Author Topic: poorly unicomp model m type - spacebar not working  (Read 5486 times)
Offline dsb
« on: Sun, 14 December 2014, 13:37:47 »
anyone have any info on where to get one of these fixed? - fixed you say! - it's a keyboard, get another.
maybe but otherwise it's fine.
everything functions except the spacebar doesn't work - press it and it clicks as you expect, bounces back, but no luck.
anyone think it's likely to be too expensive to fix or .... ?
these things are rare here in the uk so i'd really like to make it work - my existing real model m has a few less than responsive keys - maybe I've actually made it to 50 million keypresses......
Offline Xonar
  • Cathode Ray Tubes
    • Winnebago
Re: poorly unicomp model m type - spacebar not working
« Reply #1 on: Sun, 14 December 2014, 13:40:22 »
The stabilizer is probably not seated correctly. Take the spacebar off and make sure the little metal bar that's attached to it is seated properly into the plastic tabs that you'll find under the spacebar.
« Last Edit: Sun, 14 December 2014, 13:42:39 by Xonar »
IBM Model M SSK Industrial (Mopar) | Ellipse Model F77 (Industrial) | IBM Model F XT 5291 Bigfoot x2 | Unicomp UN4KPHA JP Spacesaver M | IBM Model M 3270 APL 122-Key | SHARP X68000 | Silicon Graphics AT-101 |  Samsung TH-5539 FAME Blue Alps | IBM Japanese Pingmaster | IBM Model M 1392595, 6/4/1990 | IBM Model M 1391401, 2/2/1988 | Lexmark-branded 1398601 Model M, 8/18/1995 | Apple Extended Keyboard II | Unicomp UB40T5A 122-Key, 5/20/2011 | Sun Type 4 | Sun Type 5c | DEC LK-401AA
Offline dsb
« Reply #2 on: Sun, 14 December 2014, 15:09:08 »
no luck im afraid.
tried a bit more experimenting - took the key off and used a tiny screwdriver to directly press the contact down through the spring - no dice.
tried the same with another key - worked.
so I guess the contact itself has somehow died.
ho hum.
Offline Xonar
  • Cathode Ray Tubes
    • Winnebago
« Reply #3 on: Sun, 14 December 2014, 15:24:08 »
Sorry, I admittedly didn't read your question very well.  :-[ If it's actually clicking, then it probably is the contact that's bad. You could try replacing the entire key assembly, or it might be that there's a lot of broken rivets around the area of the spacebar. The fix for that is bolt-modding, of course.
Offline E TwentyNine
    • Some of My Keyboards
« Reply #4 on: Sun, 14 December 2014, 15:47:29 »
You're certain everything works except the spacebar?
Have you tested the keyboard with this?: https://geekhack.org/index.php?topic=34670.0
Offline RoflCopter4
« Reply #5 on: Sun, 14 December 2014, 17:16:29 »
Contact Unicomp. In my experience their customer service is excellent.
Acer KB-101A with Blue Alps | HHKB Pro 2 | '85 122 Key IBM Model F | '86 1390131 "Silver Label" Model M | AEK M0115 with Orange Alps | Focus FK-2001 White Alps | Chicony 5181 with SMK "Monterey Blue" Switches | Dell AT101W | Unicomp "Ultra Classic" | Razer Blackwidow 2013
Offline orihalcon
« Reply #6 on: Wed, 17 December 2014, 01:25:09 »
no luck im afraid.
ho hum.
Bet the foot inside is cracked or suck.  That's really all there is left at this point other than the membrane being bad which is unlikely.
Offline Defect
« Reply #7 on: Wed, 17 December 2014, 13:31:51 »
Have this issue as well.  Came back to my old apartment and tried to get on the computer there before packing up.  Suddenly the space bar doesn't work anymore.
Thinking of cracking it open when I have time off for the holidays.  I'll let you know if I do and if I find anything.
Offline ime1729
« Reply #8 on: Wed, 17 December 2014, 16:23:00 »
Get it warmed up (turn a light on or something like that) and see if it still works then.
My keyboard has keys that don't work under 10 C
Offline berserkfan
« Reply #9 on: Wed, 17 December 2014, 19:18:59 »
Take the space bar off anyway, and reseat it. Sometimes it will click, but due to movement of the spring inside, the hammer underneath doesn't move properly so no real actuation of key.
