cherry G80-1865 (MX browns with black springs)
Offline intelli78
« Reply #6 on: Wed, 26 November 2014, 01:33:15 »
in my opinion, lasered caps look like ass next to dyesubs and doubleshots, but to each his own.
Offline blighty
« Reply #7 on: Wed, 26 November 2014, 01:40:52 »
I like the uniform feel of the caps on the board, but yeah, they could look better.  It amuses me to have it looking beat up i suppose, given that it's in a keycool case with un-uniform looking keys.
Offline IvanIvanovich
  • Mr. Silk Underwear
« Reply #8 on: Wed, 26 November 2014, 11:09:40 »
As blighty suggests 1800 with lasered PBTs, it's pretty much the only option if you want something that is going to be the same material and more or less the same shade of beige in Cherry profile. Cherry boards with PBT winkeyless is pretty much the only place to get Cherry profile PBT 7x spacebar as well.
Offline Sygaldry
  • Edema Ruh
« Reply #9 on: Wed, 26 November 2014, 13:16:09 »
Are those the point of sales boards?
null
Offline Sygaldry
  • Edema Ruh
« Reply #10 on: Wed, 26 November 2014, 15:34:22 »
Just an update:
My Otaku Classic Beige shipped this morning from Originative!
Also, picked up a Brand New in Box Cherry G81-1800 in Two-Tone Beige/Grey (Winkeyless version with 7u Spacebar and 1.75u Right shift).
Can't wait to get these in the mail!!!
« Last Edit: Wed, 26 November 2014, 16:09:14 by Sygaldry »
null
Offline berserkfan
« Reply #11 on: Thu, 27 November 2014, 20:59:27 »
Wait a moment, did you check with the experts if a G81 board shift and spacebar can fit? Isn't it an oft repeated wisdom that MY boards (G81s) have weirdly placed stabilizers and only 1u keys are compatible?
Offline Sygaldry
  • Edema Ruh
« Reply #12 on: Thu, 27 November 2014, 21:02:19 »
We'll see when the board gets here! I only need 2 keys from the board (the 7u Spacebar and the 1.75u Right Shift) so if the stabilizers aren't right, I can just harvest stems from the keys that I don't need (maybe from my keyswitch tester caps) and use Blu-Tack to make them work  :thumb:
null
« Reply #13 on: Fri, 28 November 2014, 12:46:35 »
Shouldn't be an issue... 1.75 isn't stabilized anyway and 7x with those inbuilt stab wire clips I've only seen once. Besides more recently made boards that have the inbuilt stab wire clips that can't work with Cherry stabilizers on MX, the only other issue is with 1.25 B row which are offset. Everything else is identical to MX.
Always hope you don't end up with those...
« Last Edit: Fri, 28 November 2014, 12:50:20 by IvanIvanovich »
