Author Topic: should I buy a 24" widescreen lcd monitor?  (Read 22434 times)
Offline wellington1869
« on: Wed, 05 August 2009, 12:05:19 »
I have a 19" regular lcd right now.
i saw some of these ginormous monitors at work. at first i thought it was way overkill. but when I saw how nice and big the fonts get, I started to be tempted.
if i were to upgrade i'd get a 23 or 24 inch I guess, cuz the vertical height (even if its widescreen) would remain around same vertical height as on the 19".
ideally i'd like to rotate it to view a word document vertically on it, but that might be asking too much. not sure how much i'd really use that anyway.
anyway, so is it worth it?  In actual screen real estate, you actually dont get all that much more (about a 4 inch wide strip).
using: ms 7000/Das 3
Offline Kraicheck
« Reply #1 on: Wed, 05 August 2009, 12:16:40 »
I would say yes.
Everything is being designed for widescreen now: movies, games, websites, etc.
Any program which uses a central working area and menus on the sides will also benefit.
You shouldn't pay more for portrait-mode as it's not all that great. Most screens have small viewing angle on the sides which leads to pretty crappy image when you turn your screen. Your screen will also stick out a huge amount above your head which makes it not that comfortable to read.
« Reply #2 on: Wed, 05 August 2009, 12:27:55 »
hmmm, good points all.  wonder if I can find one around $200.  maybe a used one.  I love ebay and craigslist.
its going to be nearly as big as my desk, lol.
Offline majestouch
  • * Commercial Vendor
    • http:///elitekeyboards.com
« Reply #3 on: Wed, 05 August 2009, 12:28:49 »
Quote from: Kraicheck;107199
I would say yes.
Widescreen websites? Where?
Offline huha
« Reply #4 on: Wed, 05 August 2009, 12:34:14 »
Going widescreen is worth it, but beware: The influence of of LCD panels' shortcomings is getting worse and worse the larger the screen gets. When sitting in front of a large widescreen monitor, you'll get significant differences in viewing angle at the edges, leading to slight colour shifts when using TN panels.
If that doesn't annoy you, go for it. If it does, you'll have to chose a high-quality panel (current production TNs are better in that respect, yet still not exactly good)--either an IPS or VA variant, but they're much more expensive than their TN brethren.
Maybe someone has a Dell 2405WFP or 2407WFP to sell--they feature PVA (IIRC) panels plus pivot, which is what you'd like to have. I wouldn't buy anything based on a TN panel when wanting to use pivot; the dependancy on viewing angles makes for a crappy picture.
-huha
Unicomp Endurapro 105 (blank keycaps, BS) // Cherry G80-3000LSCDE-2 (blues, modded to green MX) // Cherry G80-3000LAMDE-0 (blacks, 2x) // Cherry G80-11900LTMDE-0 (blacks, 2x) // Compaq G80-11801 (browns) // Epson Q203A (Fujitsu Peerless) // IBM Model M2 (BS) // Boscom AS400 Terminal Emulator (OEM\'d Unicomp, BS, 2x) // Dell AT102DW (black Alps) // Mechanical Touch (chinese BS) Acer 6312-KW (Acer mechanics on membrane) // Cherry G84-4100 (ML) // Cherry G80-1000HAD (NKRO, blacks)
Offline D-EJ915
« Reply #5 on: Wed, 05 August 2009, 12:34:31 »
If you want a monitor that big the only ones made nowadays are all widescreen so you don't have much of a choice :P
« Reply #6 on: Wed, 05 August 2009, 12:36:51 »
Quote from: huha;107210
-huha
ya i noticed a wide range of quality among the ones at work.  some look absolutely amazing and bright and clear and others look pretty crappy and dull.  i need to write down the model numbers of the ones i liked. I think they were all dells at work though.
my fear is that the ones i liked are going to be super expensive.
« Reply #7 on: Wed, 05 August 2009, 12:40:10 »
another option is to buy a second 19" one maybe.
but i'm not actually looking for more real estate just for the sake of it. What i liked specifically was that at the same resolution the fonts were bigger. Its really just for my poor tired eyes.  I usually only work on one window at a time so its not like i'd be putting windows side by side or anything.
