Author Topic: Unicomp Model M not working?  (Read 2713 times)
Offline shut up
« on: Fri, 02 January 2015, 15:03:10 »
I received a Model M terminal made by Unicomp in the mail today, in new condition. Everything looks fine, except it doesn't work. Enter on the num pad works, Windows recognizes the drivers except none of the other keys work. Now I've got two broken Model M keyboards, Yay!
Any advice, or am I better off trying to return it?
Edit: Sorted out.
« Last Edit: Fri, 02 January 2015, 18:59:39 by shut up »
IBM Model M 42h1292 (Bolt mod, but still broken Yaaaayyyy) | Adesso Mkb-125b MX blues | Alienware Tactx (D0me5.)
Re: Unicomp Model M not working?
« Reply #1 on: Fri, 02 January 2015, 15:34:59 »
Unicomp has a great repair service for about $30 even if you did not buy it from them.
"you've got to cheat like hell"
- D Trump - 2026-09-10 Dallas, Texas
Offline shut up
« Reply #2 on: Fri, 02 January 2015, 16:24:44 »
Probably not worth it for that, But thanks. I could get a whole new one or repair my bolt mod one for that.
Offline Touch_It
« Reply #3 on: Fri, 02 January 2015, 20:09:02 »
Mind stating the fix?  Could be helpful to someone in the future.
Offline ezrahilyer
« Reply #4 on: Fri, 02 January 2015, 20:15:44 »
That really seems odd to have only one key register and it happens to be the enter key on the num-pad.
I have heard that the Unicomp implementation of USB is not all that great, have you tried it on another maybe older PC? (Not that I think that there is something wrong with drivers or anything, I just wonder if it might not like certain PCs)
-Ezra
Offline shut up
« Reply #5 on: Fri, 02 January 2015, 20:55:27 »
I....... Am going to return it. :P
Offline shut up
« Reply #6 on: Fri, 02 January 2015, 20:56:30 »
-Ezra
I tried on Windows XP-8. So probably not.  :thumb:
Offline ezrahilyer
« Reply #7 on: Fri, 02 January 2015, 21:34:25 »
-Ezra
That must be very frustrating!
Offline Touch_It
« Reply #8 on: Fri, 02 January 2015, 21:37:23 »
Sad, are you getting a replacement or going a different direction?
Offline shut up
« Reply #9 on: Sat, 03 January 2015, 07:24:56 »
Replacement, This is my 2nd Model M that hasn't worked so far  :-X
Offline Touch_It
« Reply #10 on: Sat, 03 January 2015, 09:14:14 »
Sorry to hear it, :(.  Hopefully third time is the charm.  I really like my unicomp though it isn't a 122 key.
Offline shut up
« Reply #11 on: Sat, 03 January 2015, 11:29:00 »
Thanks man  :) 3rd time is a charm I hope, Haha.
