Author Topic: Korean/English Legend PBT keycaps?  (Read 5036 times)
Offline thegigglepuss
« on: Tue, 09 December 2014, 02:00:41 »
Hello all! I'm in the market for some pbt keycaps for cherry mx switches in either White or Black with Korean and english lettering. I saw the blue ones on imsto and there are blue Leopold ones on eBay, but I cannot seem to find anything of decent quality anywhere else.
Can anyone help me out? I'd be totally fine buying a set of white ones from a Leopold FC750R as well, I just don't know where I'd find any.
Re: Korean/English Legend PBT keycaps?
« Reply #1 on: Tue, 09 December 2014, 02:07:28 »
Also if there are any options that are backlight compatible, that would be Fantastic!
Offline bowji
  • Came for the Keycaps, stayed for the community.
« Reply #2 on: Tue, 09 December 2014, 02:12:36 »
I know iomania has engraved english/korean pbt keycaps but they arent compatible for leds. Since its a niche type of keycap, I believe buying a korean mechanical keyboard with leds is a possible route. There might be other options I dont know of so I hope someone else can pitch in.
               FREE GIRLDC!!     코리안 스레드
« Reply #3 on: Tue, 09 December 2014, 08:04:58 »
You're not going to find any with clear DS legends.
IMSTO makes a Hangul set, and Ivan's upcoming PBT full sets GB will probably have a Hangul or something similar.
Offline IvanIvanovich
  • Mr. Silk Underwear
« Reply #4 on: Tue, 09 December 2014, 11:10:37 »
Yes I will be offering US/KO in PBT dyesub groupbuy. I hope to have that live tomorrow.
« Reply #5 on: Tue, 09 December 2014, 12:50:33 »
Awesome! Could I have a Link when you post it?
I checked IOmania and they're out of stock of the Ducky engraved Hangul sets  :(
Offline taylordcraig
« Reply #6 on: Wed, 10 December 2014, 02:20:47 »
post cmyk or i kill u
« Reply #7 on: Wed, 10 December 2014, 12:06:11 »
« Reply #8 on: Wed, 10 December 2014, 15:10:51 »
Groupbuy is up. https://geekhack.org/index.php?topic=66550.0
Thanks for that! Unfortunately I can't justify spending $80+ on a keyset at the current moment when I can get a similar set for half that.
Once I get a better job though, you best believe I'm gonna be all over it ;)
Offline Volvicsoda
  • Want some soda?
« Reply #9 on: Wed, 10 December 2014, 21:08:10 »
Hey, take a look at vortexgear.co.kr
They are currently selling limited quantities of led compatible white-colored pbt sets. (English + Korean 29 Alphas)
but it's going to cost you 55 bucks, just the set alone, and plus additional int. shipping, if you manage to find a proxy.
FC660C, Realforce 104UK-HiPro, Novatouch TKL, NMB RT101+, NMB 8755C+, BTC-5339 Cyrilic, IBM 1390131, IBM SSK,G86-52400, G80-8113,  MX-MINI, G81-3077, Skidata, Filco Camo, 3000SAG, 1724SPF, GMK C. Orange, GMK Dolch, GMK WoB, GMK TA, Filco SA...
« Reply #10 on: Thu, 11 December 2014, 01:14:26 »
Is this the set you're referring to? I'm sure I'm probably missing a good chunk of the translation because I'm nowhere near fluent. Does this set have both english and hangul? I know the description lists both, but I just wanted to be sure because there is only English shown in the picture.
Offline bowji
« Reply #11 on: Thu, 11 December 2014, 01:29:52 »
Seems like Volvicsoda found exactly what youre looking for. The 55,000 won ones says "Korean/English Combo" so Im pretty sure it has both even the though the picture is not showing(theyre using the same picture as the english only ones).
« Reply #12 on: Thu, 11 December 2014, 02:10:03 »
They don't ship to the US do they? I know he mentioned I might have to find  a proxy, but I wasn't sure. I'm at the checkout screen now and I don't see an option for it
« Reply #13 on: Fri, 12 December 2014, 19:47:44 »
Ivan's got some in his latest GB. I suggest that over the Korean option if you're in the US.
« Reply #14 on: Sat, 13 December 2014, 04:05:14 »
Yes, I saw that and they look really cool. I would just rather spend $50-70 on exactly what I'm looking for (backlit compatible) than 80-90 for something that hits 2/3 of the things I want.
Offline bowji
« Reply #15 on: Sat, 13 December 2014, 08:51:06 »
I tried checking out just to see if it ships to the states. Unfortunately, they use a Korean zipcode finder which restricts looking up any zipcodes outside of South Korea. So no, they dont ship to the US.