Offline huha
« Reply #8 on: Wed, 05 August 2009, 12:44:51 »
Quote from: wellington1869;107212
Depending on what you want to do, bright and clear is not neccessarily better. Some LCDs now incorporate a wide-gamut backlight that allows the display to output a wider range of colours. The disadvantage is the total number of colours the display can show hasn't increased, so your colours are a bit "stretched out," so to speak. If you're not that much into post-nuclear apocalypse photography, most photos will look slightly ... off on these monitors because they're way too vivid. This can be remedied by calibration, but that will make gradients look bad if you overdo it. It's a tricky topic.
If you're not into photography or don't care if pictures look like they were taken in teletubby land, you're fine without calibration, though.
Viewing angle is important. Try looking at the displays from above and the sides--any big colour or contrast shifts? (The picture will naturally get darker, as less light is travelling to you)
-huha
Offline Kraicheck
« Reply #9 on: Wed, 05 August 2009, 12:48:25 »
Quote from: majestouch;107205
Most websites nowadays have 2 sidebars with the actual content in the middle. I also use the great Tree Style Tabs extension in firefox. It's really handy on a widescreen as most sites are indeed not full widescreen yet so there's room on the sides. Doing the same on a normal width monitor might cram the website together.
Offline o2dazone
« Reply #10 on: Wed, 05 August 2009, 12:51:21 »
What huha said
You kind of get what you pay for when it comes to LCD's. My brother went through two monitors before settling on a Dell Ultrasharp, and his HP and Asus had some horrible vignetting around the edges after about a year. Getting one for $200 might be a bargain, but expect it to have less than stellar quality, either new or a year old.
Oh, and don't bother with dual monitors. Having dual 19s or having a single 24 is night and day. I use 2 24's at work and find it too much, but I've worked on a single 30 and it was amazing!
« Reply #11 on: Wed, 05 August 2009, 12:54:11 »
thanks for the tips huha.  i'm not into photography but i can see how viewing angle is pretty important, esp on a big screen.
tree style tabs - like a table of contents for the website you're viewing. nice.
« Reply #12 on: Wed, 05 August 2009, 12:55:57 »
Quote from: o2dazone;107224
i cant even imagine working on a single 30.
anyone out there working on a 23 or 24 that they like and can recommend?  I'll do the usual price comparison shopping but i'd like to come up with a short list of models I guess.  Other than the ones i'm going to check out at work.
yea, 200 used maybe.
Offline CX23882
« Reply #13 on: Wed, 05 August 2009, 12:57:35 »
I have the Dell 2407WFP-HC and for the most part I like it. The image quality is great, viewing angles are great, power consumption isn't too bad and the optional Dell AS500 Soundbar speakers sound pretty good for small speakers.
The downsides of it are humming from the monitor at certain brightnesses (but I believe this affects a lot of LCD monitors) and ghosting at certain brightness/contrast/gamma settings (this I think is specific to the HC variant of this Dell). Other than those complaints, I think it's a great monitor.
Personally I'd like to try out an Apple Cinema display with LCD backlighting, but I'm not going to go down the "buy every possible type of monitor in the world to see if it's better" as I have done with keyboards.
Offline o2dazone
« Reply #14 on: Wed, 05 August 2009, 13:08:38 »
I have a 2407WFPb at work and a 2405FPW, they are both part of Dell's "Ultrasharp" line. They are both PVA's - and I honestly like them. Nice even color. I've had my 2405 for about 4 years, and haven't had a problem. Vesa mounted and come with a tilting base (although I use a monitor arm nowadays).
I know Eizo is another nice brand, but can get $$$
Offline talis
« Reply #15 on: Wed, 05 August 2009, 13:19:12 »
Welcome to the top of the dreaded hardware spiral!
I bought myself a Samsung 245T for home a year or so ago.  Completely worth the investment.  I absolutely love the screen, and its ability to rotate into portrait mode for coding.
But the whole process went something like this :
1) Ok, invest in a good quality screen as my primary and use my old cheap 22" as a secondary.
2) Crap, my video card can't drive a 22" and a 24".  I'll get a new video card.
3) Crap, my motheboard only supports AGP, and everything is PCI-E, ok time to get a new motherboard.
4) Crap, none of the motherboards that support my CPU have PCI-E, so I need a new CPU.
5) And new ram.
6) And a new hard drive....
« Reply #16 on: Wed, 05 August 2009, 13:22:49 »
lol, good point talis, i'll have to plug my old dell lappie into one of these at work to make sure it can drive it!
otherwise i'm looking at a new laptop too, lol.
i havent owned a desktop in like seven years or so.
