Author Topic: The last personal message from your IP was less than 5 seconds ago.  (Read 10910 times)
EVERY SINGLE POST.
even damn PMs! it's getting annoying.
Offline bueller
  • MX baller
  • Church of the Ergo Clear
Re: The last personal message from your IP was less than 5 seconds ago.
« Reply #1 on: Fri, 12 December 2014, 22:11:27 »
Ah so I guess I just double PM'ed someone.
« Reply #2 on: Fri, 12 December 2014, 22:13:39 »
i just tried to reply to a PM 5 times until i just closed the tab and reopened it and it finally went through.
check my sent messages, no PMs sent.
Offline bueller
  • MX baller
« Reply #3 on: Fri, 12 December 2014, 22:15:54 »
SMF for the win!
/sarcasm
Offline Ngt
« Reply #4 on: Fri, 12 December 2014, 22:37:20 »
Had the same problem for a post. I had to write it twice because the message's body got lost after the error message. And had to close the navigator for it to work again.
Offline heedpantsnow
  • Old enough to know better
« Reply #5 on: Fri, 12 December 2014, 22:42:00 »
I closed the browser and it worked fine after thay
I'm back.
« Reply #6 on: Sat, 13 December 2014, 11:34:23 »
just count to 12
the server sees everyone as the same user, so it just means someone is trying to post at the same time you are.
just gotta wait for imav to do something about it basically
« Reply #7 on: Sat, 13 December 2014, 12:36:00 »
I've been getting this with most of my posts it is really getting old..
Offline Ngt
« Reply #8 on: Sat, 13 December 2014, 13:00:40 »
I got it only since this week.
Offline Coreda
« Reply #9 on: Sat, 13 December 2014, 18:58:06 »
God damn this is annoying. The trick is to go into Offline mode in the browser then go back to see your post, otherwise the page returns an error and you lose the post.
Quick posting doesn't appear to have this bug.
Offline swill
  • builder & enabler
    • swillkb.com
« Reply #10 on: Sat, 13 December 2014, 19:40:42 »
If everyone is getting the same IP through the firewall or load balancer I would suggest that iMav use the "x-forward-for" header to get the real source IP through the perimeter device and then use that in the forum. Most software would support the "x-forward-for" header without modification.
« Reply #11 on: Sun, 14 December 2014, 17:29:30 »
I got it a couple of minutes ago, and I'm pretty sure I'm the only one here who would be posting on GH.
I've just got to learn to copy my post before I send it, then I can just paste it back in as the text is usually lost when I get the spurious warning message.
Offline Ngt
« Reply #12 on: Sun, 14 December 2014, 18:13:39 »
I didn't have that reflex ... :'(
« Reply #13 on: Sun, 14 December 2014, 20:34:15 »
If I quote a post it doesn't get lost. FYI.
« Reply #14 on: Sun, 14 December 2014, 20:46:14 »
I have lost quoted posts, particularly when I was catching up on new Members Saturday night.
And I have lost quoted PMs too.
In both cases where I typed my response under the quote.
« Reply #15 on: Sun, 14 December 2014, 21:09:06 »
Huh. I kept a non-quoted post just now, so maybe it's unrelated.
I dunno when it'll be fixed, but hopefully soon.
Offline MGH
« Reply #16 on: Sun, 14 December 2014, 23:07:59 »
Just got the error when posting a reply :(
Offline FrostyToast
  • Litshoard
« Reply #17 on: Sun, 14 December 2014, 23:35:15 »
This only started happening just recently. I have no idea what was changed if anything at all.
Most of the time my stuff gets saved, but it is really awful when I lose my stuff, especially when on my mobile.
Quote from: elton5354
Offline Mandolin
  • Crystal Connoisseur
« Reply #18 on: Mon, 15 December 2014, 00:19:17 »
Just lost a handful of PM's because of this lie!
Artisan keycap Maker
Working on
- Custom keycaps
- Artkeycaps V2 sale
- Due chihuahua and demoncat orders
- Boobiecaps
- Optic fiber embedded keycaps
- Others
Offline Coreda
« Reply #19 on: Mon, 15 December 2014, 00:23:10 »
If you're on a desktop hit this and then back, at least on Firefox it retains the text input of the previous page. Otherwise it's super frustrating.
Offline Ngt
« Reply #20 on: Mon, 15 December 2014, 07:34:59 »
Never had the problem on my phone but only on my desktop. Maybe I was lucky, I don't know.
Offline Ngt
« Reply #21 on: Mon, 15 December 2014, 10:31:57 »
God damn it! Now I have "Your last search was less than 5 seconds ago. Please try again later" ...
  • Live long and prosper
« Reply #22 on: Mon, 15 December 2014, 10:34:04 »
I got this when logging in this morning, "The last login from your IP was less than 2 seconds ago, please try again later"
Fix this damn 10.20.30.1 IP issue pls, ty
« Last Edit: Mon, 15 December 2014, 10:41:02 by Computer-Lab in Basement »
tp thread is tp thread
Offline iMav
  • geekhack creator/founder
« Reply #23 on: Mon, 15 December 2014, 11:49:58 »
Fixed.  We did some header modifications to get things logging properly, initially.  However, this was out the window once we swithed to SSL.  We are now logging the correct forwarded client IP.
« Reply #24 on: Mon, 15 December 2014, 11:53:13 »
Thank you iMav! :thumb:
Offline swill
  • builder & enabler
    • swillkb.com
« Reply #25 on: Mon, 15 December 2014, 13:27:41 »
Cool.  Good Job...  :)
Offline Ngt
« Reply #26 on: Mon, 15 December 2014, 14:50:56 »
Offline Coreda
« Reply #27 on: Mon, 15 December 2014, 21:28:28 »
So it's fixed? Nice one iMav :)
« Reply #28 on: Mon, 15 December 2014, 22:57:13 »
thanks for the fix, locking the thread now.
