Author Topic: Ergodox Trouble with some Keys  (Read 1708 times)
Offline rethus
« on: Thu, 04 December 2014, 05:34:12 »
At the moment I have some trouble with the marked keys.
They don't work any more.
Can somebody give me a hint, which Lines on the PCB i should test to found the error?
Offline czarek
  • Keep the momentum going!
    • FalbaTech
Re: Ergodox Trouble with some Keys
« Reply #1 on: Thu, 04 December 2014, 05:48:55 »
I would start with checking if any pins are not shorting the ground. My first suspect would be this red key in thumb cluster.
Offline rethus
« Reply #2 on: Thu, 04 December 2014, 06:21:10 »
I've jolted each of them, and inspect the SolderingPoints. Looks all good.
I think it's a cold soldering-Point on the Tensee?
Is there a plan so I could figuer out which pins on teensy I could check?
Offline rethus
« Reply #3 on: Thu, 04 December 2014, 06:56:49 »
Ok, it's on the teensy.
Pin 5, lower row from left seems to make the trouble.
At the moment, it works again, after resoldering this pin.
Offline plainbriny
« Reply #4 on: Thu, 04 December 2014, 07:08:08 »
That's odd, based on traces on PCB, it should be something to do with D3 (third pin from the lower right), pin 5 from left (B3) is connected to the column of "8ik,".
Offline rethus
« Reply #5 on: Thu, 04 December 2014, 07:11:35 »
You are right. Seems that I have resolderd B3 and it works... but only for short time.
Now I have resolderd D3, and it works again :)
Hope to got the main failure now  :thumb:
