Author Topic: Ione Scorpius M10 owners - question for you (key heights)  (Read 2862 times)
Offline Special K
« on: Sat, 25 July 2009, 12:27:52 »
I made a post about this in another unrelated thread, but since it is starting to bother me I thought I'd make a dedicated post:
I recently got an M10 and noticed that different keys are different heights, but there doesn't seem to be much rhyme or reason to it.  Here are some strange discrepancies I have noticed:
1. The row of keys with ZXCV is raised up higher than the row of keys with the spacebar, but the left shift key is raised up higher than any other key in its row. The right shift key isn't raised up any higher than any other key in its row.
2. The delete, end, and page down keys are set so low that the tops of the keys are almost flush with the case of the keyboard.
3. The F1 key is set slightly higher than F2, F3, and F4.
4. The left CTRL key is set lower than any other key in its row (including the right CTRL key).
Does anyone else have this problem with their M10?  I tried pressing down on keys to make sure they were on all the way, but none of the keys budged so I assume they were on tight.  Are these height differences deliberate or a result of very poor QC? Either way, I don't like them. I don't mind if each row is a little bit higher than the previous one (i.e. the AT101W or Model M) but making individual keys in a row higher than others is messed up.
Filco FKBN104MC/EB
Filco FKBN104M/EB2
IBM Model M 1391401 - 11/13/87
Quote from: ripster
LOL - we're on post #163 of this mega-thread and you've gone from"keyboard n00b" to "keyboard sn0b".  We've done our job.
Offline Special K
« Reply #1 on: Sat, 25 July 2009, 13:00:54 »
Quote from: ripster;104336
Ugh - that sounds strange since you would think plastic molds should be consistent unless they messed up the X well the key fits into.
One other check - have you tried removing the keys and putting a straightedge across the switch tops?
Unfortunately the blank Filcos won't fit the M10 either (at least some of the bottom row keys).
Good idea - I need to get a key puller though.
Filco FKBN104MC/EB
Filco FKBN104M/EB2
Quote from: ripster
Offline Special K
« Reply #2 on: Sat, 25 July 2009, 13:04:24 »
Quote from: ripster;104340
With the number of keyboards you're collecting a key puller would be a good idea.  Buy two, I'm always misplacing one.  Elitekeyboards seems to be the cheapest place right now.
Do you need 2 key pullers to remove the spacebar and other large keys?
Filco FKBN104MC/EB
Filco FKBN104M/EB2
Quote from: ripster
Offline Special K
« Reply #3 on: Sat, 25 July 2009, 13:35:28 »
Quote from: ripster;104345
Not really - I do though with Cherry switches because those stablizers are fussy.
The IBM M folks around here pull keys with their teeth.  I just find keypullers a lot more convenient for those inner keys and with two piece IBM keys especially.
Wait - are you saying it's possible to pull the spacebar off a Cherry switch using only 1 keypuller?  Do the ends of the keypuller really stretch out that far?
Filco FKBN104MC/EB
Filco FKBN104M/EB2
Quote from: ripster
Offline timw4mail
    • https://timshomepage.net
« Reply #4 on: Sat, 25 July 2009, 17:20:50 »
Quote from: ripster;104359
Oops.  Just ran across this oldie post.  You're not alone.
The M10 is slightly inconsistent, but I don't think it really makes it any more difficult to type on.
Buckling Springs IBM Model F AT, New Model F 77, Unicomp New Model M
Clicky iOne Scorpius M10, OCN-branded Ducky DK-9008-C, Blackmore Nocturna, Redragon Kumara K552-1, Qtronix Scorpius Keypad, Chicony KB-5181(Monterey)
Tactile Apple AEKII (Cream damped ALPS), Filco FKBN91M/JB (Japanese Tenkeyless), Cherry G84-5200, Cherry G84-4100LPAUS, Datalux Spacesaver(Cherry ML), Redragon Devarajas K556 RGB, Newmen GM711, Poker II (Cherry MX Clear), Logitech G910 Orion Spark, Logitech K840
Linear Lenovo Y (Gateron Red), Aluminum kiosk keyboard (Cherry MX Black)
Offline Special K
« Reply #5 on: Sat, 25 July 2009, 19:07:01 »
The only difference that bothers me is the lower than normal left CTRL key.  I use it for crouch in my games and holding it down when it is that much lower than the other keys is a pain.
Filco FKBN104MC/EB
Filco FKBN104M/EB2
Quote from: ripster
Offline cmr
« Reply #6 on: Sat, 25 July 2009, 20:43:34 »
I've never needed a keypuller with Cherry switches, only Alps.
As far as the original question, yeah, there's some noticeable variation in key height.
« Last Edit: Sat, 25 July 2009, 20:48:12 by cmr »
