Author Topic: Lots of Skidatas  (Read 4710 times)
Offline berserkfan
Lots of Skidatas
« on: Fri, 05 December 2014, 20:52:36 »
« Last Edit: Sat, 06 December 2014, 03:26:11 by berserkfan »
Offline billnye
  • ability man
Re: Lots of Skidatas
« Reply #1 on: Fri, 05 December 2014, 20:57:46 »
If someone wants to buy this for the caps I will buy the rest of the board for the switches :thumb:
Offline berserkfan
« Reply #2 on: Fri, 05 December 2014, 21:02:43 »
Billnye, it's a good deal for caps and switches if you have someone in Germany to help you. You might want to try Deskauthority
Offline margo baggins
  • Dungeon Dweller
  • Get back to work!
« Reply #3 on: Mon, 08 December 2014, 11:30:06 »
bah that seller had a norway board a while back, which is now sold. The norway one is the best one as it's QWERTY not QWERTZ. though, skidata are good to kill, bolt on stabs and millions of clears. i've killed 4 or 5 :S
I got boards.
« Reply #4 on: Mon, 08 December 2014, 15:37:56 »
oh they have screw-down stabilizers like WEY? sweet those are my fav.
Offline IvanIvanovich
  • Mr. Silk Underwear
« Reply #5 on: Mon, 08 December 2014, 15:41:55 »
I think the bolt on type stabs are the default for everything produced by GMK.
I wish they still had Norwegian... :(
« Reply #6 on: Mon, 08 December 2014, 22:08:03 »
GMK desko does not have any bolt down, WEY EK2000 has none either. WEY HK2000 has a mix (bolt down for modular upper sections, clip in on lower section).
Offline quochung1989
  • Vintage Cherry Collector
  • Frenzy Classic.
« Reply #7 on: Mon, 08 December 2014, 22:56:34 »
Can you post picture help me easy to image it?
« Reply #8 on: Tue, 09 December 2014, 21:55:19 »
I have lost all my WEY photos, I think I will take more tomorrow.
Here's some pictures from before I cleaned it. Top "modular" sections have screw down stabilizers (you can see the top of the screw in the photo)
IMG_20140929_125230686 by dork_vader_exe, on Flickr
Normal stabilizers elsewhere:
IMG_20140929_124856733 by dork_vader_exe, on Flickr
« Reply #9 on: Wed, 10 December 2014, 08:27:46 »
The ones I had (without the fancy screen) had the bolt on type all over.
« Reply #10 on: Wed, 10 December 2014, 21:02:36 »
interesting: my EK2000 (which I have even less pictures of) is the type without the fancy screen and it doesn't have any screw down stabilizers.
I think GMK just tosses them in at random.
  • Frenzy Classic.
« Reply #11 on: Wed, 10 December 2014, 21:37:07 »
Ok. Thank you for your photos :thumb:
Offline jonathanyu
« Reply #12 on: Wed, 10 December 2014, 21:59:37 »
Do you know that the screw down stabilizers on WEY keyboards are the old type that without two tiny "bumpers" or are the new type?
  • Frenzy Classic.
« Reply #13 on: Wed, 10 December 2014, 22:44:58 »
Maybe it 's same this:
« Reply #14 on: Thu, 11 December 2014, 14:06:49 »
I so wish they still made them that way ^ the best kind!
« Reply #15 on: Thu, 11 December 2014, 23:34:11 »
new type, pretty sure. I'll see if I can take it apart sometime and take pictures.
those old ones look like wyse era or something. Didn't the WY50 have screws downs under it's spacebar (only stabilized key)
  • Frenzy Classic.
« Reply #16 on: Fri, 12 December 2014, 02:40:15 »
I hope I can view photos about both 2 type :)
Offline jonathanyu
« Reply #17 on: Fri, 12 December 2014, 09:23:08 »
83978-0
  • Frenzy Classic.
« Reply #18 on: Sat, 13 December 2014, 02:17:08 »
Ok. Thanks :thumb:
