Author Topic: Filco Minila vs. Ducky Mini YOTH  (Read 10034 times)
Offline clickclickclick
« on: Tue, 09 December 2014, 08:16:45 »
Having trouble deciding between these two:
http://mechanicalkeyboards.com/shop/index.php?l=product_detail&p=1049
http://www.amazon.com/Majestouch-MINILA-Linear-Keyboard-FFKB67ML/dp/B00BG0ZR7Y/
Both are Cherry MX Black (supposedly), both compact.
Advantages of Flico:
*$50 cheaper
*Arrow keys are separate
*Has extra USB port
*Filco build quality may be superior? I've heard some complaints about the Ducky w/ Cherry MX Blue switches feeling mushy, and been concerned they may not be using authentic switches. Can't find anything specifically about the Black switches, though
*All black look is sleek
Advantages of Ducky:
*Backlit
*Has ability to control mouse pointer with WASD keys
*Cable attachment may be more secure
*Has a horse on it
*Comes with keychain
Thoughts?
Offline Hzza
Re: Filco Minila vs. Ducky Mini YOTH
« Reply #1 on: Tue, 09 December 2014, 08:53:13 »
The Minla isn't as compatible with aftermarket keycaps which should probably be considered (spacebar row caps mainly). The layout of the zxcv row is offset by an extra 0.25 unit as well which might throw off your typing until you get used to it.
No comments about the Ducky, I've never seen/used one but it looks like a relatively standard 60% backlit board.
Offline dante
« Reply #2 on: Tue, 09 December 2014, 09:02:38 »
I can't find it on rededit but someone put a complete set of Row 3 Nuclear SA on their Manila without issues ...
They used the right shift key for the space bar.  It looked pretty cool!
« Reply #3 on: Tue, 09 December 2014, 14:50:16 »
Well, couldn't decide, so I just bought both.
Offline FrostyToast
  • Litshoard
« Reply #4 on: Tue, 09 December 2014, 14:51:54 »
Apparently the YOTH comes with a ducky keychain and I really want it.
Could I buy it off you? Please. Maybe?   :-[
Quote from: elton5354
Offline Sygaldry
  • Edema Ruh
« Reply #5 on: Tue, 09 December 2014, 14:56:15 »
I have a Minila Air with Blacks coming in and a set of Granites waiting to pop right on it!  :thumb:
null
« Reply #6 on: Tue, 09 December 2014, 15:51:40 »
I like the way you think. I always preferred the layout of the miniLA. Mine was a tank, survived 4 OJ spills before I sold it.
I sold it because I didn't use it, not because I didn't like it.
« Reply #7 on: Tue, 09 December 2014, 15:52:53 »
Please post a comparative review of both and let us know which one you prefer :)
Offline Sygaldry
  • Edema Ruh
« Reply #8 on: Tue, 09 December 2014, 17:09:41 »
Just curious, why didn't you opt for the Bluetooth USB version (the Minila Air)?
null
« Reply #9 on: Tue, 09 December 2014, 17:47:31 »
Not every computer has bluetooth compatibility. Some people also just don't like wireless keyboards
Offline Sygaldry
  • Edema Ruh
« Reply #10 on: Tue, 09 December 2014, 17:49:31 »
Meh, I was just curious because sometimes the price is similar (heck, I got mine brand new for 88 dollars)
null
Offline dante
« Reply #11 on: Tue, 09 December 2014, 17:58:50 »
Ah ha!  Found it!
http://imgur.com/a/9Y6qj
Offline Sygaldry
  • Edema Ruh
« Reply #12 on: Tue, 09 December 2014, 18:05:36 »
There's also this beauty:
null
Offline dante
« Reply #13 on: Tue, 09 December 2014, 18:08:34 »
I have to admit - when I first saw the Manila I thought WTF worst layout ever .. but after seeing all these nice keycaps on it I've changed my tune.
