Author Topic: Looking for a A.87 compatible housing  (Read 2658 times)
Offline henz
  • What?
« on: Mon, 15 December 2014, 15:21:19 »
As topic describes. Currently im not interested in Sprits cases. But anything else might be of interest.
Offline Signature
  • master of puppers
  • * Marketplace Moderator
  • snoozing
Re: Looking for a A.87 compatible housing
« Reply #1 on: Mon, 15 December 2014, 16:16:59 »
gon?
Offline henz
  • What?
« Reply #2 on: Tue, 16 December 2014, 01:30:03 »
gon?
A.87 does not fit in a GON, Only the the old ones GON NS87. And those are kinda hard to find.
There is a TX87 IC currently which will do the trick, im just exploring my options.
Offline zennasyndroxx
  • It's good to be back!
« Reply #3 on: Tue, 16 December 2014, 02:54:13 »
gon?
looking for full alu?
just an alternative:
http://www.hanaacryl.com/product/?no=261&s_category=148&search=YToyOntzOjg6ImNhdGVnb3J5IjtzOjM6IjE0OCI7czo4OiJwYWdlc2l6ZSI7aToyMDt9
full acrylic.
Offline henz
  • What?
« Reply #4 on: Tue, 16 December 2014, 03:56:43 »
gon?
full acrylic.
I would like to use a SS plate. Thats why im not considering Sprits, But thanks for the option
Offline Lastpilot
  • Power stance
« Reply #5 on: Tue, 16 December 2014, 13:00:49 »
Buy used:
- LZ series board [I know LZ-S and LZ-GH will fit for sure]
- GON NS87 [like you said harder to find now - and its alu not SS]
- Duck Orion [also hard to find but has SS plate]
- Duck Unicorn [basically Orion, but acrylic with SS plate] - even harder to find than orion LOL
- EXE image from yuktsi - not sure if SS or aluminum plate, but definitely metal - also hard to find
Is there any reason you are limiting yourself to the A.87?
« Last Edit: Tue, 16 December 2014, 13:07:08 by Lastpilot »
Offline henz
  • What?
« Reply #6 on: Tue, 16 December 2014, 13:41:04 »
Buy used:
Because i have one without a case :)
Thanks for the options, let me see what i can find in the classfieds
Offline munch
« Reply #7 on: Tue, 16 December 2014, 19:42:04 »
you could e-mail kaliet at http://22kbd.com/ and get something custom cut for you, I think he can make it happen.
it will probably cost you in the 1500-2000 SEK range though. and it might take a month or so, since he is away for work right now.
Offline Evo_Spec
  • (╯°ヮ°)╯︵⌨
« Reply #8 on: Wed, 17 December 2014, 02:23:08 »
gon?
full acrylic.
Don't mean to step on your thread but does anyone know how to actually order from this site? it's quite a bit cheaper than from GON himself unless there's something i'm missing.
GON NerD TKL DTA Edition
Offline henz
  • What?
« Reply #9 on: Wed, 17 December 2014, 03:23:06 »
Thanks, ill look into that.
Offline Evo_Spec
  • (╯°ヮ°)╯︵⌨
« Reply #10 on: Thu, 18 December 2014, 07:16:43 »
gon?
full acrylic.
Does anyone know about this? cause GON's limited PCB is on sale now so i really need to know since i don't think i'll be buying if i can't order from here.