Offline itlnstln
« Reply #17 on: Wed, 05 August 2009, 13:35:30 »
I have 2 19s at work, and I like it more than my 22" Widescreen, but I can't speak for a 24" since that's a different resolution class.  What I use my monitors for at work makes more sense with a 2 monitor setup.  I post on GH with my main monitor and keep my e-mail up on my auxillary.  Seriously, though, I code web apps on my main screen and view in a browser on the auxillary, or I write SQL in the main screen and analyze the results in Excel on the auxillary.  In this sense, having 2 monitors keeps different things "separated" with the bezels of the monitors acting like a dividing line.  When all of that stuff is on one monitor, the desktop feels cluttered.
See attached.  Where the end of the taskbar is is where the monitors split.
« Reply #18 on: Wed, 05 August 2009, 13:37:56 »
Quote from: itlnstln;107243
what, we cant read your private emails? :D
just what are you trying to hide? :D
Offline itlnstln
« Reply #19 on: Wed, 05 August 2009, 13:44:55 »
Well, it's my work PC, and I blocked out people's names for employment reasons.
Offline talis
« Reply #20 on: Wed, 05 August 2009, 13:47:19 »
You're right tho, you don't really get that much more working space on a bigger screen.  No matter how big the screen is, its unlikely going to be large enough to comfortably get two documents of any sort open on it at the same time.
I use 2 17" at work and that works just as well as my home set up for most things, as I tend to just blow everything in the main screen up to full size.  I usually have a browser and IM client open on the other screen, along with any other documents I need to reference (PDF data sheets, etc).
Do you have a docking station for your notebook?
Offline timw4mail
    • https://timshomepage.net
« Reply #21 on: Wed, 05 August 2009, 14:36:23 »
I've got two 22" TN panels...and I regret buying the second panel, because of the narrow viewing angles. I wanted a monitor to flip into portrait mode, but the viewing angle literally hurts the eyes.
However, it does work well for a regular dual-screen setup.
Buckling Springs IBM Model F AT, New Model F 77, Unicomp New Model M
Clicky iOne Scorpius M10, OCN-branded Ducky DK-9008-C, Blackmore Nocturna, Redragon Kumara K552-1, Qtronix Scorpius Keypad, Chicony KB-5181(Monterey)
Tactile Apple AEKII (Cream damped ALPS), Filco FKBN91M/JB (Japanese Tenkeyless), Cherry G84-5200, Cherry G84-4100LPAUS, Datalux Spacesaver(Cherry ML), Redragon Devarajas K556 RGB, Newmen GM711, Poker II (Cherry MX Clear), Logitech G910 Orion Spark, Logitech K840
Linear Lenovo Y (Gateron Red), Aluminum kiosk keyboard (Cherry MX Black)
« Reply #22 on: Wed, 05 August 2009, 14:52:02 »
Quote from: talis;107247
yes, if you can call this a docking station:
:D  Altho its one of the better nicer and heavier hubs i've ever had. (its called the 'kensington dome hub').
so basically I plug in three cables when i'm home (usb to the hub, usb-power to the hub, and vga).  plus laptop power supply of course.  Its pretty easy.
Offline keyb_gr
  • Cherrified user
    • My keyboard page (German)
« Reply #23 on: Wed, 05 August 2009, 15:14:41 »
In addition to the points already mentioned, it be said that at the same size in pixels, things will actually be slightly smaller on a 24" 1920x1200 screen when compared to a 19" 1280x1024 - 94 ppi vs. 86 ppi. (I made a simple but effective spreadsheet for this.)
Widescreen monitors actually are a somewhat better match for TN panels and their inequal viewing angles but I guess only up to a certain size. For me, TN is not an option at all, would be like looking into a tunnel. At my viewing distance even a flat monitor seems slightly curved. As one may guess, a larger monitor than my current 19" would only have me lose the mouse pointer even more often.
And as it's already been said, $200 for a quality 24" is entirely unrealistic, at least new. A good (read: Eizo or NEC with a decent panel) 19" still costs twice that, though one may be able to find a nice used model that doesn't break the bank, or two for a multi-monitor setup.
EDIT:
Quote from: wellington1869;107266
I'm not sure whether I'd want to run 1920x1200 with a notebook's VGA port. Some decent DVI out would be better.
