Author Topic: Leather punch question (proper place?)  (Read 3176 times)
Offline Touch_It
« on: Wed, 31 December 2014, 10:18:42 »
Couldn't decide the best place to post this but decided here since it is keyboard related and probably gets the most views.  Someone please move it, if there is a more appropriate place.  I'm looking to pick up some leather or hole punches to punch out new foam for my model F keyboard.  I would like to pick them up locally from a store, eg Sears, Menards ETC.  It looks like the sizes in metric I would need are 12mm and 3mm or the equivalent in Imperial.  Cheap is a main goal.  Preferably $10 or under, but I would be willing to go up to $15 ish if I didn't have to order online.  If it comes down to it though I will order online.
Re: Leather punch question (proper place?)
« Reply #1 on: Wed, 31 December 2014, 10:21:48 »
Leather punches are hard to find that cheap.  I got a cheap set with interchangeable punches for $30 from Tandy Leather.  If you want cheap crap, you can try Harbor freight.
Offline Tactile
« Reply #2 on: Wed, 31 December 2014, 11:47:28 »
Try looking at a local hardware store with a good tool selection. Don't ask for "leather punches", but instead "hollow punches" or "hole punches". Mechanics use this type of punch all the time to make gaskets, etc.
Ahhh, nubbinator had a good idea about Harbor Freight...
http://www.harborfreight.com/9-piece-hollow-punch-set-3838.html
REΛLFORCE
« Reply #3 on: Wed, 31 December 2014, 11:47:30 »
I bought a used (antique, perhaps) 5/8" punch on ebay.
Rather than use a 1/2" for the main hole and a nip for the alignment tab, I punched them off-center so that there is a crescent of gap reaching around toward the tab. The harder way would be better, but much harder to hit accurately and more time consuming.
I have done a dozen of these and they worked out fine. You are really just looking for a pad for the barrel to bed into. The barrels sit shoulder-to-shoulder and hold themselves in alignment.
- Bill Roberts 2026-06-17
« Reply #4 on: Wed, 31 December 2014, 13:04:34 »
I also got a vintage punch from ebay. It was $5 shipped I believe. I had to sharpen it though. And again halfway through.
After that, my local hardware store had a new punch for pretty cheap.
Offline Snowdog993
  • Grace Under Pressure
  • Justifiably Clueless.
« Reply #5 on: Wed, 31 December 2014, 13:12:42 »
I looked around and the best thing I could find was this:
http://www.holepunchworld.com//index.cfm?getSubCat=57&getCat=Industrial%20Punches&pid=143
Maybe that helps you?
Offline Snowdog993
« Reply #6 on: Wed, 31 December 2014, 13:15:48 »
I checked that link, and wow, that's 100x better!  Gawd I try too hard to help!
Offline 0100010
  • Not Sure
« Reply #7 on: Wed, 31 December 2014, 13:26:13 »
I just used a razor myself.  Granted cutting that many holes by hand, in three different sets of foam was not fun - a punch would have been easier.
Offline Parak
« Reply #8 on: Wed, 31 December 2014, 13:59:17 »
I highly recommend getting an arch punch from here - they are high quality USA made punches:
http://www.brettunsvillage.com/leather/tools/tools.html
Scroll down until you find individuals, and get the 5/8" size which will cut out the hole including the barrel notch. Should be $20 shipped.
Like any tool that I expect to use for a long time, I prefer paying a bit more over some chinese generic..
Offline Melvang
  • Exquisite Lord of Bumfluff
  • Melvang's Desktop Customs
« Reply #9 on: Wed, 31 December 2014, 14:20:29 »
I would have to second this choice.  I work with hand tools every day at work and I refuse to buy cheap crap.  For using these make sure that you have a good sized piece of hardwood under the foam when using.  For they record you can use metal faced hammers with these.  Just take your time.  For punching foam you only want to hit it hard enough to just punch through clean with one hit.  I use hole punches like these at work for making gaskets as nubby posted earlier.  These should last for years to come.  When storing for any length of time, spray with a light oil like sewing machine or gun oil and wrap in waxed paper.  Put this into a ziploc bag to keep the oil from getting where you don't want it.  This will keep the cutting edge from rusting.
Offline Touch_It
« Reply #10 on: Sun, 11 January 2015, 18:32:11 »
Thanks
With your advice I went ahead and didn't cheap out on this.  Hopefully I'll get it next week and will finally open my baby up.  Scares me though.  Never worked on a Model F before :(.
« Reply #11 on: Sun, 11 January 2015, 18:46:49 »
Ha Ha Ha Ha Ha
Be brave, Grasshopper, and do not be afraid to do everything at least 4 times. Or 14
Offline Touch_It
« Reply #12 on: Sun, 11 January 2015, 18:54:15 »
Ha Ha Ha Ha Ha
well... That laughing certainly makes me feel better.....
Offline Noko
  • jolonarr: a tough dude who takes no esses!
    • Noko's Leatherworks
« Reply #13 on: Sun, 11 January 2015, 19:13:42 »
Thanks very much for this link!  I will definitely be picking up some of these.
Noko's Leatherworks - Handmade Custom Leather Wrist Rests -  http://www.noko.ca
Sales Thread: http://geekhack.org/index.php?topic=51762.0
Build Log: http://geekhack.org/index.php?topic=47704.0
« Reply #14 on: Sun, 11 January 2015, 20:10:59 »
The small ones are much easier to open and close than the 122-key models.
Just realize that brute force and exquisite balance will be required simultaneously.
Offline Touch_It
« Reply #15 on: Sun, 11 January 2015, 20:17:07 »
This is for my 4704 107 key.
I'm not gonna call that small
Well I guess I gotta learn somehow.
