Author Topic: plate mount to pcb mount?  (Read 5676 times)
Offline Hellcatz
« on: Mon, 22 December 2014, 18:44:22 »
So manage to find a keyboard with cherry mx browns for 35 cad and forgot to check whether or not it was plate mount or pcb mount switches. The question is, is there anyway I can make it so it will be secure?
Offline Roibhilin
  • Saver of Humens
Re: plate mount to pcb mount?
« Reply #1 on: Mon, 22 December 2014, 18:58:27 »
are you asking if you can convert a PCB mount keyboard to plate mount? if it's a standard form factor like TKL/104 there are some plates people sell but you'll have to desolder the switches before you put them on
QFR | Poker II | Quickfire TK
Offline Hellcatz
« Reply #2 on: Mon, 22 December 2014, 19:00:04 »
the other way around I need the switches for a gon build
Offline Dreamre
    • kbdlife
« Reply #3 on: Mon, 22 December 2014, 19:44:42 »
What keyboard are you buying? I'm pretty sure it's a plate mount if it's one of the more mainstream boards such as a CoolerMaster Quickfire.
Edit-
Read your question wrong. If you have a plate for the GON keyboard it should be secure. It'll be even more secure if it's PCB mount switch though...
Offline Hellcatz
« Reply #4 on: Mon, 22 December 2014, 19:47:34 »
Its going to be a nerd crystal case so?
Offline Hogesyx
« Reply #5 on: Tue, 23 December 2014, 02:30:37 »
No problem. PCB cherry can be easily converted to Plated one by cutting the 2 plastic leg with a good snip/wirecutter/etc and craft knife. I believe GON pcb has holes for PCB switches right? You might not even need to cut them unless there is some fitting issue.
Novatouch TKL | Ducky YOTR (Brown) | Ducky Shine (Brown)
Poker II (Red) | GH60 revchn (Clear)
Offline Defect
« Reply #6 on: Tue, 23 December 2014, 07:46:38 »
OP wants Plate to PCB.
The only part that changes is the lower switch housing unit.  PCB mount has two extra plastic legs.  If you have diodes/LED's, those will also work to secure the switch in place.  An old board I have even uses metal "staples' soldered to the pcb for stability.
If your GON doesn't have a plate, your best bet would be to buy PCB mount housing units (or buy PCB mount switches, swap the internals, and sell your plate mount ones).
Offline IvanIvanovich
  • Mr. Silk Underwear
« Reply #7 on: Tue, 23 December 2014, 09:59:01 »
I've used some plate switches in a pinch for replace some bad switch on pcb mount. I don't think it really makes a huge difference in stability, but they are a ***** to get them aligned perfectly without the fixing pins.
Offline Hellcatz
« Reply #8 on: Tue, 23 December 2014, 18:22:10 »
Do peeps really just sell the housing itself? The ones I have seen are replacements for the top half of the switch
Offline berserkfan
« Reply #9 on: Wed, 24 December 2014, 13:44:13 »
WHy do you need to bother? If you are taking the switches out, you will almost certainly be putting them in a plate mounted keyboard like 99% of geekhackers. The plate will hold your switches securely.
I used to be willing to sell parts, but now I'm OOS where switch housings are concerned.