« Last Edit: Wed, 05 August 2009, 15:19:40 by keyb_gr »
Offline FunkTrooper
    • http://funktrooper.t35.com/
« Reply #24 on: Wed, 05 August 2009, 15:24:01 »
Very recently, I bought a 24" monitor, the Dell S2409W. Here it is next to my old 19" monitor.
It's TN but the viewing angle is fine, for me at least. and at €215, it's a bargain!
Offline talis
« Reply #25 on: Wed, 05 August 2009, 15:35:39 »
Quote from: keyb_gr;107272
That's sort of what I was getting at.  Most docking stations have a DVI output as well.  At least you can take your laptop with you to the store and try before you buy.
The 245T is a true 8 bit S-PVA (most TN panels are 6 bit)  and seems to sell for around $600.  I haven't had any issues at all with viewing angle, but it is very slow relative to a TN of the same rated speed (the ghosting is a lot more apparent on it rated at 6ms vs my 9 year old 32ms TN screen).
« Last Edit: Wed, 05 August 2009, 15:37:50 by talis »
Offline Rajagra
« Reply #26 on: Wed, 05 August 2009, 15:43:56 »
True. And don't listen to anyone who says you can increase the system font size to easily get around that problem, at least if you use Windows XP. It is not a complete solution, eventually you will get dialogue boxes where there is too much text to show. I've even had them where the click buttons were not visible, and had to use Tab and educated guesswork to make a selection.
P.S. you can fit 2 documents on a 1920x1200 screen if you tile them vertically*. It isn't generous in size, but it's usable. (* I mean side-by-side.)
Using a VGA connection at 1920x1200 can also be OK, depending on the adapter and screen. It would be a crime to do that if you have DVI available, but if you don't it's worth trying.
« Last Edit: Wed, 05 August 2009, 15:50:22 by Rajagra »
Offline MsKeyboard
« Reply #27 on: Wed, 05 August 2009, 16:24:35 »
I am currently using a Samsung 2433bw, attached to a 3M monitor/notebook combo arm.  Works great, and places the monitor at a much more pleasant height and angle than the typical attached monitor stand.
I was real lucky, found the monitors (yes, I bought more than one at risk of significant other stealing mine) at Costco and used a coupon online to put the final price @ $219 before tax.
I spent too much time looking around, scouring the sales, and reading reviews, but I am real happy with what I now have.  Almost went with the HP that can be flipped on its side, but really like the picture better on the Samsung.  Have it set on 1920 X 1200 and it leaves me a whole lot of room for multiple applications to be used side by side.
Did not go with the dual monitor setup because of hardware issues and wires, etc., and all my friends see my setup and are making the switch to a single unit.
Hope whatever you decide works out for you......Later
« Reply #28 on: Wed, 05 August 2009, 17:16:21 »
true but if that means buying a new computer i'll prolly have to do a poor man's solution for a while.
also I wouldnt run it at that high a resolution. My eyes cant take it. I'd prolly do 1200 by 1000 range. I dont need screen real estate, I'm happy with how much info I can put on the screen around 1200 pixels; I just want slightly bigger text on it, thats all.
Of course the higher res is nice to have if I ever change my mind. Or try gaming again. Or get into photography.
EDIT:
ya i've played around with text size and even a magnifier, lol. I mean i'm not blind or anything but when you're in front of the damn thing 10 hours a day, its just really nice to have a big crisp screen.
this would definitely be a luxury item for me, i dont 'need' it in any sense. Especially since all i liked about it is the bigger fonts at same res. Tho i'm sure i'd find other uses for the real estate once I get used to having it.
« Last Edit: Wed, 05 August 2009, 17:21:18 by wellington1869 »
« Reply #29 on: Wed, 05 August 2009, 17:18:13 »
Quote from: FunkTrooper;107276
holy crap it looks so huge
Offline DrunkenDonut
« Reply #30 on: Wed, 05 August 2009, 18:47:59 »
We're using a couple of Samsung 245T at the office, and I have a Dell 2408WFP at home. They're absolutely beautiful, especially if you calibrate them.
BUT..... each has their flaws. The HDMI port / resolutions seem to work better on the Dell (it also has more ports, like DisplayPort), and the Samsung has a better menu system (IMO). The buttons on the Dell also feel worse than the Samsung's. They seem to activate on one side easier than the other, in pairs. Imagine two arrows pointed at each other. That's where they activate easy. Repeat that three times, and add another arrow for the power button. You pretty much can't even push it on the opposite side. Bizarre.
