Author Topic: CLACKVENT Radnelac  (Read 14582724 times)
Offline HPE1000
  • Keycap Paparazzo
Re: CLACKVENT Radnelac
« Reply #1000 on: Tue, 20 January 2015, 20:47:40 »
f
Offline Distilled
« Reply #1001 on: Tue, 20 January 2015, 20:47:40 »
here we go
« Reply #1002 on: Tue, 20 January 2015, 20:47:40 »
aoe
  • Live long and prosper
« Reply #1003 on: Tue, 20 January 2015, 20:47:41 »
another?
tp thread is tp thread
Offline intelli78
« Reply #1004 on: Tue, 20 January 2015, 20:47:41 »
The Z machine at Sandia National Laboratory. Due to the extremely high voltage, the power feeding equipment is submerged in concentric chambers of 2 megalitres (2,000 m³) of transformer oil and 2.3 megalitres (2,300 m³) of deionized water, which act as insulators. Nevertheless, the electromagnetic pulse when the machine is discharged causes impressive lightning, referred to as a "flashover", which can be seen around many of the metallic objects in the room.
The Z Pulsed Power Facility, informally known as the Z machine, is the largest X-ray generator in the world and is designed to test materials in conditions of extreme temperature and pressure. Since its refurbishment in October 1996[1] it has been used primarily as an inertial confinement fusion (ICF) research facility. Operated by Sandia National Laboratories, it gathers data to aid in computer modeling of nuclear weapons and eventual nuclear fusion pulsed power plants. The Z machine is located at Sandia's main site in Albuquerque, New Mexico.
The Z machine origins can be traced from the Department of Energy need to replicate in a lab environment the fusion reactions of a thermonuclear bomb, to better understand the physics involved.
Since the 1970s the DoE had been looking into ways to generate electricity from fusion reactions, with continuous reactions such as Tokamaks or discrete fusion of small balls of light atoms. Since at the time lasers were far from having the required power, the main approach considered was heavy ion fusion.[2] However major advances such as Q-switching and Mode-locking made lasers an option (culminating in the National Ignition Facility) and the Heavy Ion Fusion programs became more or less dormant. In 1985, the review of DoE's program by the National Academies[3] stated "The energy crisis is dormant for the time being". Heavy Ion Fusion machines were tasked to help military research improve nuclear bombs.
The first research at Sandia dates back from 1971[4] where Gerold Yonas[5][6] initiated and directed the particle-beam fusion program.
In the December 1976 issue of Popular Science[7] and in 1976 conference proceedings published in 1977, an article titled "Particle Beam Fusion Research"[8] described early work and first generation machines: Hydra (1972); Proto I (1975); Proto II (1977); EBFA/PBFA (Electronic Beam Fusion Accelerator/Particle Beam Fusion Accelerator) (1980).
In 1985, the PBFA-II was created.[9][10] Sandia continued to target Heavy Ion Fusion at a slow pace despite the National Academies report.
The November 1978 issue of Scientific American carried Yonas' first general-public article, "Fusion power with particle beams".[11]
Meanwhile, defense-related research was also ongoing at Sandia with the Hermes III machine and Saturn (1987), upgraded from PBFA-I, which operated at lower total power than PBFA-II but advanced Sandia's knowledge in high voltage and high current and was therefore a useful predecessor to the Z machine.
In 1996, the US Army published a report[12] on the decommissioning of the Aurora Pulsed Radiation Simulator. This report is useful in understanding ties between nuclear arms testing and inertial fusion energy research.
Also in 1996, the PBFA-II machine was once again upgraded[13] into PBFA-Z[1] or simply "Z machine", described for the first time to the general public on August 1998 in Scientific American.[14][15]
Physics of the Z machine
The Z machine uses the well known principle of Z-pinch where the fast discharge of capacitors in a tube causes its collapse towards its centerline, under the influence of Lorentz forces (current, magnetic field, force). Bennet researched successfully the application of Z-pinches to plasma compression. The Z machine layout is cylindrical. On the outside it houses huge capacitors discharging in Marx generators which discharge in about one microsecond. Yonas then uses a system to divide this time by a factor 10, using the dielectric power of water, to enable the creation of 100ns discharges.
But this effort was not successful for Heavy Ion Fusion, by lack of sufficient focalization of the beams, despite the high power used. It had been known for a long time that the Lorentz forces were radial but the current flow was highly instable and rotated along the cylinder which causes twisting of the imploding tube therefore decreasing the quality of the compression.
