Author Topic: Where Can I Buy Cherry Plate Mount Stabs?  (Read 4804 times)
Offline YoungMichael88
  • HHKB Wannabe
« on: Sun, 30 November 2014, 15:36:14 »
Just like the title says. Looking for a place where I can buy cherry plate mount stabs for my phantom. I need them all (space bar, enter etc.)
Thanks guys!
Offline kaotikb
Ducky 1087 (Green ALPS) |  CM QFR Stealth (MX Brown) | Unicomp Ultra Classic |Poker II (MX Brown)  | IBM 1391401 1991 | IBM 1391401 1989 | Ducky Shine 3 White Edition (MX Brown) | G80-3700(MX Black) | Corsair K70 (MX Brown) | Varmillo VA87MR (Gateron Red)
Pointing Devices:  Microsoft Trackball Optical (Ceramic bearings Installed)  | Sanwa MA-TB39BK (Larger Ceramic Bearings Installed) | Elecom M-XT2URBK | Kensington Slimblade | Logitech Trackman Wheel | Logitech Trackman Marble Plus
Re: Where Can I Buy Cherry Plate Mount Stabs?
« Reply #2 on: Sun, 30 November 2014, 15:47:01 »
Offline kaotikb
« Reply #3 on: Sun, 30 November 2014, 17:14:18 »
Right here http://www.wasdkeyboards.com/index.php/products/keyboard-parts/cherry-mx-plate-mounted-stabilizer-clips-2pcs.html
Those are mislabeled. It works with cherry switches and caps but those are costar stabilizers.
Well damn. Maybe mouser.com carries them then, just need to know the part number.
Offline Melvang
  • Exquisite Lord of Bumfluff
  • Melvang's Desktop Customs
« Reply #4 on: Sun, 30 November 2014, 18:28:58 »
I am not sure about the availability of Cherry Plate mount but recently I was on the search for cherry PCB mount and I found some at arrow.com  If you go to www.cherrycorp.com and navigate your way to the MX switches down on the page they list part numbers for PCB and plate mount stabs.
  • HHKB Wannabe
« Reply #5 on: Sun, 30 November 2014, 18:44:41 »
Would another name for stabs be a "leveling mechanism"?
« Reply #6 on: Sun, 30 November 2014, 20:39:30 »
Yes
  • HHKB Wannabe
« Reply #7 on: Sun, 30 November 2014, 20:52:12 »
Yes
well then, maybe they are on mouser after all. I'll look again.
Offline AKmalamute
  • HHKB Scrub
« Reply #8 on: Tue, 02 December 2014, 11:40:40 »
Here is the link I used to buy 2x plate-mount cherry stabilizers.
I *think* they have 7x stuff too but I'm less sure about that. Anyway I saved that link because those are what I ordered, and I got what I wanted when it arrived.
HHKB-lite2, Dvorak user
