Author Topic: IBM Keycap Dyeing (Golden Yellow)  (Read 12939 times)
Offline babuinix
« on: Wed, 26 November 2014, 17:38:27 »
« Last Edit: Wed, 26 November 2014, 17:40:55 by babuinix »
i5 3470//GSKILL 8GB RIPJAW X//SEAGATE 1TB//XFX 550W//MSI GTX660 TF OC 2G
Re: IBM Keycap Dyeing (Golden Yellow)
« Reply #1 on: Wed, 26 November 2014, 18:40:58 »
Very nicely done!
:thumb: :cool: :D
Offline hwood34
  • underwater squad
  • #1 CL stan
    • Keyboard Illuminati
« Reply #2 on: Thu, 27 November 2014, 10:56:03 »
Wow, that's a really nice shade of yellow, the dye really soaked in well and evenly. GJ :thumb:
Were you using iDye poly?
Offline babuinix
« Reply #3 on: Thu, 27 November 2014, 15:36:44 »
Thanks all, I used Dylon Dye and this session toke arround 4/5 hours because I think  I used too much water for the quantity of color powder used!
Still turned out well, next step is to plastic dip the case mate black/dark grey
Full Album here : http://imgur.com/a/wp0DV
« Last Edit: Thu, 27 November 2014, 15:38:20 by babuinix »
Offline katushkin
  • Too Keycool for School
  • Just the guy
« Reply #4 on: Thu, 27 November 2014, 15:53:57 »
Interesting how the modifiers ended up a much darker colour than the rest of them...
« Reply #5 on: Thu, 27 November 2014, 15:56:51 »
Not really, when you consider that they started out darker anyway.
Offline FrostyToast
  • Litshoard
« Reply #6 on: Thu, 27 November 2014, 16:06:48 »
Now you just need 2 gold checkkeys for homing!  :thumb:
Quote from: elton5354
Offline berserkfan
« Reply #7 on: Fri, 28 November 2014, 07:07:38 »
Very simple, use 500ml not 1+ litre or whatever the instructions say. The more water, the more time wasted and the color density will be lower/ less vibrant colors.
I did exactly the same thing and got the same colors. Took 5 minutes of boiling, after which I left them to cool and did other things.
Offline babuinix
« Reply #8 on: Fri, 28 November 2014, 18:40:44 »
The reason I used so much water was because last time it evaporated so much that I ended up having trouble keeping all the keys submerged, I thi ALL the keys at the same time, but yeah I should have used les water, still 5 minutes is not enough, at least 1/2 hours, I toke 5 hours because I would do baths of 15 minutes after boil and then take them off and put in the fridge, boil the mixture again and so on and so on!
Offline katushkin
  • Just the guy
« Reply #9 on: Fri, 28 November 2014, 19:12:46 »
Derp, of course. I'm stupid.
Offline berserkfan
« Reply #10 on: Fri, 28 November 2014, 19:48:57 »
[/quote]
Really don't think you need to use the fridge... never used the fridge, and I have dyed many times.
People who have bought my dyed stuff include Henz and Moemoe666; they can tell you if the dyeing had any problems.
Offline luisbg
« Reply #11 on: Sun, 30 November 2014, 09:42:26 »
How much did the dye pack cost?
Leopold FC660M - Brown mx switches - black case - white blank keys :: ErgoDox - Blue mx switches - classic case - black blank keys
Offline babuinix
« Reply #12 on: Mon, 01 December 2014, 05:23:11 »
5 Bucks
Offline luisbg
« Reply #13 on: Mon, 01 December 2014, 05:58:06 »
5 Bucks
Really cool! Tempted to do this myself.
« Reply #14 on: Mon, 01 December 2014, 08:43:07 »
This link should be in all of these.
Check reply #14
https://geekhack.org/index.php?topic=35444.msg658453#msg658453
- D Trump 2026-10-24
Offline berserkfan
« Reply #15 on: Mon, 01 December 2014, 08:51:08 »
5 Bucks
FOhat has a valid concern; RIT is available in North America; Dylon in Asia and Europe. They don't work exactly the same way.
Best if you are uncertain is to have some European buy the dye with proven utility for you.