A Russian, Valentin Smirnov, then had the idea of replacing the tube (called “Liner”) by a wire array, to fight the azimuthal flow of the current, and therefore fight the MHD instability. The Angara V[16] facility of the Kurchatov Institute had been built for the same reason: to help simulate and design the second stage of hydrogen bombs and test the effect of high power x-rays on nuclear missiles' warheads. The space inside the wire array was filled by polystyrene, which helps homogenise the X-ray flux. Any country developing thermonuclear weapons has its own Z machine, but those not using water lines had long rising pulses (for example 800ns in the Sphinx, the French machine at Gramat). In the UK, the Magpie[17] machine was situated at the Imperial College under Malcolm Haines.
By removing the polystyrene core Sandia was able to obtain a thin one and a half millimetre plasma cord in which 10 million amperes flowed with 90 megabars of pressure.
Early operation 1996-2006
The key attributes of Sandia’s Z machine[18] are its 18 million amperes and a discharge time of less than 100 nanoseconds. The array of tungsten wires is called a "liner."[19] In 1999, Sandia tested the idea of nested wire arrays;[20] the second array, out of phase with the first, compensates for Rayleigh-Taylor instabilities. In 2001, Sandia introduced the Z-Beamlet laser (from surplus equipment of the National Ignition Facility) as a tool to better image the compressing pellet.[21] This confirmed the shaping uniformity of pellets compressed by the Z machine. Sandia announced the fusing of small amounts of deuterium in the Z machine on April 7, 2003.[22]
Besides being used as an X-ray generator, the Z machine propelled small plates at 34 kilometres a second, faster than the 30 kilometres per second that Earth travels in its orbit around the Sun, and three times Earth's escape velocity.[23] It also successfully created a special, hyperdense "hot ice" known as ice VII, by quickly compressing water to pressures of 70,000 to 120,000 atmospheres (7 to 12 GPa).[24] Mechanical shock from impacting Z-machine accelerated projectiles is able to melt the diamonds.[25]
A good overview of the different missions of the Z machine can be found in the 2002 Trivelpiece committee report[26] which reviewed the pulsed power activities at Sandia.
During this period the power of X-ray produced jumps from 10 to 300TW.[27] In order to target the next milestone of fusion breakeven, another upgrade is then necessary[28]
Two billion Kelvin
At the beginning of 2006, the Z machine produced plasmas with announced temperatures in excess of 2 billion kelvins (2 GK, 2×109 K) or 3.6 billion °F, even reaching a peak at 3.7 GK or 6.6 billion °F.[29][30][31] It was achieved in part by replacing the tungsten wires with thicker steel wires. This temperature, which enables a 10% to 15% efficiency in converting electrical energy to soft x-rays, was much higher than anticipated (3 to 4 times the kinetic energy of the incoming wires on axis). The Guinness Book Of Records formerly listed it as the highest human-achieved temperature[32] (the Relativistic Heavy Ion Collider at Brookhaven National Laboratory[33] and the Large Hadron Collider[34] have since produced higher temperatures). The origin of this extra energy still remains unexplained, but it has been theorized that small-scale MHD turbulence and viscous damping would convert magnetic energy into thermal energy of the ions, which then would transfer their energy to the electrons through collisions.[30][31]
Prospects
Proposed model of a 1 petawatt LTD-based z-pinch accelerator.
104 m diameter, 70 megaamperes, 24 megavolts.
A $60 million (raised to $90 million) retrofit program called ZR (Z Refurbished) was announced in 2004 to increase its power by 50%. The Z machine was dismantled in July 2006 for this upgrade, including the installation of newly designed hardware and components and more powerful Marx generators. The de-ionized water section of the machine has been reduced to about half the previous size while the oil section has been expanded significantly in order to house larger intermediate storage lines (i-stores) and new laser towers, which used to sit in the water section. The refurbishment was completed in October 2007.[35] The newer Z machine can now shoot 27 million amperes (instead of 18 million amperes previously) in 95 nanoseconds. The radiated power has been raised to 350 terawatts and the X-ray energy output to 2.7 megajoules. However the maximum temperature the new version may reach with the same record holder stainless steel wire-array liner used in 2005 is not yet known.
The ultra-high temperatures reached in 2006 (2.66 to 3.7 billion kelvins) are much higher than those required for the classical hydrogen, deuterium and tritium fusion previously considered. They could allow, in theory if not in practice, the fusion of light hydrogen atoms with heavier atoms such as lithium or boron. These two possible fusion reactions do not produce neutrons, and thus no radioactivity or nuclear waste, so they open the possibility of human-made clean aneutronic fusion.
