Author Topic: "Gritty" feeling in my new filco keyboard  (Read 6537 times)
Offline Lust
« on: Wed, 03 December 2014, 03:14:05 »
hey guys i just recently purchased a new filco keyboard (MX Blue) and it felt really gritty. i dont know how to put it really but it doesnt feel right.
i had another board from filco which was an mx brown and it didnt have the issue as bad as this new one. ive also typed on another mechanical keyboard (razer blackwidow ultimate) and the comparing the two the razer surprisingly felt smoother. if that makes sense...
im no keyboard expert and ive tried searching stuff like this up but couldnt find any answers. i apologize in advance for my ignorance.
thanks
Offline intelli78
Re: "Gritty" feeling in my new filco keyboard
« Reply #1 on: Wed, 03 December 2014, 03:22:45 »
Some MX blues are grittier than others from the factory, I find, and they also get smoother with use. If you tried a used Razer, that's probably why it felt different. It's possible there's something wrong with your switches, but it's unlikely.
Offline Lust
« Reply #2 on: Wed, 03 December 2014, 03:35:58 »
i think im going to return this filco and purchase somewhere else.
im not too sure if it really makes a difference but the switch housing was assembled upside down on some of the switches.
the keyboard also felt very dry with the large keys(constant squeaking sound and you can feel it rubbing constantly)
ive never had any issues with a filco keyboard until now... do you think it might just be defective? and if so is there another brand i should be looking at or a certain place where i should be buying a new filco keyboard? ive been buying from amazon and spending 220 dollars on a keyboard and not being satisfied kinda sucks
Offline swill
  • builder & enabler
    • swillkb.com
« Reply #3 on: Wed, 03 December 2014, 07:10:16 »
Just so you know. New switches always feel a bit gritty before you break them in. My browns (on a filco) were really gritty when it was new. After a couple weeks it was not noticeable. After a couple months it was buttery smooth.
Offline strict
  • TKL Zealot
« Reply #4 on: Wed, 03 December 2014, 07:16:51 »
How could a switch housing be assembled upside down? They only fit together one way. Pics?
Offline swill
  • builder & enabler
    • swillkb.com
« Reply #5 on: Wed, 03 December 2014, 09:21:36 »
On the large keys, lube your stabilizers.  It made a huge difference on my filco...
Offline ynrozturk
« Reply #6 on: Wed, 03 December 2014, 10:55:21 »
Don't sell it or give it back, just type on it.
IBM Model F | IMB Model M | Poker II MX Brown | Poker II MX Clear | Filco TKL MX Brown | Bastardized Razer Blackwidow TE MX Blue | Logitech G602 |  Cyborg R.A.T. 7 | | Logitech MX518 | Icemat  | Artisan Hien
Offline swill
  • builder & enabler
    • swillkb.com
« Reply #7 on: Wed, 03 December 2014, 11:09:01 »
+1...  it will fix all its problems...  :)
Offline Lust
« Reply #8 on: Wed, 03 December 2014, 17:22:48 »
alright ill take your advice and try typing on it more. the razer that i compared it to was actually brand new too alongside with my mx brown filco.
the keycaps feel better IMO on the razer, i feel like i shouldnt be saying this but i am. i might be in the wrong section but is there a good quality and simple keycap set available?
im not sure if im using the terminology right about the switch housing and it seems like its most likely an aesthetic thing but for a quality brand like filco i wouldnt expect something like this to happen.
« Reply #9 on: Wed, 03 December 2014, 17:28:56 »
normal
and you only have one flipped because you have a ninja
top is filco camo with blues
bottom is regular mj2 with reds
PCB doesn't have backlight support anyway, so it doesn't matter at all.
Offline intelli78
« Reply #10 on: Wed, 03 December 2014, 17:31:24 »
It's not possible to put a Cherry MX switch housing on backwards. That means that the switch(es) are actually installed backwards, which means that the PCB was designed that way.
So, it is a bit unusual but it's definitely intentional.
« Last Edit: Wed, 03 December 2014, 17:33:05 by intelli78 »
Offline Lust
« Reply #11 on: Wed, 03 December 2014, 17:41:32 »
hmm interesting. is there a reason for it being flipped? thanks for taking the time to educate me on this. im quite ignorant on the subject haha.
« Reply #12 on: Wed, 03 December 2014, 17:45:05 »
literally no good reason for it
engineer was probably bored
Offline intelli78
« Reply #13 on: Wed, 03 December 2014, 17:45:42 »
I'm not an engineer but possibly due to the layout of the traces on the board.
« Reply #14 on: Wed, 03 December 2014, 17:46:29 »
then why would 2 be flipped on the normal/camo, but 1 on the ninja?
Offline strict
  • TKL Zealot
« Reply #15 on: Wed, 03 December 2014, 17:46:49 »
The flipped switch is intentional as my Filco Ninja looks exactly the same. The PCB requires the switch to be installed in this fashion due to Diatec using a universal PCB that supports 86/87/88 key layouts.
Your switches will definitely get smoother with use. Some batches of cherry switches come from the factory feeling smoother than others. Its nothing Filco or any other manufacturer can control. You could end up buying CM board that feels worse and then buy yet another Filco and it might feel the best of of them all.
Check out MechanicalKeyboards.com, they stock tons of ABS and PBT keys and most of them are pretty reasonably priced.
« Reply #16 on: Wed, 03 December 2014, 17:48:26 »
TIL
thanks
Offline intelli78
« Reply #17 on: Wed, 03 December 2014, 17:49:17 »
I don't know, but I would guess there is an actual reason even if we don't know it right now, not boredom.  ;)
Offline Lust
« Reply #18 on: Wed, 03 December 2014, 17:53:03 »
thanks for clearing this up for me. i was a little worried. is there anything you recommend that wont sacrifice the look of the ninja keyboard? and am i the only one to think that the keycaps feel kinda cheap?
Offline strict
  • TKL Zealot
« Reply #19 on: Wed, 03 December 2014, 18:00:42 »
The OEM keycaps are definitely crap. If I were going to buy another MX keyset right now it would be Leopold's thick PBT keys. We even have a thread about them (and how awesome they are ;)).
https://geekhack.org/index.php?topic=59780.0
Offline ynrozturk
« Reply #20 on: Thu, 04 December 2014, 07:19:30 »
+1 for the Leopold set, great caps. They feel awesome.
Offline strict
  • TKL Zealot
« Reply #21 on: Fri, 05 December 2014, 17:27:06 »
Since I brought my Filco home from work (in favor of the Realforce  :cool:) I figured I would pop the case apart and share pictures of the universal PCB Diatec uses. This is from a Filco MJ2 Ninja purchased around November 2013.
I stand corrected about the layouts it supports, I tried to remember them all but without the board in front of me it was a crap shot. It supports 87 key (ANSI), 88 key (ISO), and 89/91 key (JIS) layouts.
You can see in the pictures below that unused switch posts get their respective through holes filled with solder. I'm not sure why they would do this instead of leaving them empty.
