Author Topic: LaTeX discussion  (Read 6249 times)
Offline timw4mail
    • https://timshomepage.net
LaTeX discussion
« on: Tue, 28 July 2009, 13:29:28 »
This is mainly to split this off from the images thread...
I was looking into LaTeX for taking notes in my classes, since its difficult to incorporate Lewis dot structures into text in a regular Word Processor.
I've also wondered if there's an easy way to draw graphs in LaTeX.
Buckling Springs IBM Model F AT, New Model F 77, Unicomp New Model M
Clicky iOne Scorpius M10, OCN-branded Ducky DK-9008-C, Blackmore Nocturna, Redragon Kumara K552-1, Qtronix Scorpius Keypad, Chicony KB-5181(Monterey)
Tactile Apple AEKII (Cream damped ALPS), Filco FKBN91M/JB (Japanese Tenkeyless), Cherry G84-5200, Cherry G84-4100LPAUS, Datalux Spacesaver(Cherry ML), Redragon Devarajas K556 RGB, Newmen GM711, Poker II (Cherry MX Clear), Logitech G910 Orion Spark, Logitech K840
Linear Lenovo Y (Gateron Red), Aluminum kiosk keyboard (Cherry MX Black)
Offline talis
LaTeX discussion
« Reply #1 on: Tue, 28 July 2009, 13:51:16 »
Now if I could only figure out how to do Chemistry and Graphs with LaTeX...
Its usually easier to graphs in an external package, and just add them to the document as images.  Matlab works quite well for this as you can export directly to .eps.
Chemistry typesetting should be fairly easy.  I can't see it being much more then a mixture of super and sub-scrips around a few basic symbols.:
Code: [Select]
\begin{equation}
Fe_2O_3 + 2 Al \rightarrow 2 Fe + Al_2O_3
\end{equation}
For structural stuff take a look at chemtex and xymtex.
(note, I'm not a chemist, so I have no idea what this means)
Code: [Select]
\usepackage{xymtex}
\pyridinev{4==Cl}
produces an output like :
There is a lewis package specifically for that, tho it doesn't seem to be overly elegant.
Code: [Select]
\usepackage{lewis}
\lewis{F}{.}{.}{.}{.}{}{}{.}{.}--\lewis{F}{}{}{.}{.}{.}{.}{.}{.}
produces :
Offline timw4mail
LaTeX discussion
« Reply #2 on: Tue, 28 July 2009, 14:03:28 »
Quote from: talis;105088
How do you actually add images?
I don't have, or know how to use Matlab, do you know if Maple can do anything similar?
Code: [Select]
\begin{equation}
\end{equation}
Code: [Select]
\usepackage{xymtex}
\pyridinev{4==Cl}
Code: [Select]
\usepackage{lewis}
produces :
That package is perfect...I just don't want to have to leave things out of my class notes because I can't type them in.
Offline talis
LaTeX discussion
« Reply #3 on: Tue, 28 July 2009, 14:12:57 »
Anything that can export will work, .eps isn't necicary, you can use .jpg or pretty much any image format for that matter (eps are just vectorized images, so they scale nicely).  You just need to include the images.  Maple may be able to, there's probably a right click context menu export of a figure (its been a while since I used Maple).
I know there's a few ways to graph directly in LaTeX, but they've always seemed overly complicated, and are one of those things you have to look up every time you need them.
Graphics are easy to include, in its  simplest form :
Code: [Select]
\usepackage{graphicx}
\begin{figure}
\includegraphics[]{img/dc-dc-l-graph}
\end{figure}
Tho you can also scale, rotate, center, and annotate:
Code: [Select]
\begin{figure}
    \begin{center}
        \includegraphics[scale=.4]{img/dc-dc-l-graph}
    \end{center}
    \caption[Inductor selection guide]{DC-DC converter inductor selection guide.}
    \label{dc-dc-inductor-selection-graph}
\end{figure}
You can also scale relative to the width of the text field in the layout you are using:
Code: [Select]
\includegraphics[width=.8\textwidth, height=.45\textwidth]{res/car_res/pascar4_simple}\\
« Last Edit: Tue, 28 July 2009, 14:19:24 by talis »
Offline huha
LaTeX discussion
« Reply #4 on: Tue, 28 July 2009, 14:15:05 »
For chemistry stuff, there's always mhchem, which does it right--non-italic element names and slightly different sub- and superscript positions.
