Author Topic: Hello all, and thanks  (Read 2409 times)
Offline Blaklyte
« on: Sun, 21 December 2014, 16:14:54 »
Hello everyone, I'm from Canada and came across this forum after doing a lot of research on mechanical keyboards and which one to buy. I been using a Logitech G11 for probably 8 or 9 years now, but I'm getting more serious into playing CS:GO and decided it was time to look at mechanical keyboards. After hours and hours or research, reviews, YouTube videos, browsing the forum. Trying to decide between all the different switch and then look into if I should get a full keyboard or a TKL, I finally ordered a keyboard on ncix.ca yesterday.
I'm getting a Ducky Shine 3 TKL with white LED. I wanted a blue LED but looks like they're pretty popular and don't stay in stock for long. I'm sure I will still be happy with it and maybe even more then the blue :P
Well thanks for all your help!!!!
Offline Evo_Spec
  • (╯°ヮ°)╯︵⌨
Re: Hello all, and thanks
« Reply #1 on: Sun, 21 December 2014, 21:52:41 »
Welcome to GH!
Remember that sticking around here will probably empty your wallet, WALLETHACK!
here's a nice link to start you off =)
https://ctrlalt.io/bro-caps/winter-is-coming
GON NerD TKL DTA Edition
Offline Blaklyte
« Reply #2 on: Mon, 22 December 2014, 03:46:01 »
Thanks, I don't think I will do any mod to it. Well not at first anyway. If I do mod it I would probably do something classy and turn it into pinguin style with some white key caps
Offline Evo_Spec
  • (╯°ヮ°)╯︵⌨
« Reply #3 on: Mon, 22 December 2014, 06:11:20 »
penguin style? what's that?
Offline Blaklyte
« Reply #4 on: Mon, 22 December 2014, 08:23:57 »
Replacing some of the keys with white ones. I will try to post a pic later. I saw a pic in this forum but I'm at work right now and most pics are blocked.
Offline Blaklyte
« Reply #5 on: Mon, 22 December 2014, 08:45:41 »
Ok I think I found it, I can't see them because I'm at work but I will post anyway
Offline Blaklyte
« Reply #6 on: Tue, 23 December 2014, 23:32:31 »
Well I could not see the image when I posted and I guess I made a mistak the white penguin keyboard is not for me.
Offline Evo_Spec
  • (╯°ヮ°)╯︵⌨
« Reply #7 on: Wed, 24 December 2014, 01:14:42 »
ahh i see what you mean now, neat.
« Reply #8 on: Mon, 29 December 2014, 03:58:13 »
Welcome to Geekhack!
White LEDs are good - they go with almost anything.
Plus you can change their colour with little plastic inserts, including blue ones: http://www.vendio.com/stores/E-sports-Gaming-equipments/item/keyboard-accessory/led-cover-for-modification/lid=37668704