The backlight on the Samsung is better - It's brighter on the left of the Dell and top left corner too. It's a known issue with a bunch of them though I don't think it effects them all.
Both displays, due to the nature of the panels types they use, have a high input latency. I have noticed when playing games, especially where timing is a critical issue. If you're going to play games with require precise timing or split second reaction, you might want to use a TN display instead. For other types, you might be fine learning the delay and compensating for it.
*Hang on to your wallet!*
BTC E5X5R5BTC-5339R-0 (\'90), MS Natural Keyboard Pro (\'99), Sun Type 5c, 2x 1391401, DASK3ULT (\'08), ABS M1, Dell AT101W, M4-1
FKBN87M/EB (\'09), FKBN87ML/EB (\'09), FKBN87Z/EB (\'09), FKBN87MC/NPEC (\'09), G80-3000LQCDE-2 (\'11)
Offline Hak Foo
  • Make America Clicky Again!
« Reply #31 on: Wed, 05 August 2009, 19:53:54 »
Check panel types.
I bought a Soyo Topaz S (MVA panel) when they were $300.  Now a similar panel would cost $600, even though I can get a 24 of TN panel for 200 or so.
Overton130, Box Pale Blues.
« Reply #32 on: Wed, 05 August 2009, 20:55:59 »
thanks for the tips everyone. keep 'em coming if you have more.
Offline rdjack21
« Reply #33 on: Wed, 05 August 2009, 22:08:01 »
Like Hak Foo I picked up one of the Soyo Topaz S 24 back when they were $299 and I really love it. But one thing I have found is that the 24"  monitors are really hard to get setup just right so that you don't end up with neck problems/pains. This problem mostly affects vertical position more than horizontal. So you get it set up so that you can look at it dead on but if you need to read text either at the top or bottom you tend to bend your neck to see it. Also through out the day as you shift sitting positions it puts your head in the wrong position to look at the monitor dead on. Unlike smaller monitors you really need to look at the 24" dead on or you will be bending your neck allot to beable to see the whole thing.  At times this has caused me some minor neck pain. What I did to reduce this problem is I bought a good Ergotron monitor arm now as I change sitting postions though out the day I just reach out and push the monitor to where I can focus on it correctly with out having to move my neck around as much. Oh and as far as rotating it 180 the Ergotron I have will let me do that and I tried using it that way for a bit but again found that I had to move my neck too much to see the top and bottom of the screen again causing neck pain. I really need to train my eyes to move more and do less neck movement but at least for me that has been a little harder to do than it sounds.
Also like you my old eyes are not nearly as good as they used to be so my monitor sits at about arm length away from me. And when I get new glasses I have the doctor write me a prescription for reading glasses where the focus is right at arm length. This helps allot. With these glasses on I have no problem reading the screen at all. With my normal glasses I have eye strain and can't really focus on the screen as well as I should be able to.
Keyboards
Topre Capacitive: Realforce 87U, Realforce 86U, HHKB Pro 2, Topre MD01B0, Topre HE0100, Sun Short Type, OEM NEO CS (x2), NISSHO Electronics KB106DE
Buckling Spring: IBM Model M Space Saver (1291472), Unicomp Customizer x 2
Cherry Brown: Filco FKBN87M/EB, Compaq MX11800
Black Alps: ABS M1
Not so great boards Rare Spring over dome OKI, Sun rack keyboard
Trackballs - Trackman Wheel (3), Trackman marble (2)
Keyboards I still want to get - Happy Hacking Keyboard Pro 2 the White version, Realforce 23U number pad in black and maybe white, μTRON ergo board with Topre switches.
Previously owned - [size=0]SiiG MiniTouch (White Alps), Scorpius M10 (Blue Cherry), IBM Model M13[/size]
« Reply #34 on: Wed, 05 August 2009, 22:22:28 »
After all these years of using computers and staring at various good and bad CRTs and LCDs, I still have the bad habit of eventually leaning into the screen more, to be able to read or look at something.
No matter what you use, don't forget to reset your posture and move around a bit every few minutes. Rest your eyes, focus on something else once in awhile. :) Sometimes you don't notice your bad position until some starts aching or getting tired.
