Author Topic: Ergo mice?  (Read 5455 times)
Offline yasuo
  • spanengan puyeng newbie
Ergo mice?
« on: Thu, 18 December 2014, 09:26:13 »
I got my hand problems today, the feel pins and needles,really rigid and tremble to hold objects,after i searching, i find may cts
but when my hand healthy, what good choice ergo mice with less movement and no fly (my hand touched the table)?
thanks
« Last Edit: Thu, 18 December 2014, 09:28:50 by yasuo »
Logitech MK220 Colemak DH
Offline naz
Re: Ergo mice?
« Reply #1 on: Thu, 18 December 2014, 10:11:15 »
Hello,
Most ergonomics mouse (such as the evoluent) don't allow wrist movement, so you have to move it by rotating your elbow and shoulder. This is fine for most people but i never liked it.
What i use is de DXT (wireless), wich is really sensitive so you just move it with your fingers (no wrist, no elbow and no shoulder). One warning, i have small hands, so that may be a factor on why i like it so much.
Regards!
Offline vivalarevolución
Re: Ergo mice?
« Reply #2 on: Thu, 18 December 2014, 10:21:27 »
I am a fan of the Mousetrapper:
http://www.thehumansolution.com/mouse-trapper-advanced-mouse.html
http://www.thehumansolution.com/mousetrapper-flexible-mouse.html
And the Rollermouse:
http://ergo.contour-design.com/
Both devices allow the user to keep their hands in the normal typing position while utilizing the underused thumbs for mouse movement.  They also double as palm rest.  I plan to offer a thorough review of the Mousetrapper and Rollermouse when I sell this darn Maltron and reinvest the funds in a Rollermouse.  I find that the devices reduce the strain on my fingers and wrist caused by most mice, including trackballs.
Offline Sc0tTy
  • Ergo enthousiast
Re: Ergo mice?
« Reply #3 on: Thu, 18 December 2014, 12:28:35 »
I use a Wacom Bamboo Pen & Touch v3 at work and at home. Very ergonomic!
Just switch it to mouse mode and you'll never want to go back, I've been pain free for years now. Returning back to a mouse and it quickly comes back.
They have a new model out and its renamed to Intuos Pen & Touch: http://www.wacom.com/en-nl/products/pen-tablets/intuos-pen-and-touch-small
I'm thinking of replacing my current ones with the new ones and taking the larger model
« Last Edit: Thu, 18 December 2014, 12:30:07 by Sc0tTy »
1x ErgoDox EZ
2x Truly Ergonomic Keyboard 229
2x Kinesis Freestyle V3-VIP
2x Bamboo Pen & Touch (Mouse replacement)
2x Salli Swing
1x Herman Miller Aeron
Re: Ergo mice?
« Reply #4 on: Thu, 18 December 2014, 14:00:10 »
I have been recommended using of those before.  Might have to try it one of these days.  Seems like it would be a good fit with ergo boards, because the Rollermouse and Mousetrapper are best used with standard flat boards.
Offline Sc0tTy
  • Ergo enthousiast
Re: Ergo mice?
« Reply #5 on: Thu, 18 December 2014, 15:02:15 »
Yeah
Yeah its great. A lot better than those upright mice and I prefer it to those rolerbars etc. I found this a lot more precise and quicker.
But you'll want to have a narrow keyboard like TECK or Kinesis Freestyle if you use it
1x ErgoDox EZ
2x Salli Swing
Re: Ergo mice?
« Reply #6 on: Thu, 18 December 2014, 16:48:41 »
Yeah
The Rollermouse and Mousetrapper do lack in precision, that is the most annoying part.  Trade-offs, trade-offs.
Offline hoggy
  • * Moderator
Re: Ergo mice?
« Reply #7 on: Mon, 22 December 2014, 06:51:21 »
Windows has an option to automatically move the mouse pointer to a default button when a form opens - takes some getting used to, but once you've got used to it, turning it off sounds stupid.
What about using your other hand for a while?
Offline Sc0tTy
  • Ergo enthousiast
Re: Ergo mice?
« Reply #8 on: Mon, 22 December 2014, 08:43:22 »
I used that for a while but for me it was annoying because this meant any click would submit. Had quit a few problems with that...
1x ErgoDox EZ
2x Salli Swing
Offline yasuo
Re: Ergo mice?
« Reply #9 on: Mon, 22 December 2014, 23:14:51 »
Hello,
Regards!
interisting dxt ambidex model can change another hand anytime, usually i use 500dpi optical
i quite interest with rollermouse for long time interest if u make the review rollermouse compare moustrapper
btw i really dont like touch model like moustraper such touchscreen, touchpad, its very not accurate to me
its looks comfort but but eating place for dailymouse
yeah, i've using other hand for a while my mouse can setting rh/lh side with firmware
Offline pnutster
Re: Ergo mice?
« Reply #10 on: Sat, 27 December 2014, 12:18:17 »
Hi,
Having a lot of tendon problems myself, I have focussed on ergonomic products the past few years.
Ergonomic keyboards and mice are a very personal match. What works for me are:
- Apple trackpad.
- Old model trackball -  I use the Logitech Cordless Trackman FX Optical Trackball - there's 2 older versions around: http://support.logitech.com/en_us/product/189 and http://support.logitech.com/en_us/product/cordless-trackman-fx - hard to get, but there are still good offers around on ebay once in a while.
What I think is important in a mouse / trackball is that is "forces" you into a more natural "handshake" position. I tried vertical mice, but personally that doesn't work for me, but maybe it does for you.
Kinesis Advantage
Apple TrackPad
Offline hoggy
  • * Moderator
Re: Ergo mice?
« Reply #11 on: Sat, 27 December 2014, 12:50:27 »
A bit of variety (several different mice) might help.
