Author Topic: PBT Coffee set  (Read 4175 times)
Offline bamze
PBT Coffee set
« on: Wed, 24 December 2014, 04:50:32 »
I really like this coffee set
I want it PBT.
Do you guys have any idea of how i can get my hands on this or similar PBT set?
Camo Filco blue, ducky shine 3 red, filco brown, ibm model M, CM Novatouch.
Re: PBT Coffee set
« Reply #1 on: Wed, 24 December 2014, 04:57:09 »
Maybe Tai Hao would consider these colours, now that they can produce PBT sets.
Offline MrFex
Re: PBT Coffee set
« Reply #2 on: Sun, 04 January 2015, 13:51:40 »
What is up with this?!  :-X :p
Re: PBT Coffee set
« Reply #3 on: Mon, 05 January 2015, 13:00:16 »
Tai Hao would probably do it, but you could also bug keypop and SP to see if they'll run it.
Offline Lu_e
Re: PBT Coffee set
« Reply #4 on: Mon, 05 January 2015, 14:22:47 »
SP? Nope, don't think they can do that in PBT.
Just say NO to ABS keycaps
Re: PBT Coffee set
« Reply #5 on: Mon, 05 January 2015, 14:23:54 »
Not in doubleshot, they've got dyesub capabilities.
Offline Lu_e
Re: PBT Coffee set
« Reply #6 on: Mon, 05 January 2015, 14:44:57 »
A light tan on a dark brown like that? I could be wrong but I didn't think that was possible for them.
Re: PBT Coffee set
« Reply #7 on: Mon, 05 January 2015, 14:46:01 »
i have no idea dude
ask SP
Re: PBT Coffee set
« Reply #8 on: Mon, 05 January 2015, 14:49:10 »
i have no idea dude
Then why give answers which make it seem like you think you do?
Offline FrostyToast
  • Litshoard
Re: PBT Coffee set
« Reply #9 on: Mon, 05 January 2015, 14:52:08 »
You can't do the light tan on the darker brown since the legends have to be lighter than the base for sublimation.
You will definitely have to run this through Tai Hao.
Quote from: elton5354
Offline Dihedral
  • Mostly Harmless
Re: PBT Coffee set
« Reply #10 on: Sat, 17 January 2015, 03:15:27 »
*Darker
Although an etsy user managed to do small-scale light on dark sublimation by sublimating the whole top of a white cap and then dying the outside.