« Last Edit: Wed, 10 December 2014, 07:48:35 by dante »
« Reply #14 on: Tue, 09 December 2014, 18:45:56 »
I actually looked at the Filco bluetooth version a while back, and while it said it could hold connection profiles for three different devices, it doesn't let the user choose the device. It will automatically connect to the oldest paired device, which I think is pretty terrible. I ended up buying a Logitech k810 at that time, which would let me choose any of 3 paired devices. Unfortunately, the Logitech had problems with repeating key presses, and I couldn't put up with it since I do a lot of things on the linux command line. It got frustrating quick, and I returned it.
Upon reading recent reviews of the Filco bluetooth version, I found someone experienced that same problem with repeated key presses, which makes me wonder if it's a problem with bluetooth in general.
I have several computers with bluetooth, and I'd love the convenience of switching back and forth with a good mechanical bluetooth kb, but unfortunately it seems there are those above mentioned issues that I can't work around.
In the end, the USB version will suit me better for simple reliability, not to mention it will work at POST and allow entry into BIOS as well as when booting certain live discs/images. That's something bluetooth cannot do.
Offline Sygaldry
  • Edema Ruh
« Reply #15 on: Tue, 09 December 2014, 21:13:06 »
Fair enough. The bluetoith version has USB too  :rolleyes:
But I guess if you don't plan on ever using the Bluetooth, there's no point in buying the Air
null
Offline tbc
« Reply #16 on: Tue, 09 December 2014, 21:15:09 »
did anyone mention the allmetal case of the yoth?
« Reply #17 on: Tue, 09 December 2014, 21:23:29 »
If the bluetooth version has USB, then that's a serious failure on the part of Filco and those that reviewed it to never mention it.
https://www.diatec.co.jp/en/det.php?prod_c=1469
http://www.keyboardco.com/blog/index.php/2013/10/filco-minila-air-bluetooth-keyboard-review/
For the diatec link, under "Interface", it says bluetooth. No mention of USB. Also no picture of any USB port on the keyboard. For the keyboardco review link, also no mention of USB functionality or any picture of a USB port on the keyboard.
So I made the best decision I could with the information I was able to obtain. Keep that eye roll **** to yourself.
Offline Sygaldry
  • Edema Ruh
« Reply #18 on: Wed, 10 December 2014, 00:33:58 »
Whoa someone forgot to eat their cereal this morning....
I didmt mean to eyeroll at you.. I just clicked a random smiley and didn't even realize it was an eyeroll until you pointed it out.
I habe no further interest in adding any sort of constructive input to your thread since you, sir, are overly sensitive and hostile.
Now I really mean it.
  :rolleyes:
null
« Reply #19 on: Wed, 10 December 2014, 22:29:51 »
  :rolleyes:
No, I've just been on the internet too long to retain patience for arrogant condescending jerkwads and pathological liars (and there are far too many liars on the internet). If you had actually bought a Minila Air for $88 (lie), you would know it does not support USB.
And you meant your initial eye roll, which I considered disrespectful and rude, and then trying to weasel out of it with another lie just shows you lack character.
So in summary, yes, please stay out of my thread.
To everyone else, I will see about doing a comparison of the two boards soon.
Offline FrostyToast
  • Litshoard
« Reply #20 on: Wed, 10 December 2014, 22:40:11 »
  :rolleyes:
Please do not fire shots at any of these people for misunderstandings.
Just because someone didn't get their facts straight does not give you the right to back hand them telling them that they are wrong.
To me, the eye roll doesn't even look like the kind of satirical patronizing eye roll that one would usually make.
It honestly to me looks like a smiley that has been struck by something peculiar, like a sort of confusion.
After a bit of stalking on Sygaldry's previous posts, I can clearly see that he or she for that matter had no idea what that smiley's actual purpose was.
Offline heedpantsnow
  • Old enough to know better
« Reply #21 on: Wed, 10 December 2014, 22:46:23 »
Sheesh dude.  :norolleyes:
I thought I remembered that BT Filco also having a USB connection. Maybe it's worth looking into.
