Author Topic: Vintage Used Sperry Univac UTS 400 Monitor & Keyboard  (Read 14803 times)
Offline rdjack21
« on: Thu, 06 August 2009, 15:17:05 »
Just check out the keyboard on this baby. If the shipping was not so high I just have to bid on this for the keyboard.
http://cgi.ebay.com/Vintage-Used-Sperry-Univac-UTS-400-Monitor-Keyboard_W0QQitemZ310159030661QQcmdZViewItemQQptZLH_DefaultDomain_0?hash=item4836eb3985&_trksid=p3286.c0.m14
Keyboards
Topre Capacitive: Realforce 87U, Realforce 86U, HHKB Pro 2, Topre MD01B0, Topre HE0100, Sun Short Type, OEM NEO CS (x2), NISSHO Electronics KB106DE
Buckling Spring: IBM Model M Space Saver (1291472), Unicomp Customizer x 2
Cherry Brown: Filco FKBN87M/EB, Compaq MX11800
Black Alps: ABS M1
Not so great boards Rare Spring over dome OKI, Sun rack keyboard
Trackballs - Trackman Wheel (3), Trackman marble (2)
Keyboards I still want to get - Happy Hacking Keyboard Pro 2 the White version, Realforce 23U number pad in black and maybe white, μTRON ergo board with Topre switches.
Previously owned - [size=0]SiiG MiniTouch (White Alps), Scorpius M10 (Blue Cherry), IBM Model M13[/size]
Offline timw4mail
    • https://timshomepage.net
« Reply #1 on: Thu, 06 August 2009, 15:51:06 »
As cool as it would be to get that, how could you use it?
Not to mention, it probably has linear switches.
Buckling Springs IBM Model F AT, New Model F 77, Unicomp New Model M
Clicky iOne Scorpius M10, OCN-branded Ducky DK-9008-C, Blackmore Nocturna, Redragon Kumara K552-1, Qtronix Scorpius Keypad, Chicony KB-5181(Monterey)
Tactile Apple AEKII (Cream damped ALPS), Filco FKBN91M/JB (Japanese Tenkeyless), Cherry G84-5200, Cherry G84-4100LPAUS, Datalux Spacesaver(Cherry ML), Redragon Devarajas K556 RGB, Newmen GM711, Poker II (Cherry MX Clear), Logitech G910 Orion Spark, Logitech K840
Linear Lenovo Y (Gateron Red), Aluminum kiosk keyboard (Cherry MX Black)
Offline ch_123
« Reply #2 on: Thu, 06 August 2009, 15:55:40 »
Yeah, looks quite similar to the old DEC VT-100 keyboard I found. Everything back then had lightweight linears. If you exclude typewriters, IBM's buckling spring keyboards were probably the first tactile switches to show up.
Offline rdjack21
« Reply #3 on: Thu, 06 August 2009, 15:58:37 »
All I really want is the keys them self. Then I would just have to figure out how to mount them on a modern switch. I just love those old cupped keys. I keep looking for a set. I almost got a set from a old VT-100 but just missed it.
Keyboards
Black Alps: ABS M1
Offline itlnstln
« Reply #4 on: Thu, 06 August 2009, 16:05:47 »
Quote from: rdjack21;107620
I have always like that industral, all-caps look of the old keycaps.
Offline ch_123
« Reply #5 on: Thu, 06 August 2009, 17:55:46 »
I think there's some element of truth in that - the old VT100 board's keys don't go down properly if you press down at the sides.
Offline rdjack21
« Reply #6 on: Thu, 06 August 2009, 21:51:16 »
Quote from: webwit;107677
I bet cupped keys are another urban legend. I think they were cupped to force the user to hit the keys dead center. And when that was no longer necessary, they were replaced by flatter keycaps which are actual superior in terms of speed and comfort.
It has been so long since I have put my fingers on that type of key all I can remember is that the keys just felt good. Not the switch but the keys. But seeing as how long ago that was you may be right but I still would like to try them again and see how I like them today.
Keyboards
Black Alps: ABS M1
Offline rdjack21
« Reply #7 on: Thu, 06 August 2009, 21:53:44 »
Quote from: ripster;107696
It's just a vestige of the typewriters.  Probably had a lot more tooling available for this style of key back then.
That is what I'm looking for. I seem to remember seeing some on an old Alps board don't remember which one though. I keep hoping that I can find those then maybe I will not have to modify them as much to make them fit on a current switch.
Keyboards
Black Alps: ABS M1
Offline lowpoly
« Reply #8 on: Fri, 07 August 2009, 15:04:18 »
My cupped Symbolics keys can be pressed anywhere, no difference. Maybe the cupped design was the successor of the old round typewriter keys, glass with a metal edge. Those are kind of cupped as well.
The first UNIVAC 'board is from a 1610/1710 cardpunch:
Here's a UNIVAC II control panel:
So that's what inspired the C64. :suspicious:
« Last Edit: Fri, 07 August 2009, 15:12:40 by lowpoly »
Offline quadibloc
  • Layout Fanatic
    • John Savard's Home Page
« Reply #9 on: Tue, 06 October 2009, 14:08:40 »
Actually, the history is the other way around.
There were flat keys for old mechanical typewriters which had a round metal edge to hold in the clear plastic disk covering the paper key legend.
When keys were made out of plastic, they tended to have a spherical curvature, although there were some exceptions in the manual typewriter days.
The old IBM electric typewriters had square keys like a Flexowriter - which indeed seems to have an IBM electric typewriter mechanism. These had spherical depressions. And pretty much all other typewriter and computer terminal keyboards followed suit.
When the IBM PC came out - or, rather, its predecessor, the Datamaster - IBM had the brilliant idea of using keys with cylindrical tops. This still helped to locate the fingers, but because a cylinder is a 'reducible surface', plastic stickers with key legends on them could be applied to the tops of the keys. The popularity of the IBM PC drove nearly everyone else to adopt this style of key in fairly short order to make their keyboards look "modern". The IBM PC also introduced putting the key legends on the left side of the key, and the capital letters at the top to show that the keys only make capital letters when they're shifted (or when Caps Lock is on, but let's not get into that).
Cupped keys with centered legends, with the letter keys having big letters on them that filled the key, had been the standard before the IBM PC, used by everybody - DEC, IBM, Unisys, Control Data, NCR... and suddenly, IBM introduced a new style of keyboard, and everyone wanted to look like IBM... once again.
Offline quadibloc
  • Layout Fanatic
« Reply #10 on: Thu, 08 October 2009, 21:59:43 »
The photograph, surprisingly, lets one read most of the legends on the keys, but not all of them.
However, doing a little web searching, I found a document on a system that NASA used, called REACT, by which NASA researchers could search for scientific papers from home. They happened to use two terminals for this service, one made by Bunker-Ramo, and the other being the UTS 400.
Hence, I was able - without digging through my papers in the basement (where I think I have a brochure for this terminal) - to complete this diagram of the keyboard, with all the legends present:
Actually, the key marked "Program Unload" is one I'm still not sure about.
Offline msiegel
« Reply #11 on: Thu, 08 October 2009, 22:04:47 »
Quote from: quadibloc;124001
maybe it's an early form of Sys Rq :)
hmm, arrow keys on the left is neat idea!