« Last Edit: Wed, 05 August 2009, 22:24:44 by DrunkenDonut »
Offline MsKeyboard
« Reply #35 on: Wed, 05 August 2009, 23:02:41 »
I recently started using Gunnar eye glasses.  You might have seen them, yellow, supposedly made to fit your face in such a way as to keep your eyes moist, stylish, and unfortunately expensive. Oakleys for the computer crowd.
There is a lot of hype about these glasses, but I can tell you that they actually work.  I cannot sit down and read a magazine or newspaper much better than without, but when I am working on the computer they allow me much more face time with my monitor before my eyes start complaining.
I really should be wearing my cheaters, but these allow me a little vanity.  Of course, all things come with a price!
« Last Edit: Wed, 05 August 2009, 23:37:56 by MsKeyboard »
Offline bitflipper
« Reply #36 on: Wed, 05 August 2009, 23:11:37 »
Quote from: MsKeyboard;107362
I recently started using Gunner eye glasses.  You might have seen them, yellow, supposedly made to fit your face in such a way as to keep your eyes moist, stylish, and unfortunately expensive. Oakleys for the computer crowd.
Hey MsKeyboard. I've been using these as well - for about the last 3 weeks. I've always been very prone to eye strain/fatigue and related headaches. I don't need or use eyeglasses or reading glasses. I actually have a pair of Prio glasses I got maybe 5 years ago and ended up finding them not very effective. These Gunnars definitely help relieve eye strain.
What frame style did you get Ms?
Offline rdjack21
« Reply #37 on: Wed, 05 August 2009, 23:36:52 »
With out my prescription glasses my monitor is just a blur.  But I would think that the yellow tint on those gunner glasses would cause a colour shift on your monitor.
Keyboards
Black Alps: ABS M1
Offline MsKeyboard
« Reply #38 on: Wed, 05 August 2009, 23:37:12 »
Bitflipper,
Thats too funny, maybe they are just marketing more in AZ.  Ya, I spelled the name wrong, will have to go back and fix that, don't want to upset them.
I received a pair from a vendor earlier this year, the red Bit Surfer's, and received a titanium pair of the Edge's as a gift a couple days later.  I actually really like them, and even though they are slightly different, they don't feel or wear different.
The part that is amazing is that they are so light you forget you even have them on.  Someone will come walking in the door, look at me funny for a minute or so before I remember I'm wearing them.  I had to quit letting people try them on though, got tired of fighting to get them back.
Where did you find yours?  We considered carrying them, but kind of like the Topre, they are priced for those willing to buy comfort.  I can get them though, so let me know if you ever "need" another pair.....Later
Offline MsKeyboard
« Reply #39 on: Wed, 05 August 2009, 23:51:45 »
Ripster,
Scarlett Johansson is putting off that Drew Carey vibe! Not loving it (claws come out). It is amazing how fashion makes the rounds.
rdjack21,
That is supposed to be one of the selling points.  The tint was picked specifically for use with monitors.  As I said before, I can't read the paper with them (at least not any better than without them), but they really do make the screen crisp and clean.
The reviews are mixed, but I really like mine.....Later
« Reply #40 on: Thu, 06 August 2009, 00:32:28 »
the gunnar's look interesting, tho i already wear glasses so i couldnt really use them unless i went back to contact lenses.
but - why does the gunnar description say they shouldnt be used as sunglasses?  they look like the sunglasses bono wears these days.
Offline bitflipper
« Reply #41 on: Thu, 06 August 2009, 00:33:00 »
In AZ, it's really important to take care of your eyes. I never leave home without my shades. And I use the Gunnars more and more at the computer.
I've known about them for a while, but recently I saw an article somewhere about some guys from hardocp.com trying them out and liking them. I picked mine up straight from gunnars.com. I'm sure I'll lose them or destroy them at some point, so I'll be calling you. They just announced their sunglasses - can you get those as well?
I inadvertently leave them on and walk away from the computer. They're very subtle, but they have a nice way of enhancing the LCD screen. I'll reserve judgement as to the eye strain relief until I've used them a bit longer.
My Prios are frameless, so I got the Halogens which are more curved like goggles or sunglasses. Funny, they look great on the website, but I don't care for the way they look on me.
Expensive? I think I paid over $300 for my Prios. I have no clue how much eyeglasses cost. If they help, they're worth the price. IMHO, of course.
