Author Topic: Where can I buy a white PBT space bar  (Read 3342 times)
Offline Bromono
  • Wanabe Cicerone
  • HHKB > Your Opinion
« on: Fri, 19 December 2014, 08:38:10 »
My PBT space bar is warped and won't fit anymore. Where can I buy a replacement?
Offline Belfong
Re: Where can I buy a white PBT space bar
« Reply #1 on: Fri, 19 December 2014, 08:44:24 »
Offline Bromono
  • Wanabe Cicerone
« Reply #2 on: Fri, 19 December 2014, 08:45:59 »
Sorry should have calrified. MX
Offline IvanIvanovich
  • Mr. Silk Underwear
« Reply #3 on: Fri, 19 December 2014, 11:26:58 »
TO match what set (profile), what size? It may be easy or nearly impossible depending on what specifically you need.
Offline Bromono
  • Wanabe Cicerone
« Reply #4 on: Fri, 19 December 2014, 11:53:14 »
It's for a poker 2. Nothing fancy
Offline ideus
  • Björkö.
« Reply #5 on: Fri, 19 December 2014, 13:06:18 »
You may try to get your space bar un-warped. It should be heated with hot water or a hair blower, then mechanically put force to bend it back to its straight position, normally by hand, and by progressive approximation.
One source for a 6.25u near white PBT space bar is to get a PBT set from Bang Good for ~$18 USD.
QTan store had a white PBT space bar but I just checked and it is not there anymore, you may check with QTan its availability though. I am typing with one of them right now, along with my Skull Squadron set.
I hope this may be of help.
Errata: I wrote 6.5 instead of 6.25 sorry.
« Last Edit: Sat, 20 December 2014, 22:44:04 by ideus »
Offline Geroximo
« Reply #6 on: Sat, 20 December 2014, 17:36:50 »
One source for a 6.5u near white PBT space bar is to get a PBT set from Bang Good for ~$18 USD.
At least you helped me. Free shipping to Germany, nice.  :thumb:
Offline Bromono
  • Wanabe Cicerone
« Reply #7 on: Sat, 20 December 2014, 22:34:53 »
Sweet! $18 for a PBT set is awsome. Thanks man:
Offline berserkfan
« Reply #8 on: Sun, 21 December 2014, 11:27:56 »
If you're looking for an OEM profile universal 6.25x I can sell it.
