Author Topic: I have some original White Alps in my basement. Are they worth anything?  (Read 5944 times)
Offline Shyfe
I have two of them with white alps. One takes a bit to return though and I don't know how to fix it. I also broke about 15 switches while prying them off. It says 2001 on the top left corner of them. I'm pretty sure it's older than that though. I also have an Acer that has black Alps, but clicks like a light white Alps. Anyone wanna give me some advice on what to do with these? Do you think I could trade it for a keyboard with Cherry MX Browns? I ordered a Scorpius M10, but I think I may like the browns better and want to try them.
« Last Edit: Thu, 30 July 2009, 04:17:47 by Shyfe »
HHKB (55g) | IBM SSK | Realforce 87U (55g) | Unicomp EnduraPro | KBT Oni
Offline lowpoly
« Reply #1 on: Thu, 30 July 2009, 05:18:26 »
Welcome to Geekhack.
I guess it would help if you'd provide information found on the labels on the bottom. Pics are good too.
Offline xyzzy
« Reply #2 on: Thu, 30 July 2009, 05:48:56 »
The first board you have could be a Focus FK-2001. If it doesn't have windows keys then the switches are likely Alps original/complicated. Here's some info from Sandy's page: http://sandy55.fc2web.com/keyboard/focus2001.html
The second one probably doesn't have Alps switches, but Acer switches. Externally, they look identical, the differences are inside: Acer's are hammer on membrane.
See some reviews of Acer boards here: http://geekhack.org/showwiki.php?title=Island:4411 and here: http://geekhack.org/showwiki.php?title=Island:6576
IBM Model F62 (Ellipse's) • PFU HHKB Pro Type S Hybrid • PFU HHKB Pro • Leopold FC660C • IBM Model M SSK 1391472 • IBM Model M SSK UNI04C6 • IBM Model M 1391405 (x4) • Cherry MX 1800 Compact (blue Cherry) • Cherry MX 11900 Touchboard (brown Cherry) • Dell AT102W (black Alps) • Apple Extended Keyboard II (cream Alps) • Acer 6312-TA (black Acer) • Unikey KWD-601 (white Cherry)
Offline Shyfe
« Reply #3 on: Thu, 30 July 2009, 06:04:47 »
Yep, they are indeed Focus FK-2001's. Do you think I could trade all 3 of these for something?
Offline lowpoly
« Reply #4 on: Thu, 30 July 2009, 06:31:59 »
You broke the 15 switches (the stems?) on one Focus or combined on both?
Offline Shyfe
« Reply #5 on: Thu, 30 July 2009, 06:36:53 »
On one Focus. I broke a switch on the other Focus which has good return time while tearing off the keys to clean. Then I tried to pull a switch from the other one. I didn't know to do it so I just kept on tearing it off, but the metal part kept breaking.
Offline Shyfe
« Reply #6 on: Thu, 30 July 2009, 06:40:54 »
I'll take pictures in a bit after I charge my camera.. There is also one more keyboard which I don't know what the switch is but it seems like black cherries.
Offline lowpoly
« Reply #7 on: Thu, 30 July 2009, 07:16:40 »
You need a good keycap puller if you want to remove all keycaps. The switches cannot be pulled off. You have to either open or de-solder them. There is plenty of info on this here, try a search.
Offline Shyfe
« Reply #8 on: Thu, 30 July 2009, 09:46:05 »
Alright, I've got the pictures guys.
FK-2001's
Acer
No idea what this is
The back to a Focus membrane one
Offline lowpoly
« Reply #9 on: Thu, 30 July 2009, 10:01:35 »
Thanks for the pics.
The mystery board looks like a Chicony KB-2001. Conductive rubber dome.
Creative de-soldering approach with the Alps switches! Not perfect yet though. Next time try to open the case. You'll see the switch pcb and the soldered switch contacts.
On the Acer your approach would have worked (a rare exception though).
Offline Shyfe
« Reply #10 on: Thu, 30 July 2009, 10:07:36 »
Nice, thanks for the identification. Do you suppose I could trade a combination of these for a Cherry MX Brown?
Offline Shyfe
« Reply #11 on: Thu, 30 July 2009, 10:21:10 »
One of them is pretty consistent all throughout and has good return time. (The one with all switches but one intact) The other one is not so good. There are a few good keys on it. They haven't been used heavily. I think it just got dirty when we stored it. Only one person used computers when we got those and it was my dad and there is no way he wore off all of those.
Offline o2dazone
« Reply #12 on: Thu, 30 July 2009, 11:49:48 »
Your feet look almost as dirty as the keyboard
Offline Shyfe
« Reply #13 on: Thu, 30 July 2009, 12:42:39 »
they're not dirty, it's just the shadow.
Offline o2dazone
« Reply #14 on: Thu, 30 July 2009, 13:02:53 »
my custom stylish skin hides that
Offline Shyfe
« Reply #15 on: Thu, 30 July 2009, 13:23:41 »
post count of 10 rule? i can't tell what you mean by that.
Offline itlnstln
« Reply #16 on: Thu, 30 July 2009, 13:28:37 »
Ripster has a rule that you can't insult new members until they have 10 posts.  Me, on the other hand, if you even step foot in this place, I'll insult you.
Offline o2dazone
« Reply #17 on: Thu, 30 July 2009, 15:10:59 »
I love your feet
Offline lowpoly
« Reply #18 on: Thu, 30 July 2009, 15:55:29 »
Quote from: webwit;105660
What are those switches in the Acer? US layout. This might be a valuable keyboard.
Acer hammer on membrane (clicky).