Sandia's roadmap includes another Z machine version called ZN (Z Neutron) to test higher yields in fusion power and automation systems. ZN is planned to give between 20 and 30 MJ of hydrogen fusion power with a shot per hour using a Russian Linear Transformer Driver (LTD) replacing the current Marx generators.[36] After 8 to 10 years of operation, ZN would become a transmutation pilot plant capable of a fusion shot every 100 seconds.[37]
The next step planned would be the Z-IFE (Z-inertial fusion energy) test facility, the first true z-pinch driven prototype fusion power plant. It is suggested it would integrate Sandia's latest designs using LTDs. Sandia labs recently proposed a conceptual 1 petawatt (1015 watts) LTD Z-pinch power plant, where the electric discharge would reach 70 million amperes.[38] As of 2012 Fusion shot simulations at 60 to 70 million amperes are showing a 100 to 1000 fold return on input energy. Tests at the Z machine's current design maximum of 26-27 million amperes were set to begin in 2013.[39] Via MagLIF - Magnetized Liner Inertial Fusion.[40]
Z-Pinch Inertial Fusion Energy program
The Sandia Laboratories Z-IFE project[41] aims to solve the practical difficulties in harnessing fusion power. Major problems include producing energy in a single Z-pinch shot, and quickly reloading the reactor after each shot. By their early estimates, an implosion of a fuel capsule every 10 seconds could economically produce 300 MW of fusion energy.
Offline sethk_
  • Grand Master Wizard Pizza
  • www.kbdhub.com
    • My webstore
« Reply #1005 on: Tue, 20 January 2015, 20:47:44 »
  S
Offline C5Allroad
  • Formerly HUNTERANGEL121
« Reply #1006 on: Tue, 20 January 2015, 20:47:50 »
BS
Offline swill
  • builder & enabler
    • swillkb.com
« Reply #1007 on: Tue, 20 January 2015, 20:47:52 »
Again?
Offline scubaste
« Reply #1008 on: Tue, 20 January 2015, 20:47:56 »
a
Offline Synjin
« Reply #1009 on: Tue, 20 January 2015, 20:47:58 »
Jejed
Offline t2russo
« Reply #1010 on: Tue, 20 January 2015, 20:48:02 »
glhf
Offline ImBZppl
« Reply #1011 on: Tue, 20 January 2015, 20:48:09 »
hmm?
Offline ClackFactory
  • * Moderator
  • finger crosser
« Reply #1012 on: Tue, 20 January 2015, 20:59:08 »
BS will make us stronger!
The next BS winner will be chosen at random from the next group of posters.
The BS clack will be fifty, one dollar bills.  1.20.15
#dealwidit
A.K.A. "clickclack"   Vendor link ->Clack Factory   I've done so much with so little for so long, that I can do almost anything with nothing at all
Offline strict
  • TKL Zealot
« Reply #1013 on: Tue, 20 January 2015, 20:59:25 »
A
Offline HoffmanClackster
  • HOFF, MAN OF CLACKSTERY
  • * St. Jude Supporter
  • ¯\_(ツ)_/¯
« Reply #1014 on: Tue, 20 January 2015, 20:59:26 »
Mod Edit: Unfortunately, I have to be the bearer of bad news.  :(  This gif was NSFW and has been removed.  It was funny though, so there's that.
Actual Edit: LOL, I've been exposed!
