Author Topic: NIB SGI AT-101 from USD 25  (Read 6898 times)
Offline xyzzy
« on: Thu, 30 July 2009, 08:33:45 »
IBM Model F62 (Ellipse's) • PFU HHKB Pro Type S Hybrid • PFU HHKB Pro • Leopold FC660C • IBM Model M SSK 1391472 • IBM Model M SSK UNI04C6 • IBM Model M 1391405 (x4) • Cherry MX 1800 Compact (blue Cherry) • Cherry MX 11900 Touchboard (brown Cherry) • Dell AT102W (black Alps) • Apple Extended Keyboard II (cream Alps) • Acer 6312-TA (black Acer) • Unikey KWD-601 (white Cherry)
Offline CX23882
« Reply #1 on: Sat, 01 August 2009, 11:01:26 »
Are all beige ones the "one's that aren't really PS/2"?
Offline liorde
« Reply #2 on: Mon, 03 August 2009, 15:39:05 »
I have this exact keyboard.
It is PS2 connection.
Although they have a version with SGI's proprotary sqaure connection.
Offline megarat
  • (Not My Real Name)
    • http://www.megarat.com
« Reply #3 on: Mon, 03 August 2009, 17:29:58 »
Quote from: ripster;106606
Before buying you may want to check the serial numbers.  Not all are compatible.
Technically they're model numbers, not serial numbers, but the message is otherwise correct.
The SGI proprietary port looks just like PS/2, so a functional visual inspection won't be good enough.
Home/Work:  Custom Filco FKBN87Z/EB and SGI 041-0136-001 chimera (original white ALPS, not simplified, rubber-dampened)
Gaming:  Wolfking Warrior with custom-colored layout, HHKB Lite 2 (Rubber dome)
Offline megarat
« Reply #4 on: Mon, 03 August 2009, 17:42:10 »
BTW, I inquired with the seller about which kind of keyboard this is.
Offline liorde
« Reply #5 on: Mon, 03 August 2009, 22:53:23 »
Quote from: webwit;106676
Nice cat.
Thank-you..!
He will appreciate the compliment.
Found on the brink of death, on the street at 7 days of age, June 2001... still going today :amen:
Offline Special K
« Reply #6 on: Tue, 04 August 2009, 11:33:29 »
What switches do the SGI AT101's use?
Filco FKBN104MC/EB
Filco FKBN104M/EB2
IBM Model M 1391401 - 11/13/87
Quote from: ripster
LOL - we're on post #163 of this mega-thread and you've gone from"keyboard n00b" to "keyboard sn0b".  We've done our job.
Offline itlnstln
« Reply #7 on: Tue, 04 August 2009, 11:41:25 »
Quote from: Special K;106892
They use dampened, tactile, non-clicky Alps.  Basically, they are the dampened version of the Dell AT101.  Other than the dampers, they are the same switch.
Offline Special K
« Reply #8 on: Tue, 04 August 2009, 11:44:53 »
Quote from: itlnstln;106895
What exactly do the dampers do?  What is there effect on the key's action?  Do they make it require more force to press?
Filco FKBN104MC/EB
Filco FKBN104M/EB2
Quote from: ripster
Offline itlnstln
« Reply #9 on: Tue, 04 August 2009, 11:53:57 »
http://park16.wakwak.com/~ex4/kb/tech_alps_bigfoot2.htm
If you look at the pics on this page, the dampers are the black, rubber, dog-bone looking things on the side of the slider.  This creates a soft, silent landing as the switch is bottomed/topped out.  Instead of the loud clack you mormally get with an Alps switch, you get a nice, quiet landing.  There are some sound clips in the sound clips forum of damped Alps (specifically, the SGI).
Offline bitflipper
« Reply #10 on: Tue, 04 August 2009, 14:03:43 »
97.8% feedback = automatic fail
He has another SGI board with this auction, but it's Silicone Graphics?
Offline itlnstln
« Reply #11 on: Tue, 04 August 2009, 15:06:28 »
Quote from: bitflipper;106950
I'd post something NSFW right now, but... well... I'm at W.
Offline itlnstln
« Reply #12 on: Tue, 04 August 2009, 15:09:22 »
Quote from: ripster;106968
I was told my Model M was used by Bernie Madeoff (sic).
Strong.
Offline D-EJ915
« Reply #13 on: Wed, 05 August 2009, 05:51:57 »
Quote from: ripster;106941
Is there an easy way to tell this?
yes, it's smaller and has notched edges at the back
http://liquidationonly.com/pics/silcongray.jpg
I recall the Indigo keyboard looking different than the AT101 so I don't think you have to worry about that.  There's probably more information over at the nekochan.net forum
« Last Edit: Wed, 05 August 2009, 06:12:58 by D-EJ915 »
Offline ch_123
« Reply #14 on: Wed, 05 August 2009, 06:07:40 »
Quote from: D-EJ915;107083
Looks like a SGI version of the Unicomp Spacesaver...
