Author Topic: Pair of Decision Data keyboards starting at $20 + shipping  (Read 3008 times)
Offline jacobolus
Re: Pair of Decision Data keyboards starting at $20 + shipping
« Reply #1 on: Sun, 30 November 2014, 04:37:21 »
The keyboards on auction are different from the one in the other link. Keycaps are entirely different shapes, so it’s highly unlikely they’re the same switches. I’m not sure what kind of switches they have though.
If you want one like that link: http://www.ebay.com/itm/111507207174
« Last Edit: Sun, 30 November 2014, 04:42:38 by jacobolus »
« Reply #2 on: Sun, 30 November 2014, 11:43:35 »
It has identical alphas and alpha shapes with the same bars on the home keys as well as an identical layout with the exact same case.  I'm willing to state that they use magnetic valve switches.
Offline jacobolus
« Reply #3 on: Sun, 30 November 2014, 15:27:16 »
All the keycaps are of different shape, including all the 1u keys. They have the same type of homing slots though, and the overall keyboard construction is very similar.
Compare:
« Last Edit: Sun, 30 November 2014, 15:33:13 by jacobolus »
« Reply #4 on: Sun, 30 November 2014, 16:19:49 »
I believe Haata had a keyboard with those vertical homing bars that was brown alps but I may be confusing it with something else.
Also note that this style of magnetic valve switch uses a rubber dome so it's (reportedly) not that great. In the devlin KMX144 find thread I believe someone put BTC or keytronic springs on it to make it linear.
Offline jacobolus
« Reply #5 on: Sun, 30 November 2014, 16:49:36 »
The brown Alps board with homing slots looks like this:
Offline jacobolus
« Reply #6 on: Thu, 04 December 2014, 13:58:21 »
Switches seem to be different:
I’m not sure which two keyboards are part of this particular auction. From the original auction pictures it looks like they’re both the type shown on the bottom in this picture. (And I think the seller has a separate auction for the other one maybe?)
« Last Edit: Thu, 04 December 2014, 14:35:32 by jacobolus »
Offline jacobolus
« Reply #7 on: Thu, 04 December 2014, 14:36:41 »
Turns out the auction is for one of each. That is, one ITW magnetic valve keyboard and one (Maxi Switch?) dome keyboard. Even though the original auction pictures show two of the dome boards.
