Author Topic: Spacebar 6.25 units Alps Switch Costar-style Stabilizers  (Read 3321 times)
Offline Hypersphere
« on: Sat, 20 December 2014, 18:30:52 »
Does anyone know where to find spacebars that are 6.25 units that take an Alps-mount switch and Costar-type stabilizers?
This is for replacement spacebars for the KBP V60 Matias Mini Keyboard.
Offline jacobolus
Re: Spacebar 6.25 units Alps Switch Costar-style Stabilizers
« Reply #1 on: Sat, 20 December 2014, 18:33:55 »
Signature Plastics will sell you one, but it might not be cheap. Matias could probably sell you one.
Offline Hypersphere
« Reply #2 on: Sat, 20 December 2014, 18:44:22 »
Thanks. I will check out these sources.
BTW, I am typing on my V60 Matias Quiet Click Mini Keyboard right now. I have replaced all the keycaps except the spacebar. The modifiers are from a Dell AT101W -- the stabilizers work just fine, and I like the rounded profile of the mods on the bottom row to match the rounded profile of the spacebar. The alphanumeric keycaps are from a Data General 6311. The stepped CapsLock from the Dell didn't fit in the allotted space, so I have temporarily borrowed the CapsLock from my Ortek MCK-84 until I can find another non-stepped CapsLock (or better, Control) from another donor board.
I am really enjoying the V60 Matias, especially now that I have been able to replace the stock keycaps -- except for that pesky spacebar! However, I should count my blessings, because the spacebar on the V60 is perhaps the quietest spacebar I have ever encountered -- no bottoming-out click or return-stroke clack, and no rattle whatsoever.
Offline ideus
  • Björkö.
« Reply #3 on: Sat, 20 December 2014, 19:17:58 »
That was a long, long journey just to replace a set of a 60% keyboard. That is the issue with ALPS stems. You should be interested in an interest check for a full set of double shot keycaps for ALPS that is now at SP group buy site.
Offline jacobolus
« Reply #4 on: Sat, 20 December 2014, 19:22:17 »
Oy. The stabilized caps (except the spacebar) won’t work on his V60 keyboard. It’s not clear that he has a keyboard that they would work on. If not, why should he be interested?
Offline Hypersphere
« Reply #5 on: Sat, 20 December 2014, 23:39:51 »
It wasn't too difficult to gather up some donor boards, and the stabilized caps from the Dell AT101W worked just fine on the V60. I am typing on it now, with all "new" caps (except for the spacebar), and the stabilized keys are working beautifully -- crisp and even response with not a trace of rattle.
If the stabilized keycaps in the set on the SP IC would not work on the V60, then I suppose I would not be interested. In addition, I would much prefer to have PBT, at least for the alphanumeric keys. On the other hand, for the sake of promoting Alps/Matias switches, I will take a look at the SP IC and possibly cast my vote.
Currently, I am using alpha keys from a Data General 6311. They look like dye-sub PBT, but they feel too smooth (although not clammy like ABS); I have not yet done a salt-water density test or acetone test. Although I am reasonably satisfied with the new face on the V60, I am going to continue looking for some dye-sub PBT caps that have a slight pumice-like texture. I have an AEK, but I don't particularly like the font, shape, or color of its keycaps.
Offline jacobolus
« Reply #6 on: Sat, 20 December 2014, 23:54:59 »
I think most of those Acer 6311 keyboards were pbt dyesubs, but some of them might have been printed ABS. They’re definitely not the nicest dyesubs ever, but a nice option considering how cheaply the keyboards can be obtained on ebay.
