Author Topic: Dental Banding the FC660C [Suggestive Content]  (Read 4479 times)
Offline FrostyToast
  • Litshoard
« on: Fri, 19 December 2014, 01:44:52 »
Well here I am typing away on my FC660C after taking it apart and it is very enjoyable. Although I should state that I have actually taken this board apart once before already. The first time around was when I decided to dental band my board, and this time around, it was when I decided that I didn't want to type on ass. Pardon me, I know it's just opinion and everyone has their own tastes, but this is not how keyboards were meant to be used. Actually, no keyboard was ever designed to have dental bands inside of them, but that is besides the point.
For those who don't know what "dental banding" is, it's when you place a dental band, which is pretty much a smaller o-ring, over the stem of a topre switch and this ends up hitting the top of the housing on the upstroke dampening the sound. This ends up doing three things to be more exact. The first is of course that it dampens the upstroke making it much less audible and is cool because on no other switch could you practically dampen an upstroke. The second thing is that it makes the switch feel almost linear, yet not really. The very last thing is that the switch has a reduced actuation point. The last two points result from the fact that the switch is already slightly depressed from the dental band in between the stem and the housing.
If you want a straight up verdict out of 10, I shall deliver that up front for those who don't like reading walls of text.
Final Verdict: Edging/10
To be more specific, these domes have a sensation similar to what I imagine the act of edging to be like. I really don't want to explain what it actually is, but you can just look it up on Urban Dictionary if you need to. When you depress a dome on this, it sort of seems alright at first, but then the keys goes off. You know in your mind that it went off, but you really aren't sure about it. You've just put in all of this hard work just to get a sensation that is both disappointing and lacks all of the satisfaction of what you would normally get. Actually, it feels even worse to be more precise, more like edging while limp. You barely even feel anything on the downstroke. You can feel a little bit of something going on, but before you know it, you're done and you have gotten zero pleasure out of the experience and you question whether anything happened at all.
The one thing that differs between this and edging is that I would really suggest you find someone who has done this and likes it and use their equipment to have a go at it. It's just way too much effort for me to suggest to do yourself. Especially since you pretty much have to break the topre switches in order to do this mod.
Quote from: elton5354
Offline Mandolin
  • Crystal Connoisseur
Re: Dental Banding the FC660C [Suggestive Content]
« Reply #1 on: Fri, 19 December 2014, 02:25:37 »
Just to clarify the terms, as I've background in dentistry, dental bands may refer to molar metallic fixations that hug the teeth, used in orthodontics.
You were probably referring to elastomeric dental separators or elastomeric ligatures, also used by orthodontists to either create the space to place the metal bands in molars, or append the metal archwire to the brackets.
They are almost exactly like keyboard o-rings and vary in density, colors, etc
Artisan keycap Maker
Working on
- Custom keycaps
- Artkeycaps V2 sale
- Due chihuahua and demoncat orders
- Boobiecaps
- Optic fiber embedded keycaps
- Others
Offline FrostyToast
  • Litshoard
« Reply #2 on: Fri, 19 December 2014, 02:27:23 »
Yup. They are pretty much o-rings.
Offline Jumpjet
« Reply #3 on: Wed, 24 December 2014, 04:07:25 »
Um...edging...while limp?
Offline bowji
  • Came for the Keycaps, stayed for the community.
« Reply #4 on: Wed, 24 December 2014, 05:03:41 »
I appreciate this. I was debating if the dental mod was worth it once I get my hands on the 660c. Seems like a hassle if I end up not liking it after the tedious job of placing each ring. Is there any other way to silence the board without o-rings or hole punching your own individual dampeners?
               FREE GIRLDC!!     코리안 스레드
Offline FrostyToast
  • Litshoard
« Reply #5 on: Wed, 24 December 2014, 07:00:09 »
Actual type s topre seems like the best bet if you want something silent. It is expensive, however nothing will quite  compare to it.
You can of course use spicebar's method of ironing out landing pads instead if using dental bands. This I hear gives a much better feeling.
Offline bowji
« Reply #6 on: Wed, 24 December 2014, 07:33:06 »
Im guessing youre talking about the landing pads from EK? Do they fit topre switches?
Offline FrostyToast
  • Litshoard
« Reply #7 on: Wed, 24 December 2014, 07:45:23 »
Yes. And they will fit over them. However, before you put them over the stems, you need to fold some paper over them and use a clothes iron. This will make them thinner.
Offline bowji
« Reply #8 on: Wed, 24 December 2014, 07:55:31 »
Gotcha  :thumb:
Thank you sooooo much for the write up n suggestions <3
Offline FrostyToast
  • Litshoard
« Reply #9 on: Wed, 24 December 2014, 09:19:02 »
Gotcha  :thumb:
No problem :thumb:
I hope your modding adventures work out well for you!
