Author Topic: Filco Zero white alps variant  (Read 5420 times)
Offline Adriel
  • sample text
« on: Thu, 18 December 2014, 23:32:02 »
So the other day I was browsing through carousel and found this deal
Which one person was selling his used Filco Zero white alps switch for 50 dollars. Can I know how does white alps switches feel in comparison with the cherry mx switches and whether 50 is worth it for a Filco Zero.
ES-87 Gateron Red | Pok3r Blue
Offline Hak Foo
  • Make America Clicky Again!
Re: Filco Zero white alps variant
« Reply #1 on: Thu, 18 December 2014, 23:38:28 »
The ALPS version of the Zero was not well liked.  It has one of the later-generation ALPS clones (sometimes called XM) that aren't too popular.
White ALPS in general are weight-wise like MX Green, with some of the later clones closer to Blue.  The tactility is much stronger, and the sound is decidedly less plasticky.
You might also consider getting it as a baseline to swap in your favourite ALPS switches (i. e. new Matias ones)-- modern layout and a clean case are worth something.
Overton130, Box Pale Blues.
Offline Jokrik
« Reply #2 on: Fri, 19 December 2014, 01:18:33 »
I do own a Filco with white Alps, or as far as I know it's called "****" white Alps
It's a very clicky switch with high "ping"  noise (louder than my ssk). It's pretty rare though and I know some people would kill to get that Filco "fukka"
Offline jacobolus
« Reply #3 on: Fri, 19 December 2014, 01:28:33 »
Personally I would totally buy that for $50, because (a) it’s easy to swap the switches out for something nicer, and (b) I want to get my hands on a few of those switches for a community switch tester I’d eventually like to build.
Offline Wildcard
  • When caffeine isn't enough
« Reply #4 on: Fri, 19 December 2014, 01:31:42 »
I'm with you on this. Simple switch swap and now you have alps on a modern board. I know I'd pick it up if it was in my area.
Offline Defect
« Reply #5 on: Fri, 19 December 2014, 07:02:19 »
Pick it up for me.  50 is a great deal if its in nice condition
Offline strict
  • TKL Zealot
« Reply #6 on: Fri, 19 December 2014, 07:17:34 »
I was about to post the same thing. I would definitely take it so that I could swap in something like Matias quiet-click switches.
Offline Daniel Beardsmore
  • RIP
    • Boring twaddle
« Reply #7 on: Fri, 19 December 2014, 14:48:07 »
I don't know how anyone could misread Fuhua as "fukka". I have to wonder if that is a myth used to cover derision, because the naïve reading would be "foo-hoo-er" instead of the correct "foo-hwa". Also, their name is Forward Electronics.
There are two versions. The one with Xiang Min KSB-C ("XM") switches was unpopular because the switches are ludicrously stiff.
The version with Alps SKBM White switches (made by Forward) had a controller problem that caused transposition errors, as I recall. (Why only the SKBM version had that problem, I don't know — I don't know much about its production history.)
It's a nice keyboard otherwise. I had the XM version and it was great aside from needing jackhammers for fingers.
Bore Awards
Offline Magna224
« Reply #8 on: Sat, 20 December 2014, 00:51:46 »
All the Filco Zeros I've seen for sale on the classifieds have been snatched up straightaway. I even tried to buy one for like a month back in the day for $100 and didn't find any sellers. I would buy it if someone offered it to me for $50.
Offline dante
« Reply #9 on: Sat, 20 December 2014, 09:12:51 »
I tried Tipo33's Filco Zero w/ XM's at a Chicagoland gathering; and I have to say the 'dislike' for these is a little unwarranted.  No, it was not my favorite switch but it was not as terrible as people make them out to be.
« Reply #10 on: Sun, 21 December 2014, 09:24:05 »
After looking for over a year and seeing a couple go by in the high-$100-low-$200 range, I lucked into an "irregular" one about half a year ago for about $120.
Alps TKL boards are rare, and I would assume that the overwhelming majority of people who buy Filco Zeros or Ducky 1087XMs today intend to transplant better switches into them. I would say that the low-$100s is about the going rate for the Ducky, and the mid-high-$100s for the Filco.
PS - does anybody have a spare Ducky 1087 top cover for sale or trade?
- D Trump 2026-10-24
  • RIP
    • Boring twaddle
« Reply #11 on: Sun, 21 December 2014, 09:31:34 »
Low-$100s for a Ducky? You kidding me? The only thing those seemed to be good for is the switches :-P
I guess more people had good experiences with Ducky 1000-series keyboards than the forum chatter would suggest.
Bore Awards
« Reply #12 on: Tue, 23 December 2014, 09:35:46 »
That is some kind of joke, isn't it?
Those green XM switches were abominable, I tried to sell them cheap for a long time, I think Jacobolus finally bought them for the springs or something.
What are people supposed to do if they want a TKL Alps board? I put orange Alps in my 1087XM and topped them with Apple caps (as much as possible) and ended up with a nice little keyboard.
