Author Topic: Razer Blackwidow Tournament 2014 not detected  (Read 3545 times)
Offline stareckiy
« on: Sat, 03 January 2015, 07:01:39 »
That happened at new year's night, when I was playing games with friends. The keyboard just turned off, I've exited game and Razer Synapse asked for an update, I updated it and nothing happened, keyboard wasn't recognized. I reconnected it to another usb-ports, some times it gave a sound like device is connected and keyboard lighted up pale, some times not. Every time I reconnect the keyboard to computer, it heats up in the right part of it. Asking for advices.
Offline stareckiy
Re: Razer Blackwidow Tournament 2014 not detected
« Reply #1 on: Sat, 03 January 2015, 07:40:55 »
bump
Offline Altis
« Reply #2 on: Sat, 03 January 2015, 11:13:03 »
No idea what it could be. Have you tried connecting it to another computer?
Sounds like something might've gone really wrong inside the board. Might be worth opening up and having a look.
Offline Fragil1ty
  • Abre los ojos.
« Reply #3 on: Sat, 03 January 2015, 11:27:24 »
Is it new? If so, I'd try and return it as faulty and get a replacement, probably the best and more viable route to be honest.
你搞砸了
Offline Geroximo
« Reply #4 on: Sat, 03 January 2015, 11:35:55 »
If you still have warranty, you can easily return it and get a new one.
Razer is very generous with their replacement policy. They have to. You cannot sell inferior hardware with cloud spyware AND have a ****ty support.
Offline stareckiy
« Reply #5 on: Sat, 03 January 2015, 14:15:08 »
Yes, I tried to connect it to another computer and it wasn't detected. I think the problem might be in firmware, but can't reinstall it, cuz can't find firmware for razer blackwidow te 2014. There is a problem to use warranty as I've bought the keyboard in another country.
Offline fuzzybaffy
« Reply #6 on: Sat, 03 January 2015, 14:55:07 »
I actually had the same problem (with the regular Blackwidow Ultimate, not TE), and I think a re-start fixed it. Have you tried that?
Offline stareckiy
« Reply #7 on: Sat, 03 January 2015, 15:01:34 »
Computer restart? Ofc I tried, I even reinstalled windows7, but that was useless.
Offline stareckiy
« Reply #8 on: Sun, 04 January 2015, 08:30:57 »
bump
Offline Khers
  • Schrödinger's box
« Reply #9 on: Sun, 04 January 2015, 10:10:08 »
« Last Edit: Tue, 03 July 2018, 08:10:20 by Khers »
Offline stareckiy
« Reply #10 on: Mon, 05 January 2015, 08:46:24 »
Well, razer support told I should exchange my keyboard. Ty all for advices
Offline Mountain Man
« Reply #11 on: Mon, 05 January 2015, 15:00:54 »
Sounds like the kind of "quality" I've come to expect from Razer.  Their products tend to develop faults within 12-months and rarely last more than 2-years.  My advice is to get a refund, if possible, and buy a different brand.
