Author Topic: Help from any Roccat owners!  (Read 6902 times)
Offline billybobjoe
« on: Sun, 21 December 2014, 13:47:37 »
Does the Roccat software/drivers require an administrator account to open in Windows 7? Can someone please test this with a non-admin account? Thanks in advance.
Re: Help from any Roccat owners!
« Reply #1 on: Sun, 21 December 2014, 13:48:44 »
I did not have to run the program as administrator. Though I am on my main account.
Offline billybobjoe
« Reply #2 on: Mon, 22 December 2014, 18:51:10 »
Can you please test this by creating a non-admin account and trying? Thanks for your help.
Offline Protato_Tubby
  • people enthusiast
« Reply #3 on: Tue, 23 December 2014, 15:55:28 »
Have you tried clicking "No" when it asks for admin access?
DELL AT102W Black Alps | IBM Model M 122 | Matias Tactile Pro 4
Offline billybobjoe
« Reply #4 on: Tue, 23 December 2014, 15:58:51 »
No, I don't have an actual Roccat mouse yet I was just wondering if it could work before I get one.
  • people enthusiast
« Reply #5 on: Wed, 24 December 2014, 05:55:42 »
Well, the mice are driverless to begin with - if you want to change anything then you'll have to download the drivers.
Offline Evo_Spec
  • (╯°ヮ°)╯︵⌨
« Reply #6 on: Wed, 24 December 2014, 06:41:23 »
once the profiles are made they can be saved directly to the mouse and it shouldn't need the drivers to work
GON NerD TKL DTA Edition
Offline billybobjoe
« Reply #7 on: Wed, 24 December 2014, 10:07:14 »
Yeah but to make the profile you have to download the drivers right? And you can't download them if you don't have the mouse plugged in right?
« Last Edit: Wed, 24 December 2014, 10:09:18 by billybobjoe »
Offline Evo_Spec
  • (╯°ヮ°)╯︵⌨
« Reply #8 on: Wed, 24 December 2014, 10:19:50 »
don't you have a computer you can do this initial setup on? i mean even go to a friends house or something and set it up and bright it back home or work or where ever
Offline billybobjoe
« Reply #9 on: Wed, 24 December 2014, 10:22:55 »
No, do you have a Roccat mouse?  If you don't can you please try downloading the drivers online with a non-admin account? This would help me so much.
Offline FrostyToast
  • Litshoard
« Reply #10 on: Wed, 24 December 2014, 10:41:03 »
Can't you just download the mouse software yourself and try to open it without the mouse? That should work fine.
Quote from: elton5354
Offline billybobjoe
« Reply #11 on: Wed, 24 December 2014, 10:47:00 »
I just did and it didn't work.
Offline FrostyToast
  • Litshoard
« Reply #12 on: Wed, 24 December 2014, 10:57:58 »
So don't get the mouse?
Offline billybobjoe
« Reply #13 on: Wed, 24 December 2014, 11:06:24 »
Yeah but if I do plug in a Roccat mouse, will it work?
Offline FrostyToast
  • Litshoard
« Reply #14 on: Wed, 24 December 2014, 11:20:58 »
I would think that any decent software should at least start without a mouse.
Offline davkol
  •  Post Editing Timeout
« Reply #15 on: Thu, 25 December 2014, 19:06:04 »
wat.
I don't understand this thread. The mouse will almost certainly work as a dumb mouse with any modern OS that supports USB HID stuff. Want to configure it? You can pick one of *two* different drivers w/ config GUI: proprietary for MS Windows and open-source for GNU/Linux. Even if Roccat cripples the proprietary blob in any imaginable way, you can ignore it, and just use the free driver by Stefan Achatz—just run a modern distro in VirtualBox or from a flash drive or whatever.
Offline Smasher816
  • HHKB Master
« Reply #16 on: Thu, 25 December 2014, 19:41:07 »
You can plug in a roccat mouse and it will just work, no software needed.
The only time you need the software is if you want to make a change (like what the side buttons do). However, I am sure you can find a computer with admin access, at your own personal comouter, some friends, etc. There has to be someone with an unlocked computer, you don't have to do it at work.
If you make your changes they will continue to work on any computer even without the software, so you can use it at work or any other computer without admun rights.
Offline JDorfler
    • My Blog
« Reply #17 on: Fri, 26 December 2014, 05:38:35 »
If you are thinking of buying the Kone or Tyon I recommend installing the drivers.  I'm assuming you are running Windows.  The drivers install just fine.  Once you load the profiles you want and upgraded the firmware the mouse is good on any PC you want to use.  However, if you are using Linux, there is a bit of work to be done to install the drivers.  When done right, in my opinion, the drivers for Linux are a bit easier to use.
Offline dmbr
« Reply #18 on: Mon, 05 January 2015, 19:22:02 »
You should definitely install the drivers then update the firmware, they provide many important features and performance improvements. Great mouse.
