Author Topic: Do Mechanical Keyboards Change A lot?  (Read 1967 times)
Offline kidanime3d
« on: Sat, 06 December 2014, 14:36:13 »
Hey GH,
I remember a while back on a LTT video that one of the best MKs was the IBM Model Ms.  My question is do MK really change that much?  Surely some standard keys, good switches, decent fn layer, programmability and you are done right?
Re: Do Mechanical Keyboards Change A lot?
« Reply #1 on: Sat, 06 December 2014, 14:39:30 »
I don't understand the question.
Offline intelli78
« Reply #2 on: Sat, 06 December 2014, 14:50:29 »
You are right, keyboards can't change that much. Still, that doesn't mean there aren't innovations. For example, CM with the Novatouch. That was something that hadn't been done before. Logitech just came out with a new switch (Romer-G). Unicomp's TKL board is still pending. New Cherry RGB switches. Etc.
Offline kidanime3d
« Reply #3 on: Sat, 06 December 2014, 15:47:37 »
Yes quite a few innovations around.  Had a look at the Romer-G, quite cool.
Offline faceyourfaces
« Reply #4 on: Sat, 06 December 2014, 17:36:25 »
I'm not sure I would call that an innovation.
« Reply #5 on: Sat, 06 December 2014, 17:53:42 »
Whatever those new switches are from Kailh look pretty innovative. Depends on if they're any good or not.
« Reply #6 on: Sun, 07 December 2014, 03:46:52 »
Since the Model M the layout of a standard keyboard has not changed much, if at all.
60% and 75% make some compromises to fit the extra functions in.
Apart from that, a new switch every few years or so, user-replaceable keycaps, user-replaceable cable, and you're good to go for another 10 years.
Offline Altis
« Reply #7 on: Sun, 07 December 2014, 23:24:28 »
For me, one of the things that allowed me to get into mechanical keyboards was that they don't really change much over time. My 1990 Model M works like a charm and is missing only the Windows/Menu keys.
You can get all kinds of layouts and such but I think they'll be functional and compatible for many years to come.