-huha
Unicomp Endurapro 105 (blank keycaps, BS) // Cherry G80-3000LSCDE-2 (blues, modded to green MX) // Cherry G80-3000LAMDE-0 (blacks, 2x) // Cherry G80-11900LTMDE-0 (blacks, 2x) // Compaq G80-11801 (browns) // Epson Q203A (Fujitsu Peerless) // IBM Model M2 (BS) // Boscom AS400 Terminal Emulator (OEM\'d Unicomp, BS, 2x) // Dell AT102DW (black Alps) // Mechanical Touch (chinese BS) Acer 6312-KW (Acer mechanics on membrane) // Cherry G84-4100 (ML) // Cherry G80-1000HAD (NKRO, blacks)
Offline keyb_gr
  • Cherrified user
    • My keyboard page (German)
LaTeX discussion
« Reply #5 on: Tue, 28 July 2009, 14:29:07 »
For drawing I'll be using Inkscape for now. Gnuplot graphs can be included easily, as the latter has an "epslatex" output terminal these days.
Offline timw4mail
LaTeX discussion
« Reply #6 on: Tue, 28 July 2009, 14:49:31 »
Quote from: keyb_gr;105097
Inkscape does graphing?
Offline talis
LaTeX discussion
« Reply #7 on: Tue, 28 July 2009, 15:38:06 »
You can try Gnuplot (there's cross platform releases), or take a look at Octave, which is an open source Matlab clone (without all the toolkit/simulink components).
Offline DrunkenDonut
LaTeX discussion
« Reply #8 on: Tue, 28 July 2009, 19:43:50 »
Looks like you're covered with the formulas and chemistry stuff ...
I'll just add, if you're going to be producing PDFs out of all of this, pdflatex or pdftex (and probably some other package I can't recall) can import PNGs directly. PNG are also vector based so they scale nicely as well. You can also add pages from other PDF files easily too.
*Hang on to your wallet!*
BTC E5X5R5BTC-5339R-0 (\'90), MS Natural Keyboard Pro (\'99), Sun Type 5c, 2x 1391401, DASK3ULT (\'08), ABS M1, Dell AT101W, M4-1
FKBN87M/EB (\'09), FKBN87ML/EB (\'09), FKBN87Z/EB (\'09), FKBN87MC/NPEC (\'09), G80-3000LQCDE-2 (\'11)
Offline huha
LaTeX discussion
« Reply #9 on: Tue, 28 July 2009, 20:19:32 »
Quote from: DrunkenDonut;105176
PNG aren't vector graphics I'm afraid. Still, nothing's hindering you from exporting your vector graphics as PDF--almost any graphics program has that option.
-huha
Offline timw4mail
LaTeX discussion
« Reply #10 on: Tue, 28 July 2009, 20:51:36 »
Quote from: huha;105179
-huha
Although, it seems easier to just incorporate it as an EPS...
It's a shame that PDF is the defacto standard for vector text...its such a bloated, poorly-aged format.
Offline timw4mail
LaTeX discussion
« Reply #11 on: Wed, 29 July 2009, 13:56:19 »
Oh, does anyone know of a LaTeX package for logic gates?
Offline keyb_gr
  • Cherrified user
LaTeX discussion
« Reply #12 on: Wed, 29 July 2009, 14:10:17 »
Quote from: timw4mail;105284
"pgf" seems to be useable. These m4 macros may also be useful.
I might prefer an external drawing app here.
Offline talis
LaTeX discussion
« Reply #13 on: Wed, 29 July 2009, 15:02:30 »
Quote from: keyb_gr;105294
Eagle cad may work as an external editor.
If you're just trying to get the ideas across it may be better to stick with Boolean notation, much quicker to type out and captures all the same information:
Code: [Select]
\begin{equation}
\lnot ( A \land B )\lor C
\end{equation}
« Last Edit: Wed, 29 July 2009, 15:16:48 by talis »
LaTeX discussion
« Reply #14 on: Wed, 29 July 2009, 15:35:14 »
Oooops, my bad. You're right, but I got it stuck in my head that it's vector somehow. I remember doing the PDF export for various images either through built-in exporting or print-to-PDF functionality.
Quote from: timw4mail;105181
I've had trouble with EPS in the past, especially with programs that don't output EPS quite the way you want. You'd have to go into each image and manually change the window boundaries and such. That's why PDF + PDF/PNG images was such a great combo. Less issues with the file formats and still got your work done, especially if many platforms came into play - Solaris, Windows, etc... Sometimes it's easier with EPS/PS, sometimes it's easier with PNG/PDF.
