Author Topic: my snobby mousepad, I guess.  (Read 3295 times)
Offline nanu
    • http://T-T.be/portal
« on: Fri, 31 July 2009, 16:50:15 »
It turns out that the wrist rest I added, which extends the entire length of the keyboard tray on my desk, makes it uncomfortable to use the mouse.
To re-elevate the mouse I made this thick mousepad that I'd rather call a "mouse elevator."
The polypropylene is translucent enough to allow for occasional artwork/photo festivity :playball:
I assume it doesn't work for an optical mouse but it works fine for my laser mouse; it now sits ½" higher, which is just short of the wrist rest, but it's all good.
Effectively, the keyboard is now sunk in the tray, after I either adjust my chair upwards, or quit slouching as much.
Offline sixty
    • http://deskthority.net
« Reply #1 on: Fri, 31 July 2009, 17:00:08 »
Very cool. The rubber feet look very nice. The only ones I could ever find locally are not really of good quality and I would probably need like six of them at least.
