Author Topic: Please put my mind at ease.  (Read 4675 times)
Offline whitefang
« on: Sat, 29 November 2014, 03:49:27 »
There's absolutely no way http://www.tigerdirect.ca/applications/SearchTools/item-details.asp?EdpNo=9515972&CatId=539 could be anything other than a Roccat Kone Pure Military with 5000DPI optical (R4/AVAGO 3310) sensor. Right? Its been ordered. I had trouble finding somewhere that had any in stock and I'm thinking the only reason its in stock there is because its been mislabelled.
Offline ConscienceDrop
  • a-are these pbt?
Re: Please put my mind at ease.
« Reply #1 on: Sat, 29 November 2014, 04:30:13 »
I'm sure everything will work out for the best OP! Don't worry. :)
worst case you gotta send it back, just take a SS to show later if you need.
Offline woll3
    • ESL Profile
« Reply #2 on: Sat, 29 November 2014, 04:33:18 »
They just failed with the product description, ROC-16-226 is, as the picture implies, the "Naval Storm Package".
Offline whitefang
« Reply #3 on: Sat, 29 November 2014, 05:10:42 »
Thanks guys. Every search I did indicated ROC-16-226 can't be anything other than exactly what I want. I also have a Deck Hassium Pro (PBT) and a XACT Pad Hybrid in the mail too. I've been trying to get my hands on an XACT pad for literally a decade in Canada. I'm not even worried that it won't live up to my expectations because at this point I just want to try one and it was only $20.
« Last Edit: Sat, 29 November 2014, 05:19:02 by whitefang »
Offline Oobly
« Reply #4 on: Sun, 30 November 2014, 03:12:34 »
Yup, looks like it's just mislabeled. It's the Naval Storm package. I can't find any other package of mouse and pad that comes close the description. They just used the specs of the normal Kone Pure instead of the Military.
Buying more keycaps,
it really hacks my wallet,
but I must have them.
Offline minh278
  • In life we will only fall, How far will we fall?
« Reply #5 on: Mon, 08 December 2014, 21:53:07 »
Remember, whatever you get will never be as bad as the guy who accidentally ordered 500 condoms on his mom's credit card.
Keyboards:  Final Fantasy XI XIth Anniversary keyboard (topre 45g) | Realforce Rgb (topre 45g, Eva Noctilucous keyset) | Mionix Zibal 60 (mx black, Vortex doubleshot) | Greymark (white alps) | IBM model M (found in the trash!)
Offline tufty
« Reply #6 on: Sat, 13 December 2014, 08:44:27 »
That's pretty mild, I'd have said.
Offline whitefang
« Reply #7 on: Sun, 14 December 2014, 16:00:53 »
Hah! Mouse has arrived and its the correct one. I'm happy. :)
Offline minh278
« Reply #8 on: Sun, 14 December 2014, 17:28:53 »
Thats good! Hope you like it!
