Author Topic: Neat soldering gun holder  (Read 2284 times)
Offline Bromono
  • Wanabe Cicerone
  • HHKB > Your Opinion
Re: Neat soldering gun holder
« Reply #1 on: Wed, 24 December 2014, 19:41:31 »
Might as well spend a little more and get this for a holder
http://www.amazon.com/Hakko-Iron-Holder-633-01-599B/dp/B002R6H9IQ
Offline Bromono
  • Wanabe Cicerone
« Reply #2 on: Wed, 24 December 2014, 19:49:26 »
Oh nice even has a cleaner
Offline Evo_Spec
  • (╯°ヮ°)╯︵⌨
« Reply #3 on: Thu, 25 December 2014, 10:50:51 »
It's even a little cheaper at a local store here in Japan, score!
GON NerD TKL DTA Edition
Offline Parak
« Reply #4 on: Thu, 25 December 2014, 11:42:07 »
That's a holder for a desoldering gun and might not work correctly for soldering irons. I mean if one is looking for a cheapo holder, look at these instead:
http://www.amazon.com/dp/B00LQG47V0
http://www.amazon.com/dp/B008IJAEZG
http://www.amazon.com/dp/B00LXL6AHM
Offline 1391406
« Reply #5 on: Fri, 26 December 2014, 08:37:10 »
Though not a soldering gun holder, I bought one of these third hands for about $6 shipped.
Offline azhdar
  • Praise the AZERTY god
« Reply #6 on: Fri, 26 December 2014, 08:44:17 »
What kind of PCB did you hold with those ? I want a tool like this but it always look like it can't even hold a 60% PCB .
Azerty Propagandiste
Offline 1391406
« Reply #7 on: Fri, 26 December 2014, 08:56:22 »
I bought two, actually. I've never used them for holding PCB's or soldering, but to hold reflectors for photography. They're quite sturdy; the joints can be tightened and loosened to taste. While I think the arms could sustain the weight of a 60% PCB, I don't know whether the tool would sit upright without tipping over; the base may not be wide enough to support it properly.
Offline azhdar
« Reply #8 on: Fri, 26 December 2014, 09:02:47 »
K thanks .
