Author Topic: Made my keyboard light up  (Read 3190 times)
Offline obra
  • * Commercial Vendor
« on: Sun, 21 December 2014, 01:37:42 »
Video on youtube: http://youtu.be/wlHVNzhwktc
Hacked together so I can start prototyping effects for the production keyboards.
Offline YoungMichael88
  • HHKB Wannabe
Re: Made my keyboard light up
« Reply #1 on: Sun, 21 December 2014, 03:18:51 »
Whaaaaaaaattt?!!!!!!????!! That's awesome!!!
Offline obra
« Reply #2 on: Sun, 21 December 2014, 08:43:02 »
You wouldn't say that if you'd seen the LED PCBs after I used scissors to cut them apart and reposition individual LEDs to fit ;)
But thanks. We're pretty psyched.
Offline Evo_Spec
  • (╯°ヮ°)╯︵⌨
« Reply #3 on: Sun, 21 December 2014, 08:54:52 »
GON NerD TKL DTA Edition
Offline Lain1911
  • God of the Wired
« Reply #4 on: Sun, 21 December 2014, 08:58:36 »
1337 H4x0rz
Offline bowji
  • Came for the Keycaps, stayed for the community.
« Reply #5 on: Sun, 21 December 2014, 09:02:18 »
Amazing! an ergorave!!   :eek:
               FREE GIRLDC!!     코리안 스레드
« Reply #6 on: Sun, 21 December 2014, 09:12:24 »
That does look very pretty but if I you're looking for feedback before launching a commercial product the side LEDs of the thumb clusters should be "moved" further from the middle.  That is to say in the attached pic the left of the left cluster should be greener and the right of the right pinker.  Might just be config or because they can move, but it's hard to tell from a nighttime shot.
I'm being really picky, how many people will actually use a rainbow effect to notice anyway?  Not me, I'd be busy dialling in my favourite shade of orange :))
Great work!
Offline obra
« Reply #7 on: Sun, 21 December 2014, 23:37:29 »
@suicidal_orange, indeed that video is the near final led PCBs hacked to fit an old thumb layout, aligned with scotch tape and running the default neopixel demo sketch. It. ... Should not have worked at all.
Offline jacobolus
« Reply #8 on: Mon, 22 December 2014, 00:01:23 »
I hope none of your customers have epilepsy.
« Reply #9 on: Mon, 22 December 2014, 00:59:33 »
 :p
« Reply #10 on: Mon, 22 December 2014, 03:47:16 »
In that case I'm sure the final version will be perfect - there's plenty of light even with all the tape!
Offline obra
« Reply #11 on: Mon, 22 December 2014, 13:08:48 »
And we have yet to start playing with keycap material.  But I'm really digging the clear Matias keyswitches :)
