Author Topic: Looking for red trans caps  (Read 1943 times)
Offline qtrskills
« on: Sat, 20 December 2014, 11:59:55 »
Hello!
I have a logitech G710+ I would like to swap my wasd and arrow key caps to red translucent caps, Ive been on the hunt for such caps with no luck. I was wondering if anyone can help me find these? also is it possible to change the cherry mx keys to other color without pry opening the keyboard? thank you
Offline Lu_e
Re: Looking for red trans caps
« Reply #2 on: Tue, 23 December 2014, 10:24:56 »
Is it possible to change switch type without taking things apart? No, a g710 is plate mount, soldering would be required.
Just say NO to ABS keycaps