Offline bitflipper
« Reply #42 on: Thu, 06 August 2009, 00:44:13 »
Quote from: wellington1869;107376
They do have an option for prescription.
Q: How can I get a pair of prescription Gunnars?
A: Please visit your nearest authorized Gunnar Rx dealer.  You can find a list of our Rx dealers under “Retailers” tab on our website.
The amber tint is probably counterproductive in the sunlight and they're probably not optomized for viewing longer distances.
« Reply #43 on: Thu, 06 August 2009, 00:44:16 »
btw there's apparently a 25% off gunnar e-coupon floating around.
here's gizmodo's review of gunnar.
Offline JBert
« Reply #44 on: Thu, 06 August 2009, 04:14:23 »
I bought a new computer recently and wanted to buy two "regular" 19" monitors from Samsung. Turns out that you are lucky if you can still get one with a 5:4 resolution, 4:3 seems impossible for affordable LCD's.
In the end, it took a few months before the first Samsung 943N arrived (something to do with the supplier), so when the second one was even more delayed I got myself a wide-screen.
Originally I intended to go for a 23" which could be switched to portrait mode, but when that particular model went out of stock, I splashed out and got a Samsung 2443BW (16:10) instead.
Now it has a few particular things. The good:
-large screen area, taller as the 19".
-comes with a foot to adjust height and rotation.
-looks decent for a TN panel.
The bad:
-has problems with its vertical viewing angle, meaning you have to sit right in front of it when in portrait mode.
-makes a long screen, meaning you have to look up to read what is on the top of the screen.
Also, my nvidia card can't rotate image on the wide-screen in Linux when I glue the screens together. That is probably only a problem for people using Linux as their primary OS though.
The storage list:
Currently ignored by: nobody?
[/SIZE]
Offline CX23882
« Reply #45 on: Thu, 06 August 2009, 04:51:05 »
One more point about the Dell 2407WFP-HC - the upscaling is decent and allows you to enforce the original aspect ratio. For example if you're playing an older game at 1024x768, it will stretch it vertically to 1200 pixels height but maintain the aspect ratio instead of filling the entire screen (although you can choose to have it do that if you so wish). At the time I bought it, some of the other monitors always stretched to fit the screen.
It might not be as much of an issue these days now that GPU scaling is available on both ATI and nVidia hardware.
Oh, and DVI and VGA are fine (and the DVI input supports HDCP) but the regular analogue inputs (Component, Composite and S-Video) are a bit crap because it doesn't have a deinterlacer unlike the previous model. This doesn't matter for DVI and VGA but will be an issue if you want to connect something like a Nintendo Wii to it.
Offline iMav
  • geekhack creator/founder
« Reply #46 on: Thu, 06 August 2009, 05:01:02 »
I actually really liked the 30" HP monitor I had for a while.  But when I replaced my 15.4" MBP with a blackbook, I could no longer use it (due to lack of dual link DVI). Of course, now I have an alum MB which could drive the 30" just fine.
Offline itlnstln
« Reply #47 on: Thu, 06 August 2009, 07:22:01 »
I might have to check out some prescription Gunnars (I have an astigmatism) as I sit in front of my rig at work for 11-12 hours a day. One thing I have always done at home and here at the office is to turn the lights down. This way, the monitor is slightly brighter than the ambient light, so you are not competing with the light in the room to see the monitor. Just don't turn the lights all the way off as that will just create eye strain from too much brightness. Doing this has really cut down on the eyestrain and headaches. It also gives the office a romantic feel.
Offline iMav
« Reply #48 on: Thu, 06 August 2009, 10:21:36 »
Quote from: ripster;107423
I have the Dell 2407 too but keep thinking about the 30.  I wonder if it's too big though (I would think neck strain does become an issue at some point) and should compromise on a 27".
It doesn't give you any additional screen real estate over a typical 24".  The only reason I go bigger monitor-wise is to gain pixels.
Offline MsKeyboard
« Reply #49 on: Thu, 06 August 2009, 10:32:36 »
itlnstln,
I really like the idea of turning the lights down, never thought of that.  Kind of hard in our office situation most of the time, but probably a good way to end the day.  I also put in TOO much time at home nights in front of the tv working on the laptop without the lights on, maybe some lighting would be better per your information.
This plays on a whole other meaning to "clean up on isle 5"
Later.........