  • RIP
    • Boring twaddle
« Reply #13 on: Tue, 23 December 2014, 12:18:06 »
I've never owned one (I only do ISO, though I did have an ANSI Filco Zero XM) but based on what I've read in various topics, the switches aren't too bad (not great, but not terrible) and they seem to be the only part of the keyboard that doesn't fail. That's what confused me: since everything else on those seems to break or die, why would you want to put donor switches into one?
— Shirl.
Bore Awards
« Reply #14 on: Tue, 23 December 2014, 12:43:05 »
To be honest, I have not put all that much use on it. It may fail sooner rather than later.
I bought the Ducky because I had been trying to find a Filco Zero for quite a while with no success. Naturally, shortly after I completed the project I lucked into the Filco. I would sell the Ducky except that the top cover is missing. I have it painted a nice pebbled black but it is probably worth more to me than someone else would pay me for it.
The choices for TKL Alps are pretty limited. Maybe one day I will find and be able to afford a Kingsaver.
Offline dante
« Reply #15 on: Tue, 23 December 2014, 12:46:08 »
I've been in communication with KBP.  They are slammed with work right now but have been told one of their Engineers is in the process of converting the V80 PCB to dual Alps/MX compatibility.  Have no ETA but for sure won't hear a peep until around April.
Offline jacobolus
« Reply #16 on: Tue, 23 December 2014, 13:13:15 »
I feel like I’ve seen some threads of people who cut down a full-size board (Dell AT101 or something), replaced the controller with a Teensy, and made a new case.
Offline terrpn
  • Alpha Geezer
  • - Buy Vintage -
« Reply #17 on: Tue, 23 December 2014, 13:27:42 »
i have the ducky with green alp (clones), but to be honest i can put up with the switches better i can with the cable.............always afraid it is going to snap :-\
been looking for a zero for years and they always get snatched up
Luga G80-1865/MX Reds + Dolch G80-1813/MX Blues + G80-3700HQAUS + DK9008G2 Pro/MX Browns Thick PBT + DK9008G2 Pro/MX Clears Thick PBT +  QFR TKL/Ghetto Greens + Cherry G80-1800/MX Blues + IBM Model M SSK Bolt Modded + IBM Model M + IBM Model F + IBM AT F + Cherry G80-1000 (HAD)/MX Vintage Blacks + Razer BWU/MX Blues + Leading Edge DC2214/Blue Alps + Compaq MX11800/Browns + Chicony 5181/Monterey Blues + Chicony 5161/MX Black Cherry Clone + Focus 2001/White Alps + Chicony 5191/White Futabas + Olivetti ANK27-101 + Dell (Old Logo) AT101/Black Alps + NMB RT8255C+/Black Space Invaders + Unitek K260/Green Alps + Apple M0116/Orange Alps + AEK II M3501/Cream Alps + AEK M0115/Orange Alps + NEC  APC412/Blue Sliders + NEC APC410/Blue Sliders + Omnikey /White Alps + Wang/Yellow Alps (Omrons) + Laser/White SMK + Fame/Blue Aruz + AEK II M3501/Salmon Alps + Zenith ZKB-2R/Green Alps + Wang 724/Orange Alps + DK1087/Green Alps + Zenith ZKB-2/Yellow Alps + Dell Old Logo AT101/Salmon-Pink Alps + Leading Edge AK1012/White SMK's + Magitronic SK-1030/White (Linear) Futaba's + Packard Bell/White (Clicky) Futaba's + Datacomp DFK101/White  Alps + SGI AT101/Dampened White Alps + NMB AQ6RT-72511/Grey Space Invaders (Hi-Tek) + Datacomp/Blue Alps + Phillips 2812/White Space Invaders (Linear) + Dah Yang K251/Vintage MX Blues + Chicony 5161/DS Caps/Vintage MX Blue + Archie-NMB AQ659ZRT-725/Black Space Invader (Tactile) + IBM Model M 71G4644 (RD) Bolt Modded with Soarers Converter + IBM Model M Silver Label 1390131 + Cherry G80-1501/Vintage MX Clears + Focus FK8000/Linear Futabas + Gateway 2000 Anykey Programmable/Maxi-Switch + Dell GY13PVAT101/Dye Sub Caps/Salmon Alps + Chicony 5161/White Alps + AST K0B101/Slider over RD + Qtronix QX-32H + Everex/NMB RT8255CW+ Black Space Invaders-Split Erase + Tandon/NMB AQ659ZRT-101A/Beige Space Invaders + Cherry G80-11903 MNRUS/MX Blacks + Apple IIGS A9M0330/SMK Whites + WYSE PCE/MX Blacks + Chicony 5160AXT/Clicky Futaba + Cherry G80-0528/Vintage MX Blacks + Dell AT101/Linear (Modded) Black Alps+Topre 55g
