Author Topic: Poker X esc. key not working and deactivating LEDʻs  (Read 2327 times)
Offline Dakine234
  • Live, Love, ALOHA
« on: Thu, 18 December 2014, 21:55:09 »
Aloha,
I just got a Poker x keyboard, and there are 2 minor issues with it.  First, the escape key types ` instead of activating the escape function.  Next, iʻm trying to deactivate the alt + spacebar combo that turns on the bottom row LEDʻs.  Does anyone have any advice on fixing this?  Any help is greatly appreciated!
Mahalo
Poker II mx blues + Custom Poker X with mx clears, blues and old blacks
Offline FrostyToast
  • Litshoard
Re: Poker X esc. key not working and deactivating LEDʻs
« Reply #1 on: Thu, 18 December 2014, 21:56:14 »
Aloha,
Mahalo
ctrl + q for the tilda to esc
Cut the LED leads off (forgot what they're called) or desolder.
EIDT: TRACES! THEY'RE CALLED TRACES, NOT LEADS! Nailed it.
« Last Edit: Thu, 18 December 2014, 22:01:30 by FrostyToast »
Quote from: elton5354
Offline Dakine234
  • Live, Love, ALOHA
« Reply #2 on: Fri, 19 December 2014, 01:07:05 »
Aloha,
Mahalo
Thanks!  Got the esc key working again, still looking for options w/o resoldering, i think theres a way.
Offline FrostyToast
  • Litshoard
« Reply #3 on: Fri, 19 December 2014, 01:15:13 »
Aloha,
Mahalo
You might be able to flash the firmware.
If you desperately want, you can as I said, cut the traces on the PCB. This will just cut off the power that the LEDs get.
This will of course leave permanent damage, but it can be fixed again with a little bit of work.
Offline Dakine234
  • Live, Love, ALOHA
« Reply #4 on: Fri, 19 December 2014, 01:16:48 »
Aloha,
Mahalo
Sounds good, iʻll keep that in mind, if theres no easy fix i can do without it and adjust, just figured if anyone would know its the guys on this forum.  Thanks for the help!
Offline FrostyToast
  • Litshoard
« Reply #5 on: Fri, 19 December 2014, 01:20:06 »
Well if you want, there should be some nice people on the forum who can at least desolder your board for the cost of shipping.
Four LEDs doesn't take long at all.
Offline Dakine234
  • Live, Love, ALOHA
« Reply #6 on: Fri, 19 December 2014, 01:49:43 »
I think iʻm fine for now, gonna look into it a little more this weekend when I have more time, and if not iʻm sure i can likely find someone.  Thanks for the advice and happy holidays!
