Author Topic: My Keycaps Get Stuck--What to Do?  (Read 12115 times)
Offline notsonerd
  • Here for the secrets
  • Light My Fire
« on: Wed, 26 November 2014, 09:39:20 »
I recently received a set of PBT keycaps and installed them only to find that my Left Shift and Capslock actuate at the same time when I press Left Shift. I've paired each with different keycaps with no problems--it only happens when I use these two keycaps from the same set. I was thinking maybe the base of the keycaps are just slightly "taller" in a sense that they get stuck together when I press Left Shift down? I'm not sure if taking a pair of pliers and squeezing them slightly would be a good idea. Anyone else have this problem?
KBParadise V60 with Cherry MX Browns | Corsair K60 with Cherry MX Reds
Re: My Keycaps Get Stuck--What to Do?
« Reply #1 on: Wed, 26 November 2014, 12:07:12 »
What board?
Offline notsonerd
  • Light My Fire
« Reply #2 on: Wed, 26 November 2014, 12:08:38 »
KBP V60.
« Reply #3 on: Wed, 26 November 2014, 15:07:51 »
Can you see or hear the base of the keycaps rubbing together?
It might be a switch that is out of alignment by a fraction of a millimetre, plus maybe a little bit of flash along the bottom edge of the keycap.
If they are rubbing, you could get a sharp blade and take a very little bit off the bottom edge of one of the keycaps.
Offline notsonerd
  • Light My Fire
« Reply #4 on: Wed, 26 November 2014, 16:01:18 »
I'm pretty sure they are rubbing together. There's almost no space in between the keycaps when looking at the board from above. I didn't consider that it might be a switch that's the problem.
Not sure how I feel about performing keycap surgery.
Offline berserkfan
« Reply #5 on: Fri, 28 November 2014, 10:25:34 »
It's harmless. I assure you that many people, including me, have done it. You only need to pare off or sand down a bit of keycap plastic. Nothing dangerous. If you want to be a geekhacker, that's the kind of thing you can't run away from!
Offline notsonerd
  • Light My Fire
« Reply #6 on: Mon, 01 December 2014, 02:43:33 »
Welp--I finally summoned up the balls to do it. Rather, I got off my lazy ass after the last straw with the issue and took thirty seconds to shave off some of the base of both keycaps and--lo and behold--they no longer get stuck. Very happy with this simple and easy fix and, however minimal the act was, I feel that much closer to being a Geekhacker. Pretty satisfying feeling. Maybe I'll ruin my next board by trying to solder LED's onto it.
Nah.
« Reply #7 on: Mon, 01 December 2014, 15:17:23 »
Nah.
Congratulations on your first mod :)
Start small, work up to big.  With a little care and attention to detail, nearly everything is possible.
Offline berserkfan
« Reply #8 on: Sun, 07 December 2014, 01:34:19 »
Just you wait, in 5 years notsonerd will be doing group production runs for Datahand III or some mouse controlled by blinking your eyes.
Offline notsonerd
  • Light My Fire
« Reply #9 on: Sun, 07 December 2014, 16:19:31 »
If only xD
