Author Topic: Dupont Teflon Silicone Lubricant can vs bottle  (Read 1783 times)
Offline Hellcatz
« on: Sun, 30 November 2014, 21:18:44 »
So I managed to find this at my local hardware shop (rattle can only) and don't know if its the same as the stuff they sell in a bottle.
Note that I will not be spraying this stuff onto the switches themselves but using a brush instead
Cheers, Chris
Re: Dupont Teflon Silicone Lubricant can vs bottle
« Reply #1 on: Mon, 01 December 2014, 08:09:03 »
Pressurized aerosol cans use propellants that are often harmful solvents.
Personally, I avoid them.
- D Trump 2026-10-24
Offline Hellcatz
« Reply #2 on: Mon, 01 December 2014, 11:52:16 »
Wat do u recommend then that can be found readily Canada?
Also found dupont teflon multi use lube that's in a bottle I don't know if that would work