I'm back.
Offline FrostyToast
  • Litshoard
« Reply #22 on: Wed, 10 December 2014, 22:51:09 »
I am wondering about this as well.
How the heck would it be able to charge without some sort of wired connection to something? Not like anything would ever rely solely on Qi.
A USB charging solution that doubles as a wired connection to your PC would make sense to me.
Perhaps it doesn't have anything and it runs off of batteries. Either way, we need some hard evidence.
« Reply #23 on: Wed, 10 December 2014, 22:56:37 »
It was not a misunderstanding.
This is a major problem with the world. People are far more offended by abrasive raw truth than they are by nice-mannered fake people and liars. It should be the other way around.
I'm not calm, collected, and polite, but I'm honest. Maybe that's not worth anything to anyone here, though.
« Last Edit: Wed, 10 December 2014, 22:58:22 by clickclickclick »
Offline FrostyToast
  • Litshoard
« Reply #24 on: Wed, 10 December 2014, 23:08:38 »
If I was an "honest" person and I spoke my thoughts out to everyone, you would just hear me screaming about how I hate every ****ing person in this world.
Although at the end of the day, none of that "honesty" is right at all. Rarely any of these people if at all are bad and telling them what I truly think of them would just cause unnecessary harm.
Myself, and many others included, if they were speaking out their minds, would just call a bunch of people *******s when they're not even close to being *******s.
Filtering oneself with propriety and ritual behavior is what keeps us in line and can actually place us closer to the truth.
Also, please control yourself and don't use unnecessary jabs at people to try and get your point across.
It never works and people will often react with defense mechanisms, or rather "arrogance" for lack of a better definition.
It's not hard to get a point across without being abrasive, and is in fact easier and much less harmful.
Offline Sygaldry
  • Edema Ruh
« Reply #25 on: Thu, 11 December 2014, 00:57:54 »
  :rolleyes:
Dude, I was trying to be civil but you are seriously pushing my buttons.
No, I did not mean the initial eyeroll, but thanks for teaching me that there is an eyeroll emoticon on this forum.
Now that I know what it is, I can use them excessively where I see fit.
 :rolleyes: :rolleyes: :rolleyes: :rolleyes: :rolleyes: :rolleyes: :rolleyes: :rolleyes:
Also, at this rate no one will want to see your comparison of the two boards because like you said, no one likes a "jerkwad".
Ask anyone who has bought anything from NCIX. Their prices are in CAN dollars.
83919-083921-1
Note I pricematched NCIXUS price to NCIX Canada and they accepted.
Google convert 101 CAN to USD and you get 88 dollars USD.
I've purposely left my order number in the pictures so you can go online and check the status yourself.
If I'm a pathological liar then I'm out of character in posting something that's true; yes, I bought a Minila Air for 88 dollars brand new.
Life tip: baseless accusations are never appreciated.
« Last Edit: Thu, 11 December 2014, 02:25:18 by Sygaldry »
null
Offline FireInc
« Reply #26 on: Thu, 11 December 2014, 01:14:41 »
Out of curiosity, why wasn't the KBT Pure Pro an option?
The only real difference I can find is a slightly different fn layout and you trade the ability to swap out the space bar for the feature of being able to reprogram the board and key layout hardware-side. Well, that and IMO the Pure Pro's casing is much, much cleaner looking than the Filco's.
-edit-
That is, in context of the Minila. There's a good number of differences between it and the Ducky Mini; but I'd still argue that the Pure Pro is simply a more feature-rich board overall, unless of course bezels(and a more feature-rich LED feature) are your thing.
« Last Edit: Thu, 11 December 2014, 01:21:55 by FireInc »
« Reply #27 on: Thu, 11 December 2014, 05:33:36 »
This is a good post.
« Reply #28 on: Thu, 11 December 2014, 05:34:35 »
Never heard of it.
