Author Topic: IBM Model Z  (Read 2468 times)
Offline Aer Fixus
  • And now, back to lurking...
IBM Model Z
« on: Sat, 29 November 2014, 10:59:28 »
Yeah, what? http://www.ebay.com/itm/121501666202
The keyboard is very clearly a Model F with a screwed up label. Like the Bigfoot boards that have M printed on them, the Z means nothing, although a refurbishing date of 2003 is pretty cool, I guess.
I'm not sure if people collect oddities like this or if a misprinted label is of no concern to anyone. If no one actually cares about misprinted labels and late refurbish dates, I can stop posting stuff like this.
               SOON: IN PROGRESS:
I lie all the time.... I really don't even like keyboards
Offline berserkfan
Re: IBM Model Z
« Reply #1 on: Sat, 29 November 2014, 12:36:23 »
I suspect people really care; they just don't have good information on what's going on. EG is the IBM Model Z some random BS printed by some joker? Or is it an unusual and proprietary variant that doesn't work with Soarer converter? (Remember Orihalcon bought a bunch of new Lynx keyboards only to discover that they could only work with one version of Soarer.) It would be very curious if there were some versions of capacitative boards that had some unique properties.
  Guinea Pig needed!
Offline Parak
Re: IBM Model Z
« Reply #2 on: Sat, 29 November 2014, 13:46:23 »
Note: cracked case.
Offline Aer Fixus
Re: IBM Model Z
« Reply #3 on: Sat, 29 November 2014, 14:06:41 »
Note: cracked case.
And the DIN connector appears to be bent, too.
               SOON: IN PROGRESS:
Re: IBM Model Z
« Reply #4 on: Sat, 29 November 2014, 15:01:57 »
  Guinea Pig needed!
I already got the other [refurbished in 2003] one and will post info when it arrives.
This "great find" was already posted here:
https://geekhack.org/index.php?topic=66017
Offline Aer Fixus
Re: IBM Model Z
« Reply #5 on: Sat, 29 November 2014, 15:05:08 »
I see. I didn't actually click through all of the listings :|
               SOON: IN PROGRESS:
Offline Touch_It
Re: IBM Model Z
« Reply #6 on: Sat, 29 November 2014, 16:10:15 »
I always like seeing oddities, though I don't really care about the label.  The fact that was refurbished in 2003 is more interesting.  Its a decent price as well.
Re: IBM Model Z
« Reply #7 on: Sun, 30 November 2014, 08:54:42 »
Note: cracked case.
Very typical breakage for these, those bottom corners are the weak points.
I have had at least 2 6110347s and they did not have the DIP switches. Those I have only seen on the 6110668.
- D Trump 2026-09-28
Re: IBM Model Z
« Reply #8 on: Sun, 30 November 2014, 16:13:50 »
Note: cracked case.
afaik the main difference between the 6110345/346/347 and the 6110668 is that.
