Author Topic: the key between s an f on my ucky shine stoppe working  (Read 1727 times)
Offline lolsolga
« on: Tue, 30 December 2014, 00:33:56 »
Just as the title says oes anyone know of any solutions for this. It was working before but for some reason it no longer works.
Offline Snowdog993
  • Grace Under Pressure
  • Justifiably Clueless.
Re: the key between s an f on my ucky shine stoppe working
« Reply #1 on: Tue, 30 December 2014, 00:44:40 »
Did you check it out and look under the keycap to see if you have something stuck in the switch?  Could it be that?  Did you shut down your computer and unplug and replug the cable back in and see if that works?
« Reply #2 on: Tue, 30 December 2014, 03:15:29 »
Is it still under warranty?
If yes, STOP NOW!  And see if you can return it under warranty for repair or replacement.
If it is not under warranty, then it could be a faulty switch, bad soldering, or even a broken trace on the PCB.
You'll need to open the keyboard (hence why it's better not to try this if it is still under warranty as opening the keyboard generally voids the warranty), and first of all try shorting the two pins on the D switch.
If it doesn't work, have a look and see if you can locate a broken trace around that switch.  Have a look here for what that looks like.
If that still does not work, try reflowing the solder around the pins on that switch.
If it still does not work, you might need to replace the switch.  In the short term you could swap the switch with one of the 4 extras in the top right corner (assuming you have a full sized keyboard).
Offline fanpeople
« Reply #3 on: Tue, 30 December 2014, 03:32:08 »
I bet you are craving the D right about now.  ;D
Offline Touch_It
« Reply #4 on: Tue, 30 December 2014, 09:40:05 »
On topic @op i hope you get it working, not much of value I can add.
off topic omg that really made me giggle.
Offline Fragil1ty
  • Abre los ojos.
« Reply #5 on: Tue, 30 December 2014, 16:14:01 »
Just return it if you can, let's hope ducky have a good return policy and what not.
你搞砸了