Offline GypsyDanger
« Reply #1015 on: Tue, 20 January 2015, 20:59:28 »
Yay
Offline HPE1000
  • Keycap Paparazzo
« Reply #1016 on: Tue, 20 January 2015, 20:59:28 »
f
Offline sorijealut
    • steam
« Reply #1017 on: Tue, 20 January 2015, 20:59:29 »
dis i want
Offline bueller
  • MX baller
  • Church of the Ergo Clear
« Reply #1018 on: Tue, 20 January 2015, 20:59:29 »
xfvfg
Offline asdfjkl36
  • blue shirt guy
« Reply #1019 on: Tue, 20 January 2015, 20:59:31 »
Ndmdmd fm
Offline billnye
  • ability man
« Reply #1020 on: Tue, 20 January 2015, 20:59:32 »
sfasfsdfasdfd
Offline PunksDead
  • hspernks
  • keyboard poser
« Reply #1021 on: Tue, 20 January 2015, 20:59:32 »
dwdw
« Reply #1022 on: Tue, 20 January 2015, 20:59:33 »
aoeu
Offline FreeCopy
« Reply #1023 on: Tue, 20 January 2015, 20:59:34 »
Keyboards
Poker II | Leopold fc500r | Bolt Modded M 1391401 x2 08NOV90 - 19NOV90 | FK-2001 White Alps Clones | Filco MJ2 104 |  Bolt Modded SSK 1391472 27JUL87 | Winkeyless B.87 TKL | MiniVan GateReds 62g
« Reply #1024 on: Tue, 20 January 2015, 20:59:36 »
#dealwidit
Offline Moralless
« Reply #1025 on: Tue, 20 January 2015, 20:59:40 »
3124
Offline sleepy916
« Reply #1026 on: Tue, 20 January 2015, 20:59:41 »
asa
Offline DrHubblePhD
  • I am star stuff
« Reply #1027 on: Tue, 20 January 2015, 20:59:42 »
sss
Offline exitfire401
  • The Force is Re/\l
« Reply #1028 on: Tue, 20 January 2015, 20:59:43 »
PLEAAAASSE
Offline jalaj
« Reply #1029 on: Tue, 20 January 2015, 20:59:43 »
blaaah
Offline Lurch
« Reply #1030 on: Tue, 20 January 2015, 20:59:43 »
hi
Quote from: Flyersfan1
Offline hjc1710
« Reply #1031 on: Tue, 20 January 2015, 20:59:44 »
OMG PLEASE STOP THIS
Filco Majestouch II (B) | Poker II (BR) | Cherry G80-11900 (BLK) | Das V3 (BR) | RS84 (soon...)
Granite | Skull Squadron | Deep Space | Raindrop R2 | Hyperfuse GMK (soon...)
Offline calvinhousecat
« Reply #1032 on: Tue, 20 January 2015, 20:59:47 »
choose me if you like brownies
Offline scubaste
« Reply #1033 on: Tue, 20 January 2015, 20:59:47 »
a
« Reply #1034 on: Tue, 20 January 2015, 20:59:51 »
sdflkjgnjhdsfl
Offline Distilled
« Reply #1035 on: Tue, 20 January 2015, 20:59:51 »
and again
Congrats!  -cc  =)
« Last Edit: Tue, 20 January 2015, 21:02:18 by ClackFactory »
Offline MGH
« Reply #1036 on: Tue, 20 January 2015, 20:59:53 »
3 for 6?
Offline C5Allroad
« Reply #1037 on: Tue, 20 January 2015, 20:59:54 »
Ifffff
Offline swill
  • builder & enabler
    • swillkb.com
« Reply #1038 on: Tue, 20 January 2015, 21:00:04 »
Yes
Offline 3Love
  • Bumpino Supremo
  • I want to become a great collector. Greedy!!!
    • https://geekhack.org/index.php?topic=63161.0
« Reply #1039 on: Tue, 20 January 2015, 21:00:05 »
1
I♥Keyboard  I♥Clack  I♥Brobot  I♥Hammer
                          I♥♥♥friends
【WTB/WTTF】https://geekhack.org/index.php?topic=63161.0
KBD Collection: 356CL, 356.2, 356DGE, Koala, 356MINI, 356N, 356N-MK2, 356PAD, 360C, 456GT, FMJ, LZ-MXSE, LZ-RE, KMAC 1.0, KPAD, Duck Orion, Duck Pad, Exo, TEX and etc.
« Reply #1040 on: Tue, 20 January 2015, 21:00:05 »
Hjd
  • * Moderator
  • finger crosser
« Reply #1041 on: Tue, 20 January 2015, 21:06:50 »
BS BS BS!!! MUUUAAAHAAHAHAAAA!
You know the drill!
@ $50
much luv, 1.20.15
Offline strict
  • TKL Zealot
« Reply #1042 on: Tue, 20 January 2015, 21:07:12 »
A
  • ¯\_(ツ)_/¯
Offline GypsyDanger
« Reply #1044 on: Tue, 20 January 2015, 21:07:17 »
Please!
Offline PunksDead
  • hspernks
  • keyboard poser
« Reply #1045 on: Tue, 20 January 2015, 21:07:17 »
ALL NIGHT!!!
Offline asdfjkl36
  • blue shirt guy
« Reply #1046 on: Tue, 20 January 2015, 21:07:17 »
Omg my heart.
Offline Lurch
« Reply #1047 on: Tue, 20 January 2015, 21:07:17 »
dude lol <3
« Reply #1048 on: Tue, 20 January 2015, 21:07:18 »
aoeu
Offline o3okevin
« Reply #1049 on: Tue, 20 January 2015, 21:07:18 »
a
