Author Topic: Rosewill RGB80 - $79.99 on Newegg  (Read 1645 times)
Offline mogo
« on: Thu, 04 December 2014, 15:03:44 »
TKL Rosewill board with either blues or browns for 80 bucks.
Kailh Brown:
http://www.newegg.com/Product/Product.aspx?Item=N82E16823201076
Kailh Blue:
http://www.newegg.com/Product/Product.aspx?Item=N82E16823201071
Follow up question: I've been looking for an inexpensive MX brown board for my boyfriend, backlit and preferrably less than full-sized. This one seems to fit the bill, but can anyone recommend any other options? Thanks guys <3
« Last Edit: Thu, 04 December 2014, 20:02:43 by mogo »
Offline Grendel
Re: Rosewill RGB80 - $79.99 on Newegg
« Reply #1 on: Thu, 04 December 2014, 17:31:33 »
Note that these use Kaihl switches, not MX.
- I'm game !
Offline mogo
« Reply #2 on: Thu, 04 December 2014, 20:02:27 »
Ooh, thanks for the update. It wasn't clear about that. I'll update the OP.
